Old 05-25-2011, 09:21 PM   #1
hawaiifosho
Member#: 283874
Exclamation Help Help *wrx Wont Start* Help Help
So i am new to the Subaru game, i just bought my wrx less than a month ago and i love it. its a 2004 Wrx wagon 2.0. I recently took it off roading and she handled like a dream. Went to cross a river and realized that AWD is not quite 4X4. the car got stuck in the water and water got into the car. It was up to the door and water slowly started leaking in, i freaked out and got help from a friend who pulled me out with his truck. the whole driver side cabin was filled with water, a little on the passenger side but not as much as the other. the car ran fine while in the water as i did not shut it off to prevent water from entering the exhaust. Less than a minute after being rescued from the river the car stalled and did not start. had to tow home. got home and tried several times to start it but no luck. the car turns over fine just doesn't fire.
first issue the fuel pump was not priming when i turned the key, thought it might be the relay and had that checked, it worked fine. ran a direct wire to the fuel pump to check if that went out, and it worked fine.
then went with the OBD II scanner to see if anything came up and it did not link the connection. strange to not connect i have never seen that before.
thought it might be the ECU since its on the passenger side floor which wasn't flooded like the driver side but had a little moisture when i removed the kick panel and took out the unit. Went with a blow dryer and gave it a nice dry just in case, even though it wasnt wet. thought it was at least worth a try. didnt work. plugged in the OBD scanner and still no connection.
Thinking maybe the ECU shorted or something happened with that. just wanted to post and see if anyone had any advice. please help i cant be leaving my subie parked when she's meant to be on the streets.
hawaiifosho is offline   Reply With Quote
Old 05-25-2011, 09:31 PM   #2
scooby578
Member#: 220345
02 Time attack wrx
05 LGT
First off wtf were you thinking..
Now to the question, have you checked all the fuses?
There is one relay that might have gone bad witch is the main relay its on th passenger side behind the kick panel it is dark brown.
If one of the fuses in the fuse box under the hood (that is a 30 i believe its right next to your window fuse) is blown thats your problem..
scooby578 is offline   Reply With Quote
Old 05-25-2011, 09:35 PM   #3
subaru1773
Member#: 275115
2002 impreza wrx
blue pearl
did the ecu get any water near it if so take it out and check it also if motor was in water check ur coil packs water could shorted them out
subaru1773 is offline   Reply With Quote
Old 05-26-2011, 01:35 AM   #4
Zachfeen
Member#: 277479
2011 WRX
OBD not connecting is bad news. Check fuses and if nothing surfaces there, I suspect the ECU might be hurt You can pull it out and take a hair drier to it to try to dry it better. Otherwise take it to a dealer/shop and get it looked at by a pro
Zachfeen is offline   Reply With Quote
Old 05-26-2011, 01:55 AM   #5
reaves99
Member#: 241294
I can't figure out why your having these issues. The 2004 wagon typically respond great when you treat it like a submarine.
reaves99 is offline   Reply With Quote
Old 05-26-2011, 02:03 AM   #6
Jubert69
Member#: 167739
04 WRX
Jubert69 is online now   Reply With Quote
Old 05-26-2011, 03:00 AM   #7
Steeldon
Member#: 248219
2004 WRX 68HTA+HFS6
I know I take my 2004 WRX sedan through rivers all time I don't know what could be the problem lol.
Steeldon is offline   Reply With Quote
Old 05-26-2011, 04:15 AM   #8
furiouswrx
Member#: 283048
2011 WRX Ltd Hatch
::facepalm::
I hope you're just a troll because it would be incredibly sad to see a WRX mistreated like this.
furiouswrx is offline   Reply With Quote
Old 05-26-2011, 04:27 AM   #9
God
Member#: 148482
2085 CRYSMORE
LE BARON
It's a ****ing economy car you douche.
God is offline   Reply With Quote
Old 05-26-2011, 05:36 AM   #10
GL 07STi
Member#: 273503
2007 STI
UGM
I saw a camaro cross that same river, but then again those are boats.
GL 07STi is offline   Reply With Quote
Old 05-26-2011, 10:52 PM   #11
hawaiifosho
Member#: 283874
I think I might have fried my ecu. When I turn my ignition on I don't hear the fuel pump prime, the car cranks over but doesn't start. When i plug into test mode the check engine doesn't blink at all and the car still doesn't start.
I had water damage in the drivers and passengers footwell from flooding.
Took out the ECU and the carpeting was damp, not quite wet. And no visible water damage around the ecu or wires, but it was close.
When I plug in my OBD II scanner it reads "cannot link connection"
what are some of the symptoms of a fried ecu?
how can i check to see if the ecu has gone bad before buying a new one?
also, any advise on something to check on? I'm narrowing down my conclusion to the ECU, but open to ideas. thanks!!
Old 05-27-2011, 08:22 AM   #12
TFBHTMFSNE
Member#: 156086
Well, at least you've learned that.
Now, on to your problem. Obtain the proper wiring diagrams for the engine control system, and the Input/Output (I/O) chart for the ECU. Your best bet is to pay for a one day subscription on Subaru for access to the service manuals, and download the whole thing.
Check all your power supplies and grounds for the ECU. As others have stated, you probably shorted something out and blew a fuse. If all the power and ground signals are there and there is no communication with the ECU, well, they don't like water.
TFBHTMFSNE is offline   Reply With Quote
07 WRX Wont Start Need Help ASAP!!! bboylocob Factory 2.5L Turbo Powertrain 20 11-16-2010 04:34 PM
02 WRX wont start! please help meeee! 90alpine20v Factory 2.0L Turbo Powertrain 5 07-15-2010 06:14 PM
Help 03 WRX wont start after new battery! newgensti Factory 2.0L Turbo Powertrain 18 01-20-2009 01:58 AM
Help My WRX wont start! Jokoso Newbies & FAQs 9 10-30-2002 10:02 AM
need help wrx wont start Brewmaster New England Impreza Club Forum -- NESIC 8 06-15-2002 09:06 PM
Message Board Statistics All times are GMT -4. The time now is 09:40 PM.
