Old 06-06-2011, 01:08 PM   #26
Kraziken
Member#: 38629
1999 Legacy GT (STI)
I'll bite.
My HID's were getting problematic after three years of use. Worked fine in dry weather. If it rained, sometimes one headlight didn't work, or both! Not great for Washington residents!
Decided it must be the OEM FX35 ballasts, since they don't seem to be waterproof. So I decided to go to retrofitsource and get some better ballasts. I picked the Morimoto 3Five ballasts. Figured I would redo the wiring harness at the same time just in case.
---Technical features include: True 35w output, 8-Amp Quickfire, hot-restrike capability, digital control board to automatically shut down in case of bulb/harness failure, and an integrated can-bus module to help combat error codes.
Physical features include: completely water-proof casing, potted internals, extra long output cord length, bulb-base seals, compact size, modern looks, laser etched graphics.
The wiring harness has a connector that goes to the OEM power. I had the connector cut off a few months ago from the shop when they were troubleshooting the light problem (strangely enough it kind of fixed it for awhile, but then the problem popped up again).
So the wires were direct connect, so not great for trying to work on replacements. I went to Fry's and found a 3 wire molex type connector. I cut the connection and added these quick connects.
Here's a pic of the original FX35 wiring connector, and the new waterproof connectors from retrofitsource.
A pic of the old FX35 ballast and the new.
Passenger side had a nice convenient empty bolt hole that worked great for supporting the ballast. I have no idea what the hole was originally used for, but the bolts from the morimoto kit fit.
Drivers side didn't have a bolt hole in the location, so I used the bolt used for the ground to attach the ballast.
Another pic of the ballast location drivers side, just before I shoved the light assembly back in.
Happy to report, everything is back to normal. I've driven a few times in the rain, and no problems.
Kraziken is offline   Reply With Quote
Old 06-09-2011, 11:30 AM   #27
BURTONRIDR
Member#: 72132
2000 Legacy GT
Bought my third subaru(third legacy too), yesterday
Planning to resurface the headlights, clear the turn signals, and check the timing belt this weekend.
BURTONRIDR is offline   Reply With Quote
Old 06-09-2011, 06:08 PM   #28
Azlegacy
Member#: 279837
Whats the details on the car ? Any pics?
Azlegacy is offline   Reply With Quote
Old 06-09-2011, 06:11 PM   #29
BURTONRIDR
Member#: 72132
2000 Legacy GT
I have the details here http://forums.nasioc.com/forums/show....php?t=2194532
I will take photos tonight and try to get them up tomorrow
Old 06-09-2011, 09:21 PM   #30
legacybov
Member#: 285229
I need to do the engine / tranny mounts, any advice on where to buy? And which parts to buy?
Also need to do the spark plugs.... any recommendations?
legacybov is offline   Reply With Quote
Old 06-10-2011, 12:28 PM   #31
BURTONRIDR
Member#: 72132
2000 Legacy GT
STI motor mounts work on some models, I put them on my 1998 Legacy outback. They are nice and give the car a tighter feel to it, but it also makes the car vibrate a little more.
What year do you have?
Old 06-10-2011, 09:01 PM   #32
legacybov
Member#: 285229
I have a 2003. When at a stop it vibrates more than i like.
Old 06-11-2011, 11:09 AM   #33
Azlegacy
Member#: 279837
I have solid motor mounts on my protege5 , I don't think ill ever put them on another car, it causes bad vibrating. People ask why the car shakes so much and at stop lights its horrible . I only like the acceleration part . It just feels better but not worth the earth quake feelin .
Old 06-13-2011, 01:13 AM   #34
Azlegacy
Member#: 279837
Finally after 5 months of looking I found a dark grey leather interior at the pull a part for my wagon. Best part it was complete and total cost was 125. Installed it tonite . Looks great now.
Old 06-13-2011, 02:24 AM   #35
JoKerNZ
Member#: 140342
1998 Legacy GTB JDM
Gravel bashed my 'part-out' car :P
JoKerNZ is offline   Reply With Quote
Old 06-14-2011, 08:01 PM   #36
Azlegacy
Member#: 279837
Put my wagon on a tow truck , finally gettin an engine in it (ej22) . Can't wait to drive it .
Old 06-16-2011, 04:50 AM   #37
Calzoni
Member#: 282354
2000 Legacy
ordered up some front and rear Centric Rotors. No more warped and pretty much shot rotors!
Calzoni is offline   Reply With Quote
Old 06-16-2011, 09:33 AM   #38
CousinLarry
Member#: 281756
2005 Legacy GT
RBP
I covered the ugly woodgrain!
CousinLarry is offline   Reply With Quote
Old 06-16-2011, 06:10 PM   #39
Azlegacy
Member#: 279837
lt should have had that from the factory.
Old 06-16-2011, 10:10 PM   #40
98legwag
Member#: 160325
09 Legacy 3.0R
I installed a rear wiper arm and blade from a Honda Pilot today. New school look on an old school Legacy. I will get a picture tomorrow.
98legwag is offline   Reply With Quote
Old 06-16-2011, 10:56 PM   #41
Azlegacy
Member#: 279837
I was thinkin of doing that . What year is it again ?
Old 06-17-2011, 08:54 AM   #42
98legwag
Member#: 160325
09 Legacy 3.0R
http://www.sl-i.net/FORUM/viewtopic.php?f=39&t=19616
The part # and a link to order the part are in that thread. You can order the whole blade/arm assembly for about $50.
Old 06-17-2011, 07:30 PM   #43
Azlegacy
Member#: 279837
Talked to my mechanic today and he will be doing a refresh on my motor. I should have it back in less than two weeks since he is super busy. So excited to drive it . Bought it broken and building it the way I want it . It's a hybrid of all models . I added parts from every model . I love the outbacks because that's the majority of cars I sourced stuff from.
Old 06-20-2011, 01:00 PM   #44
triplet911
Member#: 106971
1998 lgt
red
currently doing an ej20k swap today im just cleaning out the engine bay some more and im going to work on the headlights
triplet911 is offline   Reply With Quote
Old 06-20-2011, 10:51 PM   #45
Azlegacy
Member#: 279837
Lucky you, boosted legacies ftw.
Old 06-21-2011, 12:51 AM   #46
Calzoni
Member#: 282354
2000 Legacy
replaced a wheel stud on my passenger side
also did this while in the replacing process
Old 06-22-2011, 09:01 PM   #47
Azlegacy
Member#: 279837
So my Subaru is on the road. Engine has been refreshed with all major maintenance, a new radiator and clutch . Owner of the shop even threw in an sti oil pump , wrx shifter assembly for tranny , fuel filter and a few other parts for free.
Old 06-26-2011, 06:48 AM   #48
soloz2
Member#: 260128
2014 WRX 5 Door
Ice Silver Metalic
I think it's time for a breaker bar...
soloz2 is offline   Reply With Quote
Old 06-26-2011, 12:11 PM   #49
Asakura
Member#: 268012
2004 Legacy L SE
Bought a 17mm socket so I can finally change the oil on Tuesday. Might be ordering some small parts tonight too.
Asakura is offline   Reply With Quote
Old 06-27-2011, 04:49 AM   #50
Calzoni
Member#: 282354
2000 Legacy
very much so. The wrench and a jack handle i guess just doesn't handle the torque
So what mods have you done to your baja? 2003Baja Baja Forum 22 07-16-2004 03:31 PM
What mods have you done to your WRX? Diesel7 Canada Region Forum 3 11-02-2002 12:16 AM
What have you done to your RS lately? CosmoTheCat North West Impreza Club Forum -- NWIC 8 03-27-2001 10:55 PM
What have you done to your impreza? Hades69 General Forum Archive 2 02-17-2001 07:39 PM
