Welcome to the North American Subaru Impreza Owners Club Wednesday April 16, 2014
Old 09-21-2013, 06:21 PM   #3351
Celery GT-5
Member#: 98210
2015 WRX Premium
wow thanks, any idea which ones they soldered?
Celery GT-5 is offline   Reply With Quote
Old 09-24-2013, 02:45 AM   #3352
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
My 2011 WRX headlights are starting to get more and more cloudy and I'm wondering if anyone else is having this problem. I park my car inside a garage every night and use a headlight sealer about 1-2x's a month (
Blue Magic 730-6 Headlight Lens Sealer - 8 oz. : Amazon.com : AutomotiveBlue Magic 730-6 Headlight Lens Sealer - 8 oz. : Amazon.com : Automotive
so I'm really confused why this is happening. Do you think the dealership will cover this? Or should I just get a headlight restore kit and fix it myself?
xabre1200 is offline   Reply With Quote
Old 09-24-2013, 08:04 AM   #3353
Celery GT-5
Member#: 98210
2015 WRX Premium
Maybe stop using the headlight sealer..its way too soon for them to be fogging
Old 09-24-2013, 12:45 PM   #3354
13orangecrush
Member#: 365304
^^^~~~ agreed
13orangecrush is offline   Reply With Quote
Old 09-24-2013, 02:03 PM   #3355
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
Yeah that's a good idea. I use it only because it says it prevents clouding and is supposed to provide uv protection for the headlights. I'm gonna try and bring my car to the dealership and get it checked out cause I haven't seem anyone with this problem before
Old 09-25-2013, 11:56 AM   #3356
rwfloberg
Member#: 327538
2012 WRX (307/344)
After installing steering rack bushings and bolting up the rack about a tooth off, my steering wheel is slightly off center.
Would it be acceptable to pull the steering wheel itself off and re-align?
rwfloberg is offline   Reply With Quote
Old 09-25-2013, 06:34 PM   #3357
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
Did you do the install yourself?
Old 09-26-2013, 10:09 AM   #3358
rwfloberg
Member#: 327538
2012 WRX (307/344)
Yeah, installed it, but just couldnt get the rack to line up 100%
Old 09-26-2013, 12:04 PM   #3359
Louie
Member#: 43393
2011 STi
After installing steering rack bushings and bolting up the rack about a tooth off, my steering wheel is slightly off center. Would it be acceptable to pull the steering wheel itself off and re-align?
I'm going to speculate no.. There are sensors in the steering wheel that allows the vdc to sense if the car is sliding. (Iirc)
Louie is offline   Reply With Quote
Old 09-30-2013, 10:02 PM   #3360
corvid
Member#: 300097
What was the ideal idle vacuum? Im at -18, and I thought it was in the 19-21 range. Might also be because the car as 200 miles on it.
corvid is offline   Reply With Quote
Old 09-30-2013, 10:08 PM   #3361
Celery GT-5
Member#: 98210
2015 WRX Premium
warm idle should be over 20 I think, although I think the actual range is like 17-22
Old 10-01-2013, 09:13 AM   #3362
Asharus
Member#: 276300
2011 WRX Ltd 5DR SWP
Stg2 310/326@17.5psi pump
i get 22/24 on my AEM digital when warm
Asharus is offline   Reply With Quote
Old 10-01-2013, 10:17 AM   #3363
honestabe
Member#: 261730
2011 WRX hatch
Do this and be merry.
http://forums.nasioc.com/forums/show...irits+urethane
Results are awesome, they look brand new and have stayed that way for a couple months now:
honestabe is online now   Reply With Quote
Old 10-01-2013, 12:00 PM   #3364
rwfloberg
Member#: 327538
2012 WRX (307/344)
Thanks. Research doesnt seem to turn up a definitive answer, and it seems I may screw up the clock spring too. Too risky, Ill wait until I need an alignment.
Old 10-06-2013, 02:24 PM   #3365
PearlRex11
Member#: 284420
2011 WRX Sedan
A friend of mine did those steering bushings and didn't align things properly. Ended up breaking a sensor when he turned the wheel, it was rather expensive to have replaced from what he said.
PearlRex11 is offline   Reply With Quote
Old 10-06-2013, 05:59 PM   #3366
_davin
Member#: 260501
2011 WRX 5dr SWP Ltd
Anyone else have to replace the rack and pinion already?
_davin is offline   Reply With Quote
Old 10-07-2013, 09:14 AM   #3367
tcoffin014
Member#: 173734
2011 WRX
Sexy White Princess
My friend did. He rally crosses his car though
tcoffin014 is offline   Reply With Quote
Old 10-18-2013, 09:04 PM   #3368
Celery GT-5
Member#: 98210
2015 WRX Premium
Old 10-24-2013, 02:04 PM   #3369
Bulls_fan
Member#: 289104
2011 WRX Limited
World Rally Blue
Not sure if this is the right place for this question, but didn't want to clog up the picture thread anymore...
For people who plastidipped the side vents in the front bumper, how did you do it? Are they removable or did you just tape it off?
Bulls_fan is offline   Reply With Quote
Old 10-24-2013, 02:14 PM   #3370
Celery GT-5
Member#: 98210
2015 WRX Premium
they just pop off, although you could just mask around it and peel the excess off the surrounding paint
Old 10-24-2013, 03:02 PM   #3371
Bulls_fan
Member#: 289104
2011 WRX Limited
World Rally Blue
Ok thanks!
Old 10-24-2013, 04:13 PM   #3372
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
I dipped mine and it lasted only 1 year before it started getting too damaged from debris.
Old 10-24-2013, 04:23 PM   #3373
Celery GT-5
Member#: 98210
2015 WRX Premium
so just peel it off and redo it, its easy
Old 10-24-2013, 04:53 PM   #3374
Celery GT-5
Member#: 98210
2015 WRX Premium
so I'm wondering if it would be worth while to get some metal plates or something to make my exhaust tips look less out of place with the bumper did a trial run with cardboard and photoshop
Old 10-24-2013, 05:00 PM   #3375
SWP is Sexy
Member#: 302389
2011 WRX
Imperial White
It looks... not as glaring but still out of place. Cutting out the center so you just had one big opening across the back would work better imo
SWP is Sexy is offline   Reply With Quote
Differences of 2011 wrx motor and 2011 sti motor stpkenton Factory 2.5L Turbo Powertrain 3 03-06-2012 11:03 AM
Differences of 2011 wrx motor and 2011 sti motor stpkenton Newbies & FAQs 3 05-12-2011 09:27 PM
2011 Subaru shifter fitment! All TWM Shifters still fit! TWM Performance Vendor Announcements 14 02-28-2011 03:27 PM
iPod 3g DLO Jam Jacket (clear) and Radtech 3g Indigo Podsleev 10gb/15gb agentmaxwell Private 'For Sale' Classifieds 1 05-24-2006 07:41 PM
Attn: Clayton, Ben and all others involved in the 6MT discussion. sherifx Mid West Subaru Owners Club Forum -- MWSOC 1 07-31-2002 03:00 AM
