#1501 |
Member#: 159474
AKIC
Vehicle:2013 BRZ Ltd 6MT CBS Counter-steer like a boss |
I haven't used compressors in years, but don't they just retain the spring's compression to safely remove them from the shocks, then as you slowly loosen them they decompress? Unless one is compressing them too tightly with the compressors (which is incorrect, from what I recall) then I don't see how it would make a difference.
Plus I wouldn't want to pay a shop to deal with that anyways since it's so much fun to work on yourself. A fairly easy and educational install meet for newbies to Subies (or "noobs to Scoobs").
#1502 |
Member#: 98210
Vehicle:2011 SWP WRX 5 Door TorquedPerformance Stage2 |
people that have shops do everything end up spending like double the price on everything, may as well just start of with a better car if you are gonna waste all that money on stuff you didn't even install yourself
#1503 |
Member#: 159474
AKIC
How far does it go, though? I don't ever do my own oil changes because I don't care to dispose of the oil and I never have anywhere dry or even to do them.
#1504 |
Member#: 166490
Vehicle:2011 WRX WRB |
My rule of thumb is that I'll do my own work on anything that 1) I currently have the tools for or only need less than $150 of new tools to complete it. 2) Can have the car back in operation the same day. 3)Feel comfortable that if I F*$# something up I have a way to take care of it the same day. Otherwise I don't mess with it.
#1505 |
Member#: 98210
yeah I'm not saying you have to do everything or anything, I just think paying for mods twice so you don't have to install them ruins the fun..lol.
I wouldn't try to rebuild a tranny or something complex like that by myself you are right about changing oil I don't like putting used oil in my car so I just let it sit for years in the garage..lol |
#1506 |
Member#: 261730
Vehicle:2011 WRX hatch WRB |
Correct, xabre is mistaken about the common issue. From what I know, the issue with doing this install yourself is spinning the strut main shaft while trying to manipulate that nut on top. You aren't supposed to spin the shaft too much, something to do with some seals down inside. I think our struts have a socket head interface on that shaft that should allow you to keep it still while you remove or tighten down that nut.
#1507 | |
Member#: 284420
SWIC
Vehicle:2011 WRX Sedan SWP |
#1508 | |
Member#: 43393
Vehicle:2011 STi WRB |
#1509 |
Member#: 260501
AKIC
Vehicle:2011 WRX 5dr SWP Ltd |
I'm having trouble finding any direct comparisons, does anyone know the difference in quality between the bayson r and JNA lips?
#1510 |
Member#: 259591
Vehicle:2011 WRX sedan WR Blue |
Pretty sure they're the same. I've been scraping my BaysonR lip everyday for 2 months and it's holding up just fine.
#1511 | |||
Member#: 261612
Vehicle:2011 WRX 5 Door NF Performance Stage 1 |
A little bit of oil (droplets/vapor) coming out is normal. Smoke coming out is bad. Check compression. Quote:
#1512 |
Member#: 98210
yeah, I will say that driving around on long island(as opposed to upstate NY) the dampening doesn't seem as bad because the roads aren't nearly as torn up...still some konis would be nice
also car feels a little faster at the lower altitude..lol |
#1513 |
Member#: 281219
Vehicle:2012 wrx hatchback satin white pearl |
Curious, any of you have a soft ticking noise coming from under the car? Mostly heard at lower speeds and 1-2 gears 3rd is very faint. Sounds like an exhaust leak but I checked all gaskets/bolts and nothing. Appeared after going stage 2... Around 6k miles. I just hit 10. Been ignoring it but does get annoying. Best heard when driving beside tall curbs, buildings and objects the make the sounds bounce off and more clear...
#1514 |
Member#: 281219
After jacking up the car and looking for things, it seems like the noise is coming from the transmission. Maybe the throw out bearing?
#1515 |
Member#: 159474
AKIC
#1516 |
Member#: 281219
I just hit 10,000 Ive noticed the problem at about 6,000.
#1517 |
Member#: 280754
#1518 |
Member#: 281219
Noise Is present when car is standing still while giving some throttle.
#1519 |
Member#: 293547
What are you guys running for Tranny fluid and brake fluid for the 2011?
Looking for a small upgrade over stock. Its a DD car that wont see a track. |
#1520 |
Member#: 159474
AKIC
#1521 |
Member#: 98210
So my car is having intermittent loopy idle. Any ideas? I am a bit low on gas I guess idk weird
#1522 |
Member#: 314833
TXIC
Vehicle:2012 Impreza 2.0i |
#1523 |
Member#: 43393
sounds like a vacuum leak.
#1524 |
Member#: 98210
wouldn't that show up on the boost gauge and not go away on its own?
#1525 | |
Member#: 166490
In any of those scenarios, it's a normal boxer quirk. Happened in all 3 of my Subi's. If it's something different than that, please elaborate. Curious. |
| Thread Tools | |
| Display Modes | |
| Differences of 2011 wrx motor and 2011 sti motor | stpkenton | Factory 2.5L Turbo Powertrain | 3 | 03-06-2012 11:03 AM |
| Differences of 2011 wrx motor and 2011 sti motor | stpkenton | Newbies & FAQs | 3 | 05-12-2011 09:27 PM |
| 2011 Subaru shifter fitment! All TWM Shifters still fit! | TWM Performance | Vendor Announcements | 14 | 02-28-2011 03:27 PM |
| iPod 3g DLO Jam Jacket (clear) and Radtech 3g Indigo Podsleev 10gb/15gb | agentmaxwell | Private 'For Sale' Classifieds | 1 | 05-24-2006 07:41 PM |
| Attn: Clayton, Ben and all others involved in the 6MT discussion. | sherifx | Mid West Subaru Owners Club Forum -- MWSOC | 1 | 07-31-2002 03:00 AM |
