Go Back   NASIOC > NASIOC Regional Areas > International Forum
Old 06-14-2013, 07:10 AM   #1151
renegadeSTi
Member#: 156273
1999 RSTi 2.5/2.0
RBP
Originally Posted by jdmdom View Post
Yes you have to. There is no room to pull the heads wile the engine still in the car. I did my timing belt/water pump/ plus all the idlers on my car not too long a go. That was a piece of cake. With the right tools of course.
I've heard of people leaving the motor in the car while doing HG job. I don't recommend that way since you have limited room to work and all that. Besides the job goes quickly once the engine is out and on a stand you could do HG in a days time.
renegadeSTi is offline   Reply With Quote
Old 06-14-2013, 07:20 AM   #1152
jzehren11
Member#: 357281
2004 WRX Wagon
well this is worse case scenario. timing belt, radiator, and water pump/tstat are getting done this weekend. Oil change next weekend. thats when the best time to tell if its gone or not is when all this is done.
there is no peanut butter on the dip stick, or on the oil cap. but the coolant is burnt, and foamy....I describe it as like rootbeer float. there was a crack in the top of the radiator that we actually found on Tuesday. it burns occasionally out the tail pipe... but its only done it once or twice in the past week.
jzehren11 is offline   Reply With Quote
Old 06-14-2013, 01:09 PM   #1153
renegadeSTi
Member#: 156273
1999 RSTi 2.5/2.0
RBP
Originally Posted by jzehren11 View Post
yeah I watched the how-to like 3-4 times. looks pretty simple!
It's not rocket science, that's for sure
Old 06-14-2013, 03:02 PM   #1154
jzehren11
Member#: 357281
2004 WRX Wagon
I normally over think things, but yeah seems pretty straight forward
Old 06-15-2013, 10:53 AM   #1155
armyssoldierboy
Member#: 109424
06 AW STI
Twin Scroll HTA gt3076r
I had an extra harness and thought I was doing the jdm mod but apparently not lol I like this though. 2 top lights are blinkers, inside bottom is the parking and brake light and the outside lower is the reverse lights. I just need to get some red bulbs for the parking/brake lights.
What are yalls opinions?
armyssoldierboy is offline   Reply With Quote
Old 06-16-2013, 07:16 AM   #1156
Goe
Member#: 113484
We just did while the engine was still inside. It's a pain in the ass.
Goe is offline   Reply With Quote
Old 06-16-2013, 07:51 AM   #1157
renegadeSTi
Member#: 156273
1999 RSTi 2.5/2.0
RBP
Yeah this is what I've heard, I've never done it that way before. I always choose to pull the motor for head gaskets and other service that needs more room to work on the motor.
Old 06-16-2013, 08:20 AM   #1158
Goe
Member#: 113484
It was more like a bet. Mechanic said he gets it done even with head stuts. And then he suffered
Old 06-16-2013, 11:46 AM   #1159
jzehren11
Member#: 357281
2004 WRX Wagon
New timing belt, water pump and thermostat are in! just gotta finish up putting everything back together tomorrow, with the new 3-core radiator! Then to find out if I indeed need to change my headgasket :/
and what else do you suggest I do while I have the motor pulled? spark plugs for sure... but what else?
Old 06-16-2013, 12:42 PM   #1160
renegadeSTi
Member#: 156273
1999 RSTi 2.5/2.0
RBP
If your oil looked like this
Head Gasket is bad. There are a whole bunch of seals on the motor that may need replacing. I can't remember all the seals off the top of my head though.
Old 06-16-2013, 12:45 PM   #1161
jzehren11
Member#: 357281
2004 WRX Wagon
the antifreeze looked like that
Old 06-16-2013, 02:39 PM   #1162
renegadeSTi
Member#: 156273
1999 RSTi 2.5/2.0
RBP
You should get that head gasket done while the motors out.
Old 06-16-2013, 03:25 PM   #1163
jzehren11
Member#: 357281
2004 WRX Wagon
I didnt pull the motor to do the timing belt. I will probably be doing it next week HOPEFULLY! I doubt if I order the stuff today that it will be here before Friday #livingingermanyproblems :/ because of course my 3 day weekend is this coming Sunday-Tuesday
Old 06-16-2013, 03:36 PM   #1164
jzehren11
Member#: 357281
2004 WRX Wagon
So on the topic of HGs...
Autozones got these?
http://www.autozone.com/autozone/par...127774_0_7031_
And when I try to get OEM from IIR, doesnt seem like they have the option for my motor??? Only comes up or 2.5L????
http://www.importimageracing.com/sub...4-wrx-sti.html
EDIT... DERP found the right ones :/
Getting these:
http://www.importimageracing.com/ngk...02-05-wrx.html
and
http://www.importimageracing.com/sub...-wrx-2-0l.html
Old 06-16-2013, 04:52 PM   #1165
renegadeSTi
Member#: 156273
1999 RSTi 2.5/2.0
RBP
Getting these:
and
Cosworth is nearby I hear they have head gaskets
Old 06-17-2013, 10:34 AM   #1166
jzehren11
Member#: 357281
2004 WRX Wagon
well yeah put the radiator in, and test fitted everything. then when I was pulling it out again I cracked an AC line, FML!!! looks like ill be pulling the AC out!
but yeah ordered the full OEM gasket kit. just need to get that then Ill be dropping the motor and regasketing it and install my new exhaust. So yeah... the car is going to be down for about a month, until I can afford the AccessPort to tune the car.
Old 06-17-2013, 11:26 AM   #1167
Evolved2Sti
Member#: 346567
2011 Sti
small roads don't like me here. Dented and scraped the side fenders of my STI. anyone know of a good body shop/paint here?
Evolved2Sti is offline   Reply With Quote
Old 06-18-2013, 08:36 AM   #1168
Patwade21
Member#: 332009
2007 Subaru STi
WR Blue
ouch during my rebuild i was pushing mine back into my garage and it ghost wheeled into the side of my garage.. scratched my fender a little... ill be looking for a good place when i get back from my deployment also.
Patwade21 is offline   Reply With Quote
Old 06-18-2013, 08:38 AM   #1169
RosewRX
Member#: 332954
2004 WrX
There's a place off the B270 near Vogelweh that's good but I can't remember the name. They're pricey but one of the best shops in the area. I'll ask at work, one of the mechanics is friends with a guy that does paint there.
RosewRX is offline   Reply With Quote
Old 06-19-2013, 04:22 AM   #1170
Evolved2Sti
Member#: 346567
2011 Sti
Insurance recommended a shop like an hr away. Near some small toyota dealership. Well see how it goes..wont have the car for a few weeks...good times lol
Old 06-19-2013, 03:57 PM   #1171
mobius388
Member#: 323465
2006 STI
Evolved2Sti... I seen you driving around. I got a black STI but she's down temporarily. Hope to see you out at the meets if you haven't gone already.
Anyways I ended up purchasing 4 new okada coil packs, FML
mobius388 is offline   Reply With Quote
Old 06-19-2013, 03:59 PM   #1172
mobius388
Member#: 323465
2006 STI
Do you still need assistance this weekend or not? I have a feeling my car will be back up and running so I won't have to depend on someone to take me to and from places anymore.
Old 06-19-2013, 04:06 PM   #1173
RosewRX
Member#: 332954
2004 WrX
She will be up again?!
Old 06-19-2013, 04:27 PM   #1174
Evolved2Sti
Member#: 346567
2011 Sti
for sure,once this cosmetic dmg gets fixed ill be out there. Awaiting for theshop to call me back and get me in.
btw...what meets?
Old 06-19-2013, 05:52 PM   #1175
renegadeSTi
Member#: 156273
1999 RSTi 2.5/2.0
RBP
I saw a WRB Hatch 08+ with what looked to be the Invidia Q300 exhaust 4 port cat back leaving Kleber Kaserne today, afternoon time.
Germany Roll Call alloutSTI International Forum 334 12-18-2011 01:55 AM
HTX : Booze & Bokeh II party...roll call. RallyGuy2k Texas Impreza Club Forum -- TXIC 29 08-30-2009 11:02 AM
Since this is a car forum... Germany in call for ban on oil speculation Qcanfixit Off-Topic 31 05-27-2008 06:36 PM
Roll call for July 14th Solo II at Cal Speedway Subayai WRX Southern California Impreza Club Forum -- SCIC 16 07-13-2002 09:06 PM
Edmonton roll call schlong8 Canada Region Forum 15 01-10-2001 02:32 PM
