Old 05-23-2011, 01:44 PM   #1
WRX_hatch
Member#: 261834
2010 WRX
Darkness
Default Tactrix 2 and Tactrix 3-port BCS
Thinking of ordering OpenPort and BCS. Anyone have input regarding their BCS? It's alleged to be PnP with Subies...
Last edited by WRX_hatch; 05-23-2011 at 01:48 PM. Reason: looking for minor boost increase- would money be better spent on the O2 sensor?
WRX_hatch is offline   Reply With Quote
Old 05-23-2011, 03:08 PM   #2
fenix-silver
Member#: 231700
2004 WRX Wagon
Buy a MAC valve (part number 35A-AAA-DDBA-1BA) and save money for your tune. It cost me about $35 for the valve, a couple fittings, and some vacuum line. I just spliced into the existing BCS harness and soldered on the leads from the MAC valve. Otherwise you'll need to find a pigtail that works with the BCS harness. I didn't feel like spending the time or money tracking one down. Used double sided tape to stick it to the existing BCS bracket and put a zip tie around it for security. The MAC valve is the same one used by a variety of performance parts manufacturers. It is working great for me so far on the e-tune that I'm getting right now. REMEMBER: YOU WILL NEED A TUNE! Otherwise you'll overboost since the wastegate duty cycle must be lowered quite a bit for a 3 port.
Also, update your profile with your car details so we know what you've got.
fenix-silver is offline   Reply With Quote
Old 05-23-2011, 04:05 PM   #3
WRX_hatch
Member#: 261834
2010 WRX
Darkness
The plus for the Tactrix BCS is that it comes with the Subaru adapter harness. It's the same solenoid sold by Prodrive apparently.
Old 05-23-2011, 06:04 PM   #4
boxer fanatic
Member#: 255153
'02 Corn fed bugeye
'11 forester 2.5X SWP
I say MAC valve as well. Very cheap and reliable.
boxer fanatic is offline   Reply With Quote
Old 05-23-2011, 10:15 PM   #5
WRX_hatch
Member#: 261834
2010 WRX
Darkness
The order is in for the Openport 2. I have to hold off on other stuff. Money doesn't grow on trees anymore. Well, it sort of does, just not in my yard...
Old 05-27-2011, 04:19 PM   #6
eminehart
Member#: 11205
2015 WRX
You can get the connectors here for an oem look. I don't worry much about shipping cost be cause I order a bunch at a time and use them to make pigtails for Bosch Injectors. They are cheap but shipping is high
http://www.connectorsfast.com/store/...rs&SubCatID=61
Nippon Denso Style Male Connectors (ND-M2)
I also found them here for a cheaper shipping price.
http://www.injectorconnectors.com/Connector_Store.html
eminehart is offline   Reply With Quote
Old 05-27-2011, 05:09 PM   #7
WRX_hatch
Member#: 261834
2010 WRX
Darkness
Checked that link, thank you. The OP2.0 showed up earlier today. Just read my ROM and it's not recognized so I'm not sure where to start looking for a start point. Not surprised that a newer model wasn't found. I WAS surprised that it found the OP and ECU and read it the first time. (Gotta be lucky once/day.)
Last edited by WRX_hatch; 05-27-2011 at 05:10 PM. Reason: I am supposed to use the 07+ CAN Subaru option for reading, correct?
Old 05-29-2011, 04:22 PM   #8
WRX_hatch
Member#: 261834
2010 WRX
Darkness
EcuFlash works better when you have metadata where it belongs... There are valid maps in my ROM now. I wish I ordered the O2 sensor with OP2.0
Old 01-11-2013, 12:05 AM   #9
mgreen3
Member#: 320656
2002 WRX wagon
this is going to sound stupid but do any of you know if the openport 2.0 works with an 02 ej205
mgreen3 is offline   Reply With Quote
Old 01-11-2013, 12:46 AM   #10
DZXN
Member#: 306186
2002 Subaru WRX
The tactrix openport 2.0 works with the 02+ wrx's very well. Spend the couple extra bucks to get the jumper, saves your paper clip/spare wire stash.
DZXN is offline   Reply With Quote
Old 01-11-2013, 01:32 AM   #11
mgreen3
Member#: 320656
2002 WRX wagon
ok thanks for the info and advice man.
FS : EPTX: Tsudo UP, Tactrix 3 port BCS, Stock 07 STi TBE Black07STiGuy Engine/Power/Exhaust 37 05-24-2011 04:46 PM
FS : EPTX: Tsudo UP, Tactrix 3 port BCS, Stock 07 STi TBE Black07STiGuy TXIC Private Classifieds 28 05-23-2011 06:47 PM
oem bcs and grimspeed 3 port bcs scooby_wooby Engine/Power/Exhaust 7 10-14-2009 02:43 PM
BCS , 2 way or 3 way iam lost . vulpina Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 08-18-2007 09:05 PM
Buschur Dyno Tuning Special Prices - Feb 2 and Feb 3 Dyno Flash MWSOC Vendor Classifieds 9 01-29-2007 06:24 PM
