Welcome to the North American Subaru Impreza Owners Club Sunday April 26, 2015
Old 07-22-2002, 05:06 PM   #1
WhiteLightning
Member#: 21763
2005 MiniCooperS&D2
truck/car Dark Silver
Question How to launch an MT WRX?
I ask this question coming from a 95 GSX with an aftermarket clutch that was easy to launch...rev and drop...But the WRX is new so I figured I'd ask before breaking something....so whats the proper method to get that 5.8 0-60mph and the 14.3 1/4et?
tia
Nik
WhiteLightning is offline   Reply With Quote
Old 07-22-2002, 07:38 PM   #2
THEMAN
Member#: 16816
2005 STizzle
CGM
Bring the rpm's to 4.5k and let the clutch out really slow untill you feel the friction point. Then dump the clutch and floor it. You can even bring the rpm's to 5k for an even faster launch. You should get a turbo timer to find out what you are really running 0-60 in, because I went 5.6 in my car with only a BOV.
THEMAN is offline   Reply With Quote
Old 07-23-2002, 12:46 AM   #3
WhiteLightning
Member#: 21763
2005 MiniCooperS&D2
Wink
Thaaank you...this info was most helpful.
Nik
Old 07-23-2002, 06:32 PM   #4
TurboWRXImpreza
Member#: 9911
2008 STi
Lightning Red
IMO, you should never dump the clutch. I'm sorry to say that I found out the hard way. I'm already on my 2nd tranny. I dumped the clutch too much.
Slipping the clutch IMO, is better because at the same time it allows you build boost and you reach full boost much faster than dropping it....that is...if you do it right.
PRACTICE
Raymond
TurboWRXImpreza is offline   Reply With Quote
Old 07-24-2002, 09:02 PM   #5
Ian02WRX
Member#: 20899
2002 WRX sedan
I've always cringed when people said "dump" the clutch. To me that means side-step the pedal and MAN does that put a lot of STRAIN on the drivetrain. I've had many hundreds of launches in my 92 and 97GSX's without any tranny problems, but I quickly slip the clutch. My WRX is a little new for launches (300 miles), but when I do, I'm slippin'.
I'm surprised no one else asked this of "THEMAN"
You should get a turbo timer to find out what you are really running 0-60 in...
There's a turbo timer that measures 0-60MPH times? My HKS turbo timer (97GSX) only let's the engine run for a set period of time after the ignition is shut-off. Sorry, just sounded kind of funny.
Ian02WRX is offline   Reply With Quote
Old 07-24-2002, 11:30 PM   #6
Diversion
Member#: 18651
2013 Civic Si Sedan
PMM
I pull consistent 1.9 60' times with a 5800ish RPM cluch drop at the track. No burnt clutch smell!
Jay
Diversion is offline   Reply With Quote
Old 07-25-2002, 02:53 AM   #7
wrxmd
Member#: 20932
blue
the HKS type 1 TT will do 1/4 mile times
wrxmd is offline   Reply With Quote
Old 07-25-2002, 06:52 AM   #8
Ian02WRX
Member#: 20899
2002 WRX sedan
Damn, I stand corrected, found this on the Internet: "Blitz Multi Speed Turbo Timer, which is an advanced version of the FATT, which includes features such as 0 to 60 timing and quarter mile". Crazy convergence. Still sounds funny, kind of like "I'm going to turn on my TV and do my taxes..." which I suppose you could do with WebTV or something.
And 5800 RPM clutch drops, ouch! At the Diamond Star Shootout (DSM's--Eclipse/Talon Drag Racing event) a couple years ago, there were some really fast 3000GT's and I could here them on a stutter box (bababababababa) at the line and later asked someone if the guy had a modified ECU (like www.tmo.com). His friend said he was bouncing off the 7000RPM rev limiter at the line! Pulling low 1.6 60' times...but I later saw him at the Econolodge with a hole in his tranny...
Clutch drops still make me quiver. In five years of owning DSM's and being around them I've learned that something has to give, either the clutch slips or the tires spin. At my local tracks, between the traction compound they spray and the cars with slicks leaving rubber on the launch pad, it always takes some work to spin the tires, even in low 12 second DSM's. My opinion is still that it's safer to slip the clutch a little as it is released, rather than side-stepping it. I pull low 1.7 and an occassional 1.6 60' time with an ACT2600 and still have 35k miles and over 200 launches on that clutch.
Old 07-25-2002, 11:41 AM   #9
n20x3whitewrx
Member#: 21511
13.0 @104mph
with massive wheels spin!
Jay
not bad i also found that method to work i have very few mods and i slip the clutch @5200 rpms and reach a1.766 60 ft and get a 13.0 @ 101mph. but when going trhu the traps i smell clutch. but better the clutch than trans............
n20x3whitewrx is offline   Reply With Quote
Old 07-25-2002, 11:54 AM   #10
NotoriousWRX
Member#: 9026
I think that some people might be misunderstanding the slip and dump description. It's not a dump per se, but more of a slip, then once you get rolling, dump (very quick slip) while simultaneously flooring the gas. It takes some practice to get good at it, but I think that everyone agrees that it's the safest way to get a good launch.
I use this method and now I consistently manage to get low 1.8s.
NotoriousWRX is offline   Reply With Quote
Old 07-25-2002, 10:54 PM   #11
austenf740
Member#: 21519
02 WRB WRX
98 RS
ok i am going to try to get this straight. You rev it to 4.5 then slowly take down the clutch until you feel the friction point. Then you take it out smoothly while giving it plenty of gas. sometimes i drive and i can feel the car pull harder when the clutch is not all the way down like when taking off it just pulls.
austenf740 is offline   Reply With Quote
Old 07-26-2002, 05:26 PM   #12
Ian02WRX
Member#: 20899
2002 WRX sedan
At this point, it reads like everyone is talking about the same thing, just describing it differently. To me, you want to let it slip a little (so you don't grenade your tranny) then let it out the rest of the way quickly (so that you don't fill your car with burned clutch stench).
I have a video on my website that lets you hear the launch and you can kind of tell it's a slip and not a total dump--more gradual, less bang. http://www.gotboost.org/My97GSX.htm
-Ian
02WRX
how to launch an 07STI weasel936 Newbies & FAQs 26 12-27-2007 12:56 AM
How to Launch in a wrx RL-N-AH Newbies & FAQs 21 02-20-2006 01:10 AM
How to launch an 4EAT WRX off the line RedSuns Transmission (AT/MT) & Driveline 21 10-18-2004 12:13 PM
How to launch an AWD wrxtony Proven Power Bragging 26 09-17-2004 07:01 PM
How to Launch an STi (Video) renichms General Community 12 01-16-2004 03:00 PM
