![]() Brakes & Suspension Forum sponsored by The Tire Rack |
#1 |
Member#: 453
Vehicle:2013 VT |
I recently replaced my 205/50/16 RE-92s with some 215/45/17 S-03s on my 99 RS and i noticed that the front camber looked out of balance, comparing my L to my R tires. My R front tire looked like it had too much positive camber and i also noticed some mild fender rubbing on the R front as well as my car pulling to the right when i cruised on the freeways above 50 mph.
I took it ino the Subaru dealership for a MAF sensor recall and asked them to do a realignment as well. Basically they said my alignment was normal, within factory specs and that the reason for my car pulling to the R was a tire defect. Now it sounds like BS to me and here are the alignment specs measured: L front R front Camber -0.10 + 0.03 Caster +3.18 + 2.30 Toe -0.03 - 0.02 and my rear settings too: L rear R rear Camber -1.17 - 0.51 Toe +0.09 + 0.02 Now these numbers do fall within the factory ranges, but i'm wondering if these differences should be really tolerated, especially if i do regular autocrossing. Plus i don't quite buy the whole 'dfective' tire thing either. Is the Subaru tech right or full of BS? Ed
#2 |
Member#: 15618
International
Don't you just love the way the dealership seems to exist just to piss off their customers. Hey dealers, it's us customers that keep you SOBs in business. The car is a relatively high performance machine that is designed to be driven hard and therefore should be evenly aligned.
It is totally unacceptable for a dealer to turn around and say that a car that is not correctly aligned is OK and then blame your problem on the tires. I don't care if the figures fall within specs - they should at least be equal for each axle - then you can argue that because the figures fall within specs etc. I suggest a trip to the place that sold/installed your tires and have them check the tires - you may have a bad one. One other thing, while you're there have an alignment done and add about -1 degree of camber to the front and the back. |
#3 |
Member#: 453
Vehicle:2013 VT |
Being a dealership service center, i don't think these idiots will choose to mess with my suspension beyond factory numbers. I am going to find a performance alignment shop and have them redo it. *sigh* what a waste of $80
Ed |
#4 |
Member#: 453
Vehicle:2013 VT |
bump, anyone else?
#5 |
Member#: 6598
Vehicle:2012 Mazdaspeed3 Crystal White Pearl |
Ed,
What dealership did you take it to? Speedway or Tom Wood? |
#6 |
Member#: 453
Vehicle:2013 VT |
It was Tom Wood
Ed |
#7 |
Member#: 12959
Vehicle:2008 Scion xB White |
Just call around different alignment shops and see which ones will set your alignment up to the numbers you want or close to, since all cars seem to only go to a certain number.
-Joe |
#8 |
Member#: 453
Vehicle:2013 VT |
Yeah i've already made an appointment to go to a custom alignment shop this week
![]() Ed |
#9 |
Member#: 10784
Vehicle:2002 WRX Platinum Silver Metallic |
Ed, sorry to hear about your dealership problems. Doesn't surprise me though. I doubt your tires have any issues. Did you get them through TireRack?
I'm schedule for an alignment on Monday. I'll be installing my new coilovers this weekend. My alignment will be as follows: L Front R Front Camber: -1.5 -1.5 Caster: 3.6 3.6 (factory specs) Toe: 0 0 L Rear R Rear Camber: -1.5 -1.5 (factory specs) Toe: 0 0 I plan on using a tire pyrometer to find out the best camber setting. Cobb suggest -1.0 on the front for aggressive street and -2.3 to - 2.8 for the track. You may want to drop Cobb and line and ask them what settings they recommend for the 2.5RS. I imagine they will be similiar if not the same. -Eric |
#10 |
Member#: 453
Vehicle:2013 VT |
I got my car realigned at this place called Matt's alignment, downtown in the city. They were very good, and pretty cheap too. $40 with a $10 off coupon i got from the phone book
![]() My current alignment settings are as follows: L front R front camber -1.1 -1.1 caster 3.0 2.0 toe -0.01 -0.01 L rear R rear camber -1.1 -0.8 toe -0.23 0.16 they unfortunately couldn't do much with my rear struts settings without adjustable camber plates, and -1.1 was the max they could do with the sti strut mount tops too, but i'm still pretty pleased with the results Ed |
| Thread Tools | |
| Display Modes | |
| Alignment Gurus Needed | 007WRX | Brakes, Steering & Suspension | 2 | 05-29-2008 03:39 PM |
| Hardware gurus, need help with med entry video card | ChosenWon | Off-Topic | 10 | 11-23-2003 08:33 PM |
| Computer Gurus - need help | scoobysport | Off-Topic | 2 | 11-12-2003 04:08 PM |
| MS Exchange gurus...need help | NYCshopper | Off-Topic | 39 | 06-19-2003 05:38 PM |
| Home audio gurus, need help on choosing speakers | trhoppe | Off-Topic | 32 | 06-05-2003 11:31 PM |
