Old 03-30-2012, 01:55 PM   #1451
SWP is Sexy
Member#: 302389
2011 WRX
I'm a stormtrooper pewpew
Anyone know what kind of spacers we can run without needing longer studs? I thought I read somewhere something about 5mm, but I'm not sure.
SWP is Sexy is offline   Reply With Quote
Old 03-30-2012, 06:25 PM   #1452
PearlRex11
Member#: 284420
2011 WRX Sedan
Not sure about universal type spacers but I think you can run bigger spacers than that if you do hub centric spacers, which are a lot better.
PearlRex11 is offline   Reply With Quote
Old 03-30-2012, 08:21 PM   #1453
Celery GT-5
Member#: 98210
2016 Forester XT CWP
2002 WRX SRP
just get good spacers that have studs on them, better yet just buy wheels with the offset you want
Celery GT-5 is offline   Reply With Quote
Old 03-31-2012, 02:12 AM   #1454
SWP is Sexy
Member#: 302389
2011 WRX
Yeah I know, but I was looking at some spacers we have at work and was thinking if I could pick up a set for cheap may as well
Old 03-31-2012, 10:36 AM   #1455
BullyWRX
Member#: 258756
2011 WRX
As long as the lugnuts cover the same length of the stud as the stud is wide, you'll be good to go!
BullyWRX is offline   Reply With Quote
Old 03-31-2012, 06:23 PM   #1456
Poptart1318
Member#: 230510
2011 MX-5
Finally got around to blacking out the window chrome last night..looks so much better without the chrome IMO.
Used some matte black vinyl that my buddy had laying around. My edges aren't the cleanest, but you cant notice unless you put your face up to it...and free is always better than the $30 pre cut strips
Poptart1318 is offline   Reply With Quote
Old 03-31-2012, 10:12 PM   #1457
08fg2
Member#: 281219
2012 wrx hatchback
satin white pearl
Went cone dodging today for the first time and dang...sways and bushing are a MUST!!!!
08fg2 is offline   Reply With Quote
Old 03-31-2012, 11:56 PM   #1458
SWP is Sexy
Member#: 302389
2011 WRX
Got a slightly noob technical question.
Started up the car leaving work tonight and had a bigass cloud come out the exhaust. Couldn't see what color since it was dark, but any ideas? Ran just fine, revved it a little and no more smoke. Hit target boost exactly too, I dunno.
Old 04-01-2012, 12:14 AM   #1459
JordenP
Member#: 305041
2013 STOCK WRXSDN
Way too vague man... Are you completely stock? What was the the outside temp? During the day verify the color of the smoke and scent. If you are that concerned go to the dealer.
JordenP is offline   Reply With Quote
Old 04-01-2012, 12:20 AM   #1460
SWP is Sexy
Member#: 302389
2011 WRX
AP stage one, stock otherwise. Never happened before, outside was about 75-80.
Not terribly worried, but definitely curious.
Old 04-01-2012, 01:59 AM   #1461
Celery GT-5
Member#: 98210
2002 WRX SRP
probably normal condensation and what not like what comes out of all cars when they are cold
Old 04-06-2012, 10:24 PM   #1462
08fg2
Member#: 281219
2012 wrx hatchback
satin white pearl
About to pull the trigger on the bayson r front lip! How's the Fitment for those running it?
Old 04-06-2012, 10:28 PM   #1463
Andrew862
Member#: 299321
2011 WRX Hatch
Fit Is great. I added a few extra screws to make it hold very tight with no gaps at all. The quality is good and I didn't even have to warm mine up in the sun like they recommend before installing it.
Andrew862 is offline   Reply With Quote
Old 04-06-2012, 10:40 PM   #1464
chanomatik
Member#: 159474
2013 BRZ Ltd 6MT CBS
SNOSLO
You "didn't have to" or you neglected to and got away with it? haha
Old 04-07-2012, 12:27 AM   #1465
_davin
Member#: 260501
2003 miata SE
Blurple
Is it at all possible to get our keys re cut/programed? From one 2011 to another.
_davin is offline   Reply With Quote
Old 04-08-2012, 02:35 AM   #1466
11wrx_dude
Member#: 311747
2011 wrx
white
Can anyone tell me of I need a tune for equal length headers ?
11wrx_dude is offline   Reply With Quote
Old 04-08-2012, 02:58 AM   #1467
_davin
Member#: 260501
2003 miata SE
Blurple
Yeah.
Old 04-08-2012, 06:00 PM   #1468
PearlRex11
Member#: 284420
2011 WRX Sedan
Is a tune absolutely required or is it just to actually see gains? Ive heard both?
Old 04-08-2012, 11:30 PM   #1469
SWP is Sexy
Member#: 302389
2011 WRX
I would imagine you'd have a similar situation to running an aftermarket downpipe with no tune.
Alright guys I've got a problem. First off, specs. Bone stock with Cobb OTS Stage 1 93
On the way home tonight I started noticing that I could hear alot of air moving, almost like I had an intake installed. I switched my AP readout over to boost and noticed I was peaking at around 14.5, 2psi low from the target 16.5 (I'm normally spot on)
Boost kept getting lower and sound kept getting louder, any ideas? I'm thinking I've got a tube loose/off somewhere
Old 04-08-2012, 11:51 PM   #1470
k757
Member#: 274785
2014 Ford Fiesta ST
eventually you'll have nearly no boost and all "whooshing" sound. My stock WRX is at Subaru now for this. The internet tells me that the tube underneath the intercooler is loose or off completely.
k757 is offline   Reply With Quote
Old 04-08-2012, 11:59 PM   #1471
PearlRex11
Member#: 284420
2011 WRX Sedan
I've heard the same. The dealer should be able to fix it or you can get an avo I've heard some guys do that.
Old 04-09-2012, 12:05 AM   #1472
PROcede
Member#: 293500
2015 FXT Stage 2
CWP
That's exactly it! It's the throttle body hose underneath the intercooler. My car was stock and blew it partially off after a good 2nd gear pull. The stock hose sucks to be honest. You'll probably blow it off again at some point. It sounds like you have some crazy big turbo spooling right? When you push the pedal you don't really go anywhere though. Don't continue to floor it like that. Drive like a granny to the dealer when you can. They'll most likely try to remedy it and order the part for you and reschedule you to have it replaced. If you are a good DIY'er zip tie that hose after its replaced. A buddy of mine had it pop off on the track and he ended up cracking a ringland.
PROcede is offline   Reply With Quote
Old 04-09-2012, 12:13 AM   #1473
SWP is Sexy
Member#: 302389
2011 WRX
Eff, guess I'll see if I can diy it and then also get it into the dealer.
Thanks guys
Old 04-09-2012, 12:23 AM   #1474
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
After you turn the car off and check the oil cap see if there is smoke there too. Its really hard to say, unless the cloud lingered for a while, but like others have said, probably condensation from the cool/humid air.?.?
Yes, the dealer can do that for you. You have to have a subaru programmer machine....thingy.
I don't see why you would, I would recommend that you are driving on some form of EM (Cobb AP, or something)
Yeah.
Werd
You might reach higher boost levels faster, I don't remember the REAL gains in the the headers... unless you do EL headers, they are supposed to perform better at high rpms.
No, the 2 biggest things with down pipes are; 1) different WG integration (absence of a plate for WG exhaust(bellmouth or divorced)); 2) Absence of back pressure from catalytic convertor or use of a higher flowing cat.
The headers only provide better flow on the topend of the rpms (so I remember being lectured).
Sounds like your TMIC--->TB coupler is loose or the TMIC end tank popped off (common for 08-09 (IIRC) wrx's). Have you ever had any of the hoses off before?
Your car will idle very unevenly when that vacuum hose comes off. You can super glue it back on to fix it on your own (very common on the LGT's)
Louie is offline   Reply With Quote
Old 04-09-2012, 12:50 AM   #1475
SWP is Sexy
Member#: 302389
2011 WRX
Never had them off. I'm letting the car cool, gonna go pull the intercooler and see what I find.
I'm still a newb to turbo, got any tips on what to look for?
Differences of 2011 wrx motor and 2011 sti motor stpkenton Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 03-06-2012 11:03 AM
Differences of 2011 wrx motor and 2011 sti motor stpkenton Newbies & FAQs 3 05-12-2011 09:27 PM
2011 Subaru shifter fitment! All TWM Shifters still fit! TWM Performance Vendor Announcements 14 02-28-2011 03:27 PM
iPod 3g DLO Jam Jacket (clear) and Radtech 3g Indigo Podsleev 10gb/15gb agentmaxwell Private 'For Sale' Classifieds 1 05-24-2006 07:41 PM
Attn: Clayton, Ben and all others involved in the 6MT discussion. sherifx Mid West Subaru Owners Club Forum -- MWSOC 1 07-31-2002 03:00 AM
