Old 05-27-2011, 04:03 PM   #1
mstkenny04
Member#: 261358
2015 STI
World Rally Blue
Question 2011 wrx 5 mt problems?
whats going on forum. Just a question. I got my wrx in oct 2010 and for some reason it seems sometimes its tough to get it into reverse. Anyone else experience this problem? its frustrating, sometimes have to roll forward a bit then it would go into gear. Just wondering if anyone has had that problem and if so what measures did you take?
mstkenny04 is offline   Reply With Quote
Old 05-28-2011, 03:02 AM   #2
xatnys
Member#: 271829
2011 WRX STI 5-dr
Keep the clutch in and go into a different gear, then try reverse again. It's pretty normal. Had the same issue on my WRX and last manual car before that.
xatnys is offline   Reply With Quote
Old 05-28-2011, 03:04 AM   #3
socalwrench
Member#: 231975
2008 WRX (sedan)
Most automotive transmissions these days use synchronized gears. However, the reverse gear is not usually synchronized. The front gears are synchronized and allow much smoother engagement.
socalwrench is offline   Reply With Quote
Old 05-28-2011, 03:04 AM   #4
Spiro2010
Member#: 270786
2011 Stage 2 Prem.
Dark Gray Metallic
I have an 11 prem, and I know what your talking about, I just put it in first and then put it in reverse. Keep the Clutch in.
Spiro2010 is offline   Reply With Quote
Old 05-28-2011, 08:29 AM   #5
Jessekrs123
Member#: 236927
2015 BRZ, 93 Legacy,
1984 BRAT
This. Same thing with my 1993 Legacy. Occasionally it is hard to get into reverse (no synchro straight cut). If I can't get it in, I just shift into 5th, then go into reverse.
It's perfectly normal.
Jessekrs123 is offline   Reply With Quote
Old 05-28-2011, 01:40 PM   #6
mstkenny04
Member#: 261358
2015 STI
World Rally Blue
Cool re:
Thanks I figured... I thought maybe could have been a problem but meh.. haha
Old 05-28-2011, 05:14 PM   #7
achavez
Member#: 139320
2006 RA 1-4 5mt
wrx obp needs a e85 tune
Its a manual tranny thing. I know my friends hondas do this too as well as my wrx. Going into another gear works and lettin go the clutch pressing it again works better
achavez is offline   Reply With Quote
Old 05-28-2011, 10:49 PM   #8
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
Selecting a forward gear may slightly spin the shaft enough that the gears for reverse will not interfere or selecting neutral and releasing the clutch pedal momentarily will spin the shaft at engine speeds so it will move the gears for sure.
Old 05-29-2011, 10:41 AM   #9
ricky0418
Member#: 236866
2013 Charger SRT8
white
i think is normal my 2010 wrx does this since day 1, i learned to deal with it!
ricky0418 is offline   Reply With Quote
Old 05-29-2011, 11:45 AM   #10
mrkyle3
Member#: 272675
2011 WRX
2004 Miata
If I can't go into reverse I just put into neutral, let clutch out, push clutch back in, then put it into reverse. Works every time.
mrkyle3 is offline   Reply With Quote
Old 05-29-2011, 11:56 AM   #11
Baddmnkey
Member#: 211812
09 WRX
SSM, mostly stock!
^^^ This works everytime
Baddmnkey is offline   Reply With Quote
Old 03-08-2013, 07:01 PM   #12
2007 wrx hatch York
Member#: 349524
Problem with a 2011 wrx it goes in reverse but doesn't do anything all 1-5 work fine what could it be?
2007 wrx hatch York is offline   Reply With Quote
2011 wrx 5 door hatch with Rota 17"x7.5 +48 5x100 wheels? BretCutler Tire & Wheel 4 01-14-2011 08:05 AM
FS: 02 Silver WRX 5 MT w/ V7 RA-C Motor Need4Boost Tri-State Area Private Classifieds 10 04-15-2008 01:36 PM
2006 Wrx 5/mt bannerd Transmission (AT/MT) & Driveline 3 07-26-2006 05:13 PM
FS in NJ: 02 PSM WRX 5 MT w/ JDM Swap Need4Boost Private Vehicle 'For Sale' Classifieds 2 03-07-2006 06:05 PM
WRX 5 MT Transmission With STi RA Gears MisterX Private 'For Sale' Classifieds 12 07-02-2004 11:34 PM
