Old 05-24-2012, 10:14 AM   #1576
PearlRex11
Member#: 284420
2011 WRX Sedan
Haven't installed mine yet but I believe these were designed to match closely to the subaru dash color specifically. Shouldn't be closer than anything else you can buy.
http://forums.nasioc.com/forums/show....php?t=2232491
PearlRex11 is offline   Reply With Quote
Old 05-24-2012, 10:37 AM   #1577
xluben
Member#: 261612
2002 WRX - 800HP
9.5s @ 150mph
Originally Posted by _davin View Post
How well does the color match with the dash?
The SMY Cluster matches the dash perfectly:
The ProSport Gauges look pretty good, but they don't match as well as Defi.
Originally Posted by mw1484 View Post
^ ProSport Halo gauges w/ SMY cluster pod... Couldn't be happier. Super discreet, nice options, and get the job done reliably.
xluben is offline   Reply With Quote
Old 05-24-2012, 02:01 PM   #1578
ciege125
Member#: 306475
2012 STI Sedan
Which two gauges are these? I imagine one is boost, and the other....?
ciege125 is offline   Reply With Quote
Old 05-24-2012, 02:58 PM   #1579
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
Most common are egt and boost. However, I think a boost gauge is about as usefull as an ex wife after you establish that your car is hitting target boost. Use an AP or tatrix cable and do some data logging to make sure you are hitting target boost occasionally.
Louie is offline   Reply With Quote
Old 05-24-2012, 03:57 PM   #1580
xluben
Member#: 261612
2002 WRX - 800HP
9.5s @ 150mph
I think the boost gauge is the #1 most important gauge. It can help find many issues. Often it's the vacuum readings that can point to problems. But if you have a logging method (Tactrix or AP) and religiously pull logs, then you may not need it. I can log, but I still find it 100x more convenient to have a boost gauge. The second most common (and the second gauge I got) is the oil pressure. This one is more debated. There are plenty of good options for a second gauge.
Old 05-24-2012, 04:09 PM   #1581
mw1484
Member#: 239546
2011 WRX TP Stg2+AEM
Spark Silver Sedan
They're the ProSport Halo's :
Boost:
Amazon.com: Prosport Gauges Halo Series Boost Gauge: AutomotiveAmazon.com: Prosport Gauges Halo Series Boost Gauge: Automotive
Oil Pressure:
Amazon.com: Prosport Gauges Halo Series Oil Pressure Gauge: AutomotiveAmazon.com: Prosport Gauges Halo Series Oil Pressure Gauge: Automotive
Correct, Boost and the other is Oil Pressure as Ben mentioned.
mw1484 is offline   Reply With Quote
Old 05-24-2012, 04:45 PM   #1582
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
I agree that you can find hidden problems with a boost/vac gauge... There are typically other problems associated with vac/boost leaks like funky idle. Once you've established that target boost... You really shpuld be watching the road and not your boost level inbetween shifts. As far as the debate on oil pressure. We have high pressure oil systems... The oil plume and smoke will tell you that there is a problem 1/100th of a sec before your OEM light comes on. If you are going to monitor the oil, monitor the temp... That will let you know more about oil breaking down from heat and other engine lubricated issues.
just my experience, by no means a good opinion.
Old 05-24-2012, 06:59 PM   #1583
iambigsteveo
Member#: 311459
2011 5Door WRX
World Rally Blue
I'm looking to put wheel spacers on but don't want to roll the fenders. Stock wheels, any idea the widest spacers I can go without rolling the fenders?
iambigsteveo is offline   Reply With Quote
Old 05-24-2012, 07:22 PM   #1584
ciege125
Member#: 306475
2012 STI Sedan
Boost: Amazon.com: Prosport Gauges Halo Series Boost Gauge: Automotive
Oil Pressure: Amazon.com: Prosport Gauges Halo Series Oil Pressure Gauge: Automotive
Im about to pull the trigger on the prosport boost gauge for the time being. Does it come with everything you need to mount it up? pod and what not
Old 05-24-2012, 09:14 PM   #1585
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
Save your money for other things. Why do you want wheel spacers? To clear brembos?
xabre1200 is offline   Reply With Quote
Old 05-24-2012, 11:31 PM   #1586
xluben
Member#: 261612
2002 WRX - 800HP
9.5s @ 150mph
I ran 25mm spacers and didn't rub, but the guy I sold them to rubbed in the rear. Both were 2011 WRX hatch's with stock wheels/tires and stock suspension. I guess it's hit or miss. I would just roll the fenders in the rear.
Old 05-25-2012, 03:46 AM   #1587
chanomatik
Member#: 159474
2013 BRZ Ltd 6MT CBS
SNOSLO
I used 25mm spacer adapters for 2011 STI wheels and didn't rub. Those were 18x8.5 +55 on stock STI tires and stock WRX suspension. They were herrafrush.
Old 05-25-2012, 10:31 AM   #1588
iambigsteveo
Member#: 311459
2011 5Door WRX
World Rally Blue
Quotes
Not looking to clear anything. I just like the look of the wheels flush with the fenders, more flush than with the stock setup that is.
I wonder why
Do you have any pics?
Old 05-25-2012, 02:35 PM   #1589
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
What about a set of lowering springs? They don't cost much more than wheel spacers (probably the same amount of $ if you pick up a used set) and they'll do a lot to improve the look and feel of your car. More than wheel spacers.
Old 05-25-2012, 03:17 PM   #1590
PearlRex11
Member#: 284420
2011 WRX Sedan
I like the defi's but I think they are overpriced imo and they don't have the white needle. Prosports can store your peak boost and set warnings for half the cost and the amber color is pretty close to stock color.
Old 05-25-2012, 03:21 PM   #1591
PearlRex11
Member#: 284420
2011 WRX Sedan
Got oil pressure and boost myself. Stock dummy light turns on around 2psi so by the time you see it you will have damage to the motor. Oil pressure is very important to me. Boost is important to me because I have the stock tmic, could come apart if I boost more than 18psi from what I've heard.
Old 05-25-2012, 03:40 PM   #1592
08fg2
Member#: 281219
2012 wrx hatchback
satin white pearl
Waiting patiently on my AEM intake. This day is a drag!!!!
08fg2 is offline   Reply With Quote
Old 05-27-2012, 11:30 AM   #1593
PROcede
Member#: 293500
2015 FXT Stage 2
CWP
Anyone with a 2012 WRB want to trade headlights? I kinda like the way WRB looks with the chrome headlights better then my black housing headlights.
PROcede is offline   Reply With Quote
Old 05-27-2012, 11:43 AM   #1594
SWP is Sexy
Member#: 302389
2011 WRX
I'm a stormtrooper pewpew
The paint color shouldn't make a difference in the headlights, you could swap with any color 2011
SWP is Sexy is online now   Reply With Quote
Old 05-27-2012, 11:48 AM   #1595
PROcede
Member#: 293500
2015 FXT Stage 2
CWP
Doh! Lol. Obviously it's still early for me. But yeah also lights must be in perfect condition! Mine have had clear bra on them since day 2. lmk pm me!
Old 05-30-2012, 11:55 PM   #1596
ciege125
Member#: 306475
2012 STI Sedan
Anybody know anything about the SPT vortex generator that was supposed to come out for the sedans?
In the subaru parts catalog it said, available first quarter 2012. But i havent seen or heard anything about it.....?
Old 05-31-2012, 01:12 PM   #1597
Celery GT-5
Member#: 98210
2016 Forester XT
CWP
yeah but then a year later your car rides like **** and you have to take them back out and get new shocks..fail
Celery GT-5 is offline   Reply With Quote
Old 05-31-2012, 02:11 PM   #1598
chanomatik
Member#: 159474
SNOSLO
I have pics everywhere, but I'll try to show off wheel-specific ones for the sake of the conversation. I tried showing as many variations of lighting and angles as I had available. I don't have the wheels anymore.
Old 06-02-2012, 04:44 PM   #1599
PearlRex11
Member#: 284420
2011 WRX Sedan
Hoping to get my car back today..... Maybe tomorrow. Car accident in front of my house and some parts from one of the cars hit mine. Damaged front bumper, drivers front Fender, hood. Getting the front plate mount shaved while it's in there though!
Old 06-02-2012, 06:01 PM   #1600
mw1484
Member#: 239546
Spark Silver Sedan
^^ post picsof the front after, is love to get the plate shaved too
Differences of 2011 wrx motor and 2011 sti motor stpkenton Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 03-06-2012 12:03 PM
Differences of 2011 wrx motor and 2011 sti motor stpkenton Newbies & FAQs 3 05-12-2011 10:27 PM
2011 Subaru shifter fitment! All TWM Shifters still fit! TWM Performance Vendor Announcements 14 02-28-2011 04:27 PM
iPod 3g DLO Jam Jacket (clear) and Radtech 3g Indigo Podsleev 10gb/15gb agentmaxwell Private 'For Sale' Classifieds 1 05-24-2006 08:41 PM
Attn: Clayton, Ben and all others involved in the 6MT discussion. sherifx Mid West Subaru Owners Club Forum -- MWSOC 1 07-31-2002 04:00 AM
