#1 |
Member#: 451
NWIC
Vehicle:2000 Impreza 2.5RS 2008 Legacy GT Limited |
Is there anyone who has a service manual who would like to post the instructions on how to change the fuel filter
Or anyone who has experience with this would like to tell me their steps that they use? Gonna try this for the first time, I've changed them on my old Blazer but I want to make sure I don't skip a step on the Subaru Thanks, Ryan
#2 |
Member#: 6436
Vehicle:1998 Impreza 2.5RS BDP |
Do a search on this forum and you'll find many postings detailing fuel filter replacement.
#3 |
Member#: 451
NWIC
I already tried that, didn't help out that much
Maybe I'll try expanding the search date to 6mo-1yr Thanks |
#4 |
Member#: 4162
Vehicle:2001 Impreza 2.5RS Silver |
i did mine the other day its pretty easy. The filter is located on the drivers side right on top. Unclip the filter bracket and release the hose clamps. The hose will spit a little fuel out when you pull them off. Just put the hoses back where they are supposed to be and clip the filter back in. Dont forget the stock rubber piece or else the filter wont be gripped. If you have any questions PM or e mail me...Joe
#5 |
Member#: 3288
Vehicle:1998 Impreza 2.5RS Rally Blue Pearl |
If you have never done a FI fuel filter replacement I suggest:
-Do it when the engine is bone cold (the pressure in the line will also be lower by the time the engine gets cold). -Disconnect the battery. -Have rag available to catch and/or deflect fuel spray. -Don't get fuel on the paint. -Use common sense when dealing with combustibles. |
#6 |
Member#: 4083
NESIC
Vehicle:2006 OBS SE regal blue |
also open your gas cap to relieve pressure.
#7 |
Member#: 451
NWIC
Hey thanks guys, I think I'll try it this weekend
Common sense huh...you mean don't smoke a cigarette while doing this ![]() |
#8 |
Member#: 15543
Vehicle:90BJ Legacy LS ABS AWD 946 Rio Red Jpn built |
I dont think you need to remove the gas cap. If anything there would be a slight vacum in the tank. Any pressure is removed by the evaporative system and placed into the charcoal to be burned at the next start.
I suggest having a little motor oil or wd40 handy. The tubes can be a bitch to get on the new filter without a little lube. |
#9 |
Member#: 13607
Vehicle:82 Suzuki GS 1100E Gold-ish |
So, has anyone replaced the filter with anything aftermarket? somthing smaller or inline that i could just replace the element in?
I needa spot for my greddy oil catch tank... Trent |
| Thread Tools | |
| Display Modes | |
| fuel filter replacement | vtownrida | Service & Maintenance | 11 | 12-18-2009 08:35 PM |
| Fuel Filter replacement - where is fuel pump relay? | SeenDubAYouAreEx | Newbies & FAQs | 4 | 07-11-2007 09:29 PM |
| fuel filter replacement | loudog800 | Service & Maintenance | 4 | 03-06-2004 11:26 PM |
| Fuel filter replacement | Shifter | Service & Maintenance | 3 | 08-31-2003 06:16 AM |
| wrx fuel filter replacement | phillywrx | Service & Maintenance | 9 | 10-10-2002 12:12 PM |
