Old 05-24-2011, 05:45 AM   #1
Rexxyou
Member#: 110816
USMC Semper Fi
GT35
Default Rexxyou's Impreza
I DID IT ALL MYSELF!
Im building a charty race car to help raise money for worthwhile causes. If you want to support me please PM me.
In between Builds so the list is'nt updated
ENGINE
WISECO 100MM FORGED PISTONS
ARP HEAD STUDS
CARRILLO PRO H RODS
COMETIC HEAD GASKET
ACL MAIN BEARINGS
ACL ROD BEARINGS
TOMIE 281 CAMS
SUPERTECH VALVE SPRINGS AND RETAINERS
SUPERTECH VALVES
TOMIE OIL BAFFLE
ATP GT3582 w/63 A/R TIAL HOTSIDE
TIAL 44MM EXTERNAL WASTEGATE (1.2 BAR)
TIAL TYPE QR 50MM BOV
TGV DELETE
TOMIE GT FMIC
TOMIE GT 4 INCH INTAKE W/ HKS FILTER
TOMIE GT UPPIPE/DOWNPIPE WITH V-BAND INTERNAL DUMP
TOMIE GT BATTERY RELOCATION KIT
TURBO XS CUSTOM OIL CATCH CANS
AEM STAND ALONE EMS
AGENCY POWER FUEL RAILS
PROSPORT TURBO MANIFOLD
SPT OIL CAP
COBB BATTERY TIE DOWN
BLITZ RADIATOR CAP
BLITZ FULL AUTO TURBO TIMER (FATT-II)
TURBO SMART BOOST SELENIOD
INVIDIA N1 RACE CBE
BOSCH ID1600's INJECTORS
EARLS TURBO OIL LINES
AEROMOTIVE 340LPH FUEL PUMP
MSD FUEL PUMP AMPLIFIER
UNORTHODOX RACING ULTRA SS PULLEY SET
KOYO RACING RADIATOR
BRAKES
TILTON 600 BOX W/ BIAS BAR
ALCON FRONT ROTORS
DBA SLOTTED REAR ROTTORS
CARBOTECH PADS
SUSPENSION
JIC MAGIC FAS DAMPERS 12/10 swift springs
WHITELINE 29MM SWAYBAR FRONT AND REAR w/ HD mounts
KARTBOY ENDLINKS
WHITELINE ALK
WHITELINE REAR DIFF BUSHINGS
WHITELINE REAR DIFF LOCKOUT BOLTS
WHITELINE STEERING RACK BUSHINGS
CUSCO LOOKING LATERAL LINKS
RPM 12PT SUBFRAME BRACE
CUSCO FRONT AND REAR STRUTBARS
DRIVETRAIN
PPG 1-4 STRAIT CUT SNYCROMESH GEARSET
PPG BILLIT TI SHIFT FORKS
QUAFE LIMITED SLIP DIFFERANTIALS
ACT PROLIGHT FLYWHEEL
CLUTCH POWER 3600LBS PRESSURE PLATE W/ 6 PUCK UNSPRUNG DISC
KARTBOY PITCHSTOP
KARTBOY SHORT SHIFT LEVER
KARTBOY TRANSMISSION CROSSMEMBER BUSHINGS
KARTBOY FRONT AND REAR SHIFTER BUSHINGS
MACH V EDITION TECHNA-FIT CLUTCH LINE
CUSCO MOTOR/TRANSMISSION MOUNTS
DRIVESHAFTSHOP DRIVESHAFT
EXTERIOR
ROTA SVN 18X10 +30 (FLAT BLACK)
SCOOPLESS 2.5i HOOD
COLOR MATCH MIRRIORS
SHAVED FRONT BUMPER
05 IMPREZA TAIL LIGHTS
STi SIDESKIRTS
SR48 LUG NUTS (BLACK)
GTSPEC HOOD STRUTS (CF)
ROYAL ENTERPRISE AIRDAM (CK)
ROYAL ENTERPRISE EXHAUST FINISHER (CK)
ROYAL ENTERPRISE FOG COVERS (CF)
HANKOOK RS3 265/35/18
OPTX LED UNDERGLOW KIT
APR GTC300 SPOILER
INTERIOR
EVO VIII SEATS
OMP HARNESS
PERSONAL 345MM WHEEL
Rexxyou is offline   Reply With Quote
Old 05-24-2011, 05:46 AM   #2
Rexxyou
Member#: 110816
USMC Semper Fi
GT35
About Me
I'm Dennis, from Fairfax Virginia. I enlisted in the Marine Corps and ended up stationed at Camp Pendleton Marine Base in San Diego, California. While in the Marines I Deployed to both Iraq, and Afghanistan. Some of you may know me already, some may not. I'm the owner of this 2006 Subaru Impreza below. I purchased this car January 7th, 2006.
2006
It all started with just a K&N drop-in the day i picked her up. Then my coilovers arrived a week later. I went with a set of Megan street coilovers. I followed that up with a TurboXS FMIC kit (the first to be fitted to a 2006), a new intake and an Accessport were also installed among other things. In October I added a new turbo, a TD06H 20G, netting 378whp/403wtq on 93. By December as you can guess my gearbox exploded.
2007
I spent the majority of 2007 busy with the Marines. When I had time, I had Andrewtech install a set of PPG gears. I added some new wheels, 17x8 rota boost, and had the front bumper shaved. I also added a set of Evo VIII Recaro seats.
2008
I spent most of 2008 deployed. When I got back I Immediately blew all my money on my car. Underglow
2009
I was deployed all of 2009, so no real progress was made. Andrewtech assembled and Installed a new engine for me. I also added a ATP stock location 35R thats externally gated, and [email protected] tuned my car netting 510whp/480wtq.
2010
I drove from Fairfax County to San Diego in February of 2010. My friend TJ and I drove non-stop and arrived 31 hours later. A few months later i destroyed another gear set this time stripping my 3rd gear. I had it fixed by a "friend" and it failed within 200 mile of the repair, smashing input and output shafts into each other and destroying the case. I ended up replacing the whole transmission and case, no parts could be reused. As soon as i repaired my transmission i shattered my clutch drag racing. (Best 1/4 mile: 10.8 @131 1.7 60ft) as soon as that was fixed i realized the rear and center diff had worn badly as well so they got replaced with cusco 2 ways. after I recovered from that, my turbo failed and I had a Local shop make a rotated turbo kit for me. Literally a week after getting this set up tuned the block decided to crack.
Old 05-24-2011, 05:46 AM   #3
Rexxyou
Member#: 110816
USMC Semper Fi
GT35
2011 sucked. dealt with a few ****ty SoCal Subaru/import shops and have come to the conclusion that all shops in the south west suck balls. i want to go back to Andrewtech . I had not so great shop build two engines for me, both died within 1000 miles from improper assembly and Timing. No refund and no warranty.
Ive recently added a new set of wheels, wrapped it a matte gray metallic with 3m 1080 vinyl wrap (if you want your car wrapped PM me). In addition Ive added a new and improved splitter. Gary at Universal Metals in Fullerton California hooked it up with a sheet (144"x80") of T6(aerospace grade aluminum) from which i cut a 74"x30" section and rounded the edges with a cut off wheel, and although this is not the prettiest method getting a CNC cut on a piece so big takes One hour for design input in the CNC and One-two hours for cutting. this option would cost 300(+400 for T6)dollars for the cut making it far more expensive than a composite carbon piece(500-600). anyways the 74"x30" was surprisingly light and extremely rigid! I attached it to my 12 point chromoly sub-frame at 6 points as well as 4 more spots (near where the impact sensor was mounted) with support rods made from aluminum flat bar. and then i used cables for the leading edge, they are cheap and strong and work great, they are attached to the body where the impact bar bolts to the body, i used billet aluminum turnbuckles with a few large washers and a forged loop on one end. I'm going to replace the cables with smaller ones and possibly add a few turnbuckles also. planning to make some more kevlar widebody parts also so cant wait for that.
2012
I moved in with my parents in Virginia to spend time with my mother who was battling stage four cancer for 20 months. I got to spent 3 great months with her before she passed March 26 2012. Since this was much earlier then we had planned Ive had alot of free time before i start school again. I'm currently about 30 days into my project and thought i would update NASIOC on my progress if there is enough interest i will document it and share but its really not my priority
Old 05-24-2011, 05:53 AM   #4
Rexxyou
Member#: 110816
USMC Semper Fi
GT35
VIDEO
Old 05-24-2011, 06:54 AM   #5
Rexxyou
Member#: 110816
USMC Semper Fi
GT35
Old 05-24-2011, 07:14 AM   #6
fourmicah
Member#: 128760
2017 STI
My old car looked very similar to this without all the money you've spent of course. Wish I'd never got rid of my 06. Love the car good luck with getting her up and running.
fourmicah is offline   Reply With Quote
Old 05-24-2011, 07:30 AM   #7
KevinK
Member#: 231813
Candy Red Mettalic
DAMN that chick is sexy!
oh...sickcarbro
KevinK is offline   Reply With Quote
Old 05-24-2011, 07:54 AM   #8
Mecka20000
Member#: 176162
MY02 Jesus Once Told
Me, "Numbers Sell"......
Story of my life. I Went through 3 trans rebuilds 3 Clutches and now 2nd major motor work done. All between 2009-2011.
An STi would have been a smarter choice for the amount of monies ive spent. and im sure for you as well.
Nice dedication though.
Mecka20000 is offline   Reply With Quote
Old 05-24-2011, 08:06 AM   #9
JDwhiteWRX
Member#: 190502
2005 VF36 WRX
any regrets not going straight to a 6 speed?
antilag vid was rad too.
JDwhiteWRX is offline   Reply With Quote
Old 05-24-2011, 08:11 AM   #10
Rex2006
Member#: 268193
2006 WRX Limited
Wow that is a sick car. I love my 06 as well
Rex2006 is offline   Reply With Quote
Old 05-24-2011, 09:53 AM   #11
Smallville04
Member#: 260235
04 WRX
Wow more pics of girl!!
Smallville04 is offline   Reply With Quote
Old 05-24-2011, 04:41 PM   #12
Rexxyou
Member#: 110816
USMC Semper Fi
GT35
perhaps.
None, i prefer the 5 speed for the big turbo setup!
thanks!
Old 05-24-2011, 05:14 PM   #13
Smallville04
Member#: 260235
04 WRX
Thank you!!
Old 05-24-2011, 05:15 PM   #14
CVR STi
Member#: 127428
anymore 2step vids ?
CVR STi is offline   Reply With Quote
Old 05-24-2011, 05:16 PM   #15
black thunder
Member#: 210047
im a scooby guru
really
photoshoot in a month k thx
black thunder is offline   Reply With Quote
Old 05-24-2011, 05:21 PM   #16
kcook
Member#: 78074
2005 STi
alan, I want a photoshoot. my car is ready
kcook is offline   Reply With Quote
Old 05-24-2011, 05:59 PM   #17
Primary Visions
Member#: 261698
2008 WRX Hatchback
daymmmmm that is fresh
Primary Visions is offline   Reply With Quote
Old 05-24-2011, 06:07 PM   #18
ThePowerOfAWD
Member#: 283649
Nice!!!
ThePowerOfAWD is offline   Reply With Quote
Old 05-24-2011, 08:54 PM   #19
Rexxyou
Member#: 110816
USMC Semper Fi
GT35
when you get sti?
Old 05-24-2011, 10:35 PM   #20
mpsti05
Member#: 86741
05 STi.. Built
twinscroll35r Love/Hate
Car looks real nice man! When you think its gonna be running again?
mpsti05 is offline   Reply With Quote
Old 05-24-2011, 11:10 PM   #21
pDubs
Member#: 149317
'95 BMW M3 (E36)
'05 Kawi ZX6R, '73 CB350F
Did you vinyl wrap it then take it off then wrap it again?
pDubs is offline   Reply With Quote
Old 05-24-2011, 11:20 PM   #22
kcook
Member#: 78074
2005 STi
Originally Posted by Rexxyou View Post
when you get sti?
november after I sold my M3
Old 05-25-2011, 01:45 AM   #23
Rexxyou
Member#: 110816
USMC Semper Fi
GT35
thanks, it is running as of a few weeks ago
yes sir
nice about time..
Old 05-25-2011, 04:20 AM   #24
Rexxyou
Member#: 110816
USMC Semper Fi
GT35
Old 05-25-2011, 09:25 AM   #25
cmiovino
Member#: 134005
2004 WRX Premium
nice license plate
FS : 2007 Impreza, Impreza WRX, Impreza WRX STi owner's manual AraSh Accessories & Misc 2 07-12-2012 02:25 PM
FS : 2007 Impreza, Impreza WRX, Impreza WRX STi owner's manual AraSh SWIC Private Classifieds 5 12-31-2010 12:36 PM
The 2006 Impreza/Impreza WRX/Impreza WRX-STi thread (merged thread) wrxpeed News & Rumors 938 05-17-2005 12:11 AM
('93-'01) played GranTurismo3, Old Rally impreza VS New impreza christurismohk Impreza Forum 5 05-19-2001 02:32 AM
whos selling their impreza away for new age impreza? DarkImpreza Vancouver Impreza Club Forum -- VIC 2 02-04-2001 01:14 AM
