Old 04-09-2012, 01:14 AM   #1476
PearlRex11
Member#: 284420
2011 WRX Sedan
Originally Posted by SWP is Sexy
Never had them off. I'm letting the car cool, gonna go pull the intercooler and see what I find.
I'm still a newb to turbo, got any tips on what to look for?
It's the hose with a hose clamp on the drivers side of the intercooler. Push it back on and tighten the hose clamp very tight. You may have to loosen it to adjust it before you tighten it. Doubt your endtank came apart on stage 1, you should easily be able to tell visually I would think if it did.
PearlRex11 is offline   Reply With Quote
Old 04-09-2012, 03:11 AM   #1477
SWP is Sexy
Member#: 302389
2011 WRX
I'm a stormtrooper pewpew
Think I've got it, but this thing is a bitch to tighten. Intake mani is in the way so I can only get one click per go on the ratchet for that clamp
SWP is Sexy is offline   Reply With Quote
Old 04-09-2012, 08:05 AM   #1478
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
TAKE THE RUBBER CAPS OFF BOTH ENDS OF THE THROTTLE BODY HOSE!
If you just tighten it back down, it will just come loose again. Those rubber things are just glued on each end and used for alignment. The clamping force is MUCH better after they are removed. Also, put a zip tie on the hose that goes from the top of the BPV to the back of the manifold (on the manifold nipple). It will be tough to reach. For both of these things you will probably have to move some of the wires/hard tubes connected to the back of the manifold to get access.
xluben is offline   Reply With Quote
Old 04-15-2012, 04:06 PM   #1479
PROcede
Member#: 293500
2015 FXT Stage 2
CWP
How accurate is the Cobb's dynometer on the accessport. Does it give a pretty decent number to go by or is it ridiculous high reading?
PROcede is offline   Reply With Quote
Old 04-17-2012, 02:48 PM   #1480
chanomatik
Member#: 159474
2013 BRZ Ltd 6MT CBS
SNOSLO
So I think the LGT wheels look nice and I think I can pull off the look, but I'm definitely going to need a 25mm spacer for 5x100 AND I'm going to need lowering springs.
Right now my research has me deciding between Eibach Pro Kit or Epic Engineering. Are there others I should consider? My car is going to need a bit more of a dramatic drop, over 1", but 1" might have to do for now. Is there anything out there that fits a 2011 WRX sedan that would give more than 1"?
Thanks in advance!
Old 04-17-2012, 03:32 PM   #1481
mw1484
Member#: 239546
2011 WRX TP Stg2+AEM
Spark Silver Sedan
** I got the H&R's and they ride nice for me. I actually have it on 25mm spacers right now too...
http://www.flickr.com/photos/mikelwong/ for full pics
mw1484 is offline   Reply With Quote
Old 04-17-2012, 03:47 PM   #1482
chanomatik
Member#: 159474
SNOSLO
I was just glancing at the H&R's. Nice set up! I believe the Legacy wheels are 17x7, so it's interesting to see what 17x8 looks like with 25mm spacers. How long have you been on the H&R's? It looks like 1" drop front and rear. Is there a specific part number used for 2011+ WRX or is it the same for all 3G sedans?
Old 04-17-2012, 05:09 PM   #1483
mw1484
Member#: 239546
Spark Silver Sedan
I've been on mine for a little over 6 months. With just the springs they were fine and didn't run at all. Running the spacer, they rub over bumps or when I have more than 2 (including me) people in the car. I think if you were to go a siilar route, you'd be better off with a 15mm spacer in the rear but who knows...
Part Number: 54462 for the springs, and yes, i htink they're same for all 3g.
Old 04-17-2012, 05:16 PM   #1484
chanomatik
Member#: 159474
SNOSLO
Excellent! I see that's what tirerack.com has. Decent price on shipping to Alaska. I might go this route. I had the STI 18x8.5 wheels with 25mm spacers on and never rubbed, but I don't haul around more than 2 people that often.
Thanks for the help. I'll keep researching until I collect the funds.
Old 04-29-2012, 11:10 PM   #1485
Celery GT-5
Member#: 98210
2016 Forester XT CWP
2002 WRX SRP
finally got my lazy ass around to datalogging/virtual dynoing stage 2
I think I hit the gas at a lower rpm for the stage 1 dyno but the gains look pretty solid once SAE corrected(the stage 1 dyno was done in 23 degree weather and it was close to 60 today) so here are the graphs corrected and uncorrected..lol
red line is stage 2
looks like about 25-30 whp and lb ft at ~5000 rpms
with dynojet correction I can almost claim 300whp..297/320 lawl
Celery GT-5 is offline   Reply With Quote
Old 04-30-2012, 12:26 PM   #1486
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Those gains look pretty good. If you use your SAE numbers the Dynojet should read around 280WHP. That seems reasonable.
Old 04-30-2012, 01:26 PM   #1487
Celery GT-5
Member#: 98210
2002 WRX SRP
yeah dynojet i think was 297/320 uncorrected and around 280 corrected
in other news I think my struts are unhappy with their springs
Old 04-30-2012, 05:56 PM   #1488
mw1484
Member#: 239546
Spark Silver Sedan
^^ same boat. Running on H&R springs right now and I'm not sure they're liking the harshness.
Old 04-30-2012, 06:30 PM   #1489
chanomatik
Member#: 159474
SNOSLO
I'm looking at the Eibach Pro Kit lowering springs, possibly, or just going with Epic Engineering. Still on the fence. Almost 31k miles, I think lowering springs will just stick a fork in my struts. hahaha
Old 04-30-2012, 10:49 PM   #1490
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
I've been on Epic springs for about 6,000 miles and no problems so far. I didn't install them myself though but took them to a shop that didn't use spring compressors to install them. I hear the main reason for blow shocks is the use of spring compressors when people install their own lowering springs.
xabre1200 is offline   Reply With Quote
Old 04-30-2012, 11:22 PM   #1491
PROcede
Member#: 293500
2015 FXT Stage 2
CWP
Hey guys I could just be paranoid but when you are doing the ringland check with the oil filler cap are you supposed I have huffs of air coming out of the cap or is it only if you have real visible white smoke coming out? I have huffs of air but no smoke. My car is running fine no issues but i want to start checking it after driving hard or long freeway drives.
Old 05-01-2012, 12:04 AM   #1492
_davin
Member#: 260501
2003 miata SE
Blurple
Enlighten me of this check you speak of.
_davin is offline   Reply With Quote
Old 05-01-2012, 12:36 AM   #1493
PROcede
Member#: 293500
2015 FXT Stage 2
CWP
When your car is running you remove the oil filler cap and see if smoke comes out. If it does it's likely you have a cracked ringland. What isn't clear is if huffs of air is okay as long as white smoke doesn't come out.
Old 05-01-2012, 12:43 AM   #1494
_davin
Member#: 260501
2003 miata SE
Blurple
Well if your cap is off and your engine in compressing... air should come out, right?
Old 05-01-2012, 02:32 AM   #1495
jege41
Member#: 280754
Hi
What you speak of has long been called blow-by, and is not just only a Subaru test. The least amount of air pushing outward is best, and new cars almost have a vacuum of air being sucked in, and that is good.
jege41 is offline   Reply With Quote
Old 05-01-2012, 02:39 AM   #1496
jege41
Member#: 280754
If you have bad rings you will be burning oil, and cold starts will have a lots of blue smoke, also burnt valves can cause similar symptoms.
Old 05-01-2012, 05:26 PM   #1497
iambigsteveo
Member#: 311459
2011 5Door WRX
World Rally Blue
Any of you guys experience a slight hood vibration when driving at speed? Speeds of 85+ I noticed my hood shakes a little, mostly around the scoop.
iambigsteveo is offline   Reply With Quote
Old 05-01-2012, 06:43 PM   #1498
_davin
Member#: 260501
2003 miata SE
Blurple
When I drove my car up last time I noticed the scoop insert piece would vibrate while I was cruising, probably around 80.
Old 05-04-2012, 03:28 AM   #1499
Celery GT-5
Member#: 98210
2002 WRX SRP
yes
try wrapping the hood latch with electrical tape or something, I think that might help
what do spring compressors have to do with anything? some springs are impossible to get on w/o compressing. I can't remember if I used them or not with my epics. I think I've had my springs on for about a year now, not sure the mileage but the roads around here are really ****ty so that can't be helping. They just seem a little more harsh although maybe its just from switching 215/55s to 235/45s for summer. I think they could benefit from some better dampening.
Old 05-04-2012, 11:53 AM   #1500
PearlRex11
Member#: 284420
2011 WRX Sedan
Yeah if those springs lose any integrity from using a spring compressor I would ask my money back and buy something else. Compressors shouldn't make any difference on even a semi decent spring.
Differences of 2011 wrx motor and 2011 sti motor stpkenton Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 03-06-2012 11:03 AM
Differences of 2011 wrx motor and 2011 sti motor stpkenton Newbies & FAQs 3 05-12-2011 09:27 PM
2011 Subaru shifter fitment! All TWM Shifters still fit! TWM Performance Vendor Announcements 14 02-28-2011 03:27 PM
iPod 3g DLO Jam Jacket (clear) and Radtech 3g Indigo Podsleev 10gb/15gb agentmaxwell Private 'For Sale' Classifieds 1 05-24-2006 07:41 PM
Attn: Clayton, Ben and all others involved in the 6MT discussion. sherifx Mid West Subaru Owners Club Forum -- MWSOC 1 07-31-2002 03:00 AM
