Welcome to the North American Subaru Impreza Owners Club Tuesday August 4, 2015
Old 05-20-2011, 11:29 AM   #1
Slim1721
Member#: 274761
Default Clicking noise, goes away when i brake
Got a clicking noise from the right front, 02 wrx. its a click...click...click...click...click...click, speeds up when i speed up, and it happens pretty much no matter if im turning or in a strait line, but doesnt happen all the time. It goes away EVERY time I hit the brakes, you guys have any ideas?
Slim1721 is offline   Reply With Quote
Old 05-20-2011, 12:22 PM   #2
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD) / 87 GL
sounds like you're missing a brake pad shim. I've seen this once before on one of my other cars.
the brake pad is moving back and forth making it click in the caliper bracket. But when you apply the brakes, it will stop the pad from moving. These are not the shims that go between the pad and the pistons. I'm taking about the little tangs around the side.
Try checking the pads for movement.
Zefy is online now   Reply With Quote
Old 05-20-2011, 01:23 PM   #3
Slim1721
Member#: 274761
hmmm, i took the brake off, it looks like theres NO shim between anything
Old 05-20-2011, 01:25 PM   #4
Slim1721
Member#: 274761
are you talking about the little tangs in the top and bottom of the bracket? those are there, it has tabs that look like they should be folded onto the pad, but they are straitened out, not sure if they should be folded up or not
Old 05-20-2011, 04:18 PM   #5
LIChuck
Member#: 266122
2007 WRX Limited
UGM
Jack the car up and spin the tire. You should be able to locate the source, possibly a wheel bearing. Find it and fix it before you have a catastrophic failure.
LIChuck is offline   Reply With Quote
Clutch noise at idle, but goes away when clutch is disengaged.....please advise. hoodwinked Transmission (AT/MT) & Driveline 12 06-17-2013 06:38 PM
Wheels squeak when I drive, goes away when I press brake nitr0x99 Brakes, Steering & Suspension 11 12-13-2010 12:34 AM
03 Front Wheel rattle, goes away when braking blitzpb Service & Maintenance 4 12-29-2008 10:37 AM
Clunk/Grind... that goes away when braking? twizzstyle Transmission (AT/MT) & Driveline 3 10-02-2008 11:49 AM
Unknown Squeal when NOT braking and goes away when lightly braked Gorge Brakes, Steering & Suspension 1 04-05-2008 02:57 AM
