Old 03-02-2012, 05:17 PM   #1226
SWP is Sexy
Member#: 302389
2011 WRX
I'm a stormtrooper pewpew
On a completely unrelated note, anyone know if theres a way to customize the display on an AP? I don't wanna do anything fancy, just adjust the primary color because I'm tired of having the big blue glow that doesn't match anything else in my car at night.
SWP is Sexy is offline   Reply With Quote
Old 03-02-2012, 05:18 PM   #1227
Celery GT-5
Member#: 98210
2016 Forester XT CWP
2002 WRX SRP
os lol
Celery GT-5 is offline   Reply With Quote
Old 03-02-2012, 05:18 PM   #1228
_davin
Member#: 260501
2003 miata SE
Blurple
Originally Posted by Celery GT-5 View Post
how old is the oil?
Meh, a little over 3k I think, so theorheticly I could go another 3k with little worries. Not that I planed to.
_davin is offline   Reply With Quote
Old 03-02-2012, 05:20 PM   #1229
chanomatik
Member#: 159474
2013 BRZ Ltd 6MT CBS
SNOSLO
Originally Posted by _davin View Post
I think you misunderstood, I'm not asking what would perform better.
As in should I just dirty up the used oil more since I'm about to change it anyway, or would it be particularly better for the engine were I to put fresh oil in before redlining it a bit.
Why wouldn't you want FRESH oil? Wouldn't your engine be happier? I mean, if someone REALLY wanted to, they could do an oil change every 1k miles just for the peace of mind.
Sounds like that's what you're looking for: Peace of mind.
Go fresh!
Old 03-02-2012, 05:34 PM   #1230
_davin
Member#: 260501
2003 miata SE
Blurple
Well yeah I guess, now I feel silly for asking. I guess what I was getting at was if I changed it before hand, and that dirtied it up a bit, would it be worse for the engine in the long run afterwards, assuming I didn't change it again until the regular interval. But you're right I should probably change it first, thanks.
Old 03-02-2012, 05:58 PM   #1231
Celery GT-5
Member#: 98210
2002 WRX SRP
6k oil changes are not something you want to do with a turbo car
Old 03-02-2012, 06:06 PM   #1232
_davin
Member#: 260501
2003 miata SE
Blurple
Well subaru says 7500 but I guess I'm excluded with "extreme conditions".
Originally Posted by AKSubie View Post
My thoughts on oil: Some of which is IMHO, some is regurgitation from what I've read and some ... probably way off base.. HAHAaha.
IMHO, Synthetic oil is the way to go unless you are breaking in an engine or have an old and tired engine that might not be sealed as properly. Synthetic tends to help protect more against sludging.
For me, I have used Mobil 1 almost exclusively up until I tried Amsoil. Cost difference for me wasnt that bad. My buddy's discount was ~$9/QT vs the M1 German blend for ~$8/QT. My oil change intervals are hovering around the 10k mile mark. Due to time constraints my last change went till 12k and was quite ... concerned/anxious. However I sent my oil off to Blackstone for a UOA and it came back very good with a recommendation I could go even longer. To note, I am also using the Amsoil oil filter if it makes a hill o beans. I have run the car again to 12k miles (with a couple ice races) and will again send it off for UOA.
According to what has been stated on various forums like QW, Rotella T6 seems to be the new preferred oil for higher end cars & turbo cars. Amsoil isn't too far behind right along side M1 (kind of a preference/available thing), and RP is far in the back. Most also tend to begin relying on UOA reports, almost to an anal level to discern their oil use and change intervals. MOST believe though, that changing a synthetic oil any sooner than 5-6k miles is considered wasting money.
Cliff Notes: I used to use M1, now use Amsoil 0w40. Changing at 10-12k miles with a Blackstone report. You should be fine with a synthetic.
Old 03-02-2012, 06:10 PM   #1233
Celery GT-5
Member#: 98210
2002 WRX SRP
if you read more carefully I believe it says being turbo automatically equals extreme condtions
Old 03-02-2012, 06:57 PM   #1234
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
Originally Posted by chanomatik
Louie caused me to realize that the Legacy comes with shocks for the trunk lid that aren't the stupid bars that Impreza's use.
I'm going to look into having something fabbed for my WRX based on what I can figure for the Legacy's set up.
Louie, do you think this can be done?
Yes can be fabbed, probably won't seal as well.
Louie is offline   Reply With Quote
Old 03-02-2012, 07:13 PM   #1235
chanomatik
Member#: 159474
SNOSLO
I change at 7500 because Subaru tells me to. I'm extreme like that. I'll let you know if anything happens to my engine. So far, so good.
I checked out the Legacy and 2012 Impreza sedan today. Legacy is big enough to hide the components on either side of the trunk opening, 2012 Impreza has the bars moved closer to the outside edge of the trunk and they're hidden when you close the trunk. Much nicer compensation of space.
I guess I'm screwed. I'm such a baby.
Old 03-02-2012, 10:44 PM   #1236
tcoffin014
Member#: 173734
2011 WRX
Sexy White Princess
I change my oil every 6k miles give or take. I use rotella t6. My friend gets his oil tested (same oil in an sti) every other oil change and they say it's good for about 8k. Not that they say to go that far but it would be ok of you did
tcoffin014 is offline   Reply With Quote
Old 03-03-2012, 10:11 AM   #1237
BullyWRX
Member#: 258756
2011 WRX
Didn't you get your addendum package from Subaru? I received a couple new booklets for the owners manual pouch, and a letter instructing me to throw out the other ones and replace with the new ones. The letter also stated that the service intervals for all 2011+ Subaru's, with turbo engines, was now extended to 7500 miles. No more clause for extreme conditions. That was in place before the requirement to use synthetic oil, only!
BullyWRX is offline   Reply With Quote
Old 03-03-2012, 12:55 PM   #1238
Celery GT-5
Member#: 98210
2002 WRX SRP
I guess it does say that...it also says
Engine Oil/filter*1,
ALL TURBO models Forester XT, WRX, STI, Legacy GT
requires Synthetic 5w-30 oil.
1st oil change is required by 7500 miles or 7.5 months and is required at least every 7500 miles or 7.5 months after that. It is strongly recommended to do more often than that.
Old 03-05-2012, 12:03 PM   #1239
ciege125
Member#: 306475
2012 STI Sedan
okay noob question: On a brand new 2012 sti would a turbo timer be beneficial at all? Possibly to protect the turbo? I plan on running cobb stage 1 maps right out of the box. Thanks in advance.
ciege125 is offline   Reply With Quote
Old 03-05-2012, 12:15 PM   #1240
_davin
Member#: 260501
2003 miata SE
Blurple
From what I gather they're cooled enough it's not necessary. If you're really thrashing it just give it a minute before you turn it off.
Old 03-05-2012, 12:17 PM   #1241
Celery GT-5
Member#: 98210
2002 WRX SRP
Somewhere in subaru's literature it says you should let the car idle for 30 seconds after hard acceleration or a long highway trip. I have also heard people say that its not necessary because of the way the turbo is designed. I try to let my car idle for a little while after I've been mean to it. If you are really concerned about it I don't really see the harm but it seems like a waste of money plus extra wires and a box cluttering up a new car. I haven't seen one person say that they had a turbo timer on a 3g wrx since I bought my car.
Old 03-05-2012, 12:18 PM   #1242
rmj
Member#: 276611
2011 STi 5-Door
Plasma Blue Pearl
Yeah or just don't drive hard for a bit/a few minutes after running it hard and let it cool down so it's cooled when you park.
rmj is offline   Reply With Quote
Old 03-05-2012, 12:24 PM   #1243
Ying
Member#: 166490
2011 WRX
Subaru turbos are water cooled and do not require any idling for a DD, and thus no TT. If you take the car out and flog it at a track or autox event, then I'd let it sit for a minute but you're money is better spent elsewhere like bushing upgrades.
Ying is offline   Reply With Quote
Old 03-05-2012, 06:03 PM   #1244
PearlRex11
Member#: 284420
2011 WRX Sedan
I put an hks type 1 TT on my 2011 wrx just for piece of mind. It was only $50 brand new off of here. I don't trust myself with remembering to wait to shut it off if i drive hard. It also reminds me to pull the e brake because i park in neutral. Serves as a volt gauge as well
PearlRex11 is offline   Reply With Quote
Old 03-05-2012, 08:43 PM   #1245
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
Not the best use of money unless you're driving your car hard at the track.
xabre1200 is offline   Reply With Quote
Old 03-05-2012, 09:42 PM   #1246
PearlRex11
Member#: 284420
2011 WRX Sedan
It gives me piece of mind. Whether it was physically needed is debatable, I will give that.
Old 03-05-2012, 09:45 PM   #1247
Celery GT-5
Member#: 98210
2002 WRX SRP
Im gonna walk around with a condom on so I don't accidentally fall on teh aids
Old 03-05-2012, 10:57 PM   #1248
_davin
Member#: 260501
2003 miata SE
Blurple
Lawl.
Old 03-06-2012, 12:43 AM   #1249
PearlRex11
Member#: 284420
2011 WRX Sedan
Lol. Nasioc is the worst for douchebaggery. “we hate your turbo timing a**, why don't you go time your turbo somewhere else"
Old 03-06-2012, 12:53 AM   #1250
Celery GT-5
Member#: 98210
2002 WRX SRP
why because we said it isn't really necessary and made a lighthearted joke?
Differences of 2011 wrx motor and 2011 sti motor stpkenton Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 03-06-2012 11:03 AM
Differences of 2011 wrx motor and 2011 sti motor stpkenton Newbies & FAQs 3 05-12-2011 09:27 PM
2011 Subaru shifter fitment! All TWM Shifters still fit! TWM Performance Vendor Announcements 14 02-28-2011 03:27 PM
iPod 3g DLO Jam Jacket (clear) and Radtech 3g Indigo Podsleev 10gb/15gb agentmaxwell Private 'For Sale' Classifieds 1 05-24-2006 07:41 PM
Attn: Clayton, Ben and all others involved in the 6MT discussion. sherifx Mid West Subaru Owners Club Forum -- MWSOC 1 07-31-2002 03:00 AM
