Old 05-29-2011, 12:36 PM   #1
bluemax189
Member#: 137405
2011 WRX 6spd
GTX3076r
Default Bulletproof TMIC install
Installed my bulletproof TMIC this morning from SeeeeeYa. Quick shipping and great quality with great install directions. This how to will supplement his written instructions that come with the kit. Off we go
Heres the tools you will need:
BP TMIC kit from SeeeeeYa
12mm socket
10mm socket
Pliers
flat head screw driver
Clamp kit from Advance auto/autozone/pepboys/salvo
Here is the pic of the kit and the clamp set i bought
Stock 2011 wrx engine bay/tmic
I first removed the tmic. Unclamp the bpv and remove the 2 10mm bolts
Remove the 3 12mm bolts holding the TMIC bracket in place and remove the bracket
Next i removed the 2 12mm turbo side bolts
Loosen up the throttle body hose clamp using your flathead screw driver
Wiggle off the TMIC and remove from the vehicle. Your car should look like this now...
bluemax189 is offline   Reply With Quote
Old 05-29-2011, 12:36 PM   #2
bluemax189
Member#: 137405
2011 WRX 6spd
GTX3076r
Now below the center of the intake manifold you will see the BPV source hose that needs a corbin clamp installed on it. This can potentially lead to boost leaks later so might as well clamp it now.
Install the clamp and hook it back up to the engine
Also install one on the opposite end of the same hose on the bpv
Now is time to install the bulletproof tmic kit. I didnt document this process because the directions couldnt be any better from SeeeeeYa. The install is very straight forward and pretty easy to do. The kits specs are spot on. On thing I did to install the rails was to use a piece of wood and a rag to tap the rails into place as to not leave marks on the aluminum rails.
Final Assembly:
Reseat TMIC into car and wiggle onto the tb hose and tighten clamp
Install your turbo side bolts
Reconnect the recirc hose to bpv while you have a little extra wiggle room with out the TMIC bracket.
Reinstall tmic bracket making sure to put the rubber washer, metal side up, back on the tmic if you removed it.
Tighten all your bolts up and your done!
Overall impression....... Well I noticed absolutely no difference in driving or power. This is a safety feature and ensure my TMIC will not seperate. The kits' directions were written well. I thought it would be nice to just have some supplementry pictures of the install for others to see. Overall the install process took about an hour with taking pictures along the way. Easy mod to perform to ensure the most longevity out of your stock TMIC setup.
Huge shout out to SeeeeeYa for his great communication, awesome quality and even faster shipping on the kit!
Old 05-29-2011, 12:41 PM   #3
Seventh
Member#: 263223
2011 WRX 5dr
SWP, 332ti
Nice write-up and pics!
Seventh is offline   Reply With Quote
Old 06-13-2011, 08:17 AM   #4
SeeeeeYa
Member#: 129681
2016 WRX w/EyeSight
Lapis Blue Pearl
Default Another Excellent Install Thread!
This thread has provided more than one BP Mod installer a good visual guide. Excellent photos and words... I should do as well.
Interesting how the very same mod gets into different forums... its fundamental reason for being transcending category.
Another great ride gets even better.
SeeeeeYa is online now   Reply With Quote
Old 08-13-2011, 09:16 AM   #5
08imprezaRS
Member#: 185564
Looks like an amazing bit of kit!
I want one for my 2011 in aus!
08imprezaRS is offline   Reply With Quote
Old 08-13-2011, 06:46 PM   #6
Joker_927
Member#: 267865
2020 WishIHadMySubby
Imaginary Blue
Thank you for this. I couldn't find any pictures for how to remove the TMIC from a 3g wrx. After seeing this I realize how easy it is but I still think this might be the only thread on the internet documenting how to do it and for that I thank you.
Joker_927 is offline   Reply With Quote
Old 07-18-2012, 02:20 PM   #7
SeeeeeYa
Member#: 129681
2016 WRX w/EyeSight
Lapis Blue Pearl
http://legacygt.com/forums/showthrea...html?p=3986222
Old 07-18-2012, 05:22 PM   #8
pux888
Member#: 8356
02 STi swap
12 WRX limited
Mods like this one is the reason for enthusiast communities and forums, profit or not!
pux888 is offline   Reply With Quote
Old 07-18-2012, 06:17 PM   #9
SeeeeeYa
Member#: 129681
2016 WRX w/EyeSight
Lapis Blue Pearl
Default The TMIC Cure for 08+ WRX and LGT
I absolutely agree! And am fortunate to be able to contribute.
The OP in that thread is there with my blessings. The BulletProof TMIC Mod has become Subaru Community property. No longer need we be held hostage by big-buck vendors that often provide less.
The original mod has become more refined as the membership contributes, and is an excellent option for everyone with an LGT or 08+ WRX.
Thanks to everyone.
Old 07-18-2012, 07:01 PM   #10
BigRob74
Member#: 305107
2016 GT 5.OHH
DIB
whats this cost? is there a link or something?
BigRob74 is offline   Reply With Quote
Old 07-18-2012, 07:27 PM   #11
SW21MR2
Member#: 60135
2005 Kona Stink-E
I'd like to know where to get this as well.
SW21MR2 is offline   Reply With Quote
Old 07-18-2012, 08:57 PM   #12
SeeeeeYa
Member#: 129681
2016 WRX w/EyeSight
Lapis Blue Pearl
Here you are: http://legacygt.com/forums/showthrea...ts-189608.html
Old 07-18-2012, 09:14 PM   #13
PhillyLGT
Member#: 280615
2005 turbro Camry
I've done this to my '05 LGT with great results. Also got my kit from the same guy on the Legacy forums (BarManBean). Highly recommended service and shipment time.
PhillyLGT is offline   Reply With Quote
Old 07-19-2012, 10:30 AM   #14
BoozeRS05
Member#: 137797
'05 LegacyGT
wagon, 5mt
I'm in on the BP TMIC kit, thanks to SeeeeeYa and those who've helped along the way.
BoozeRS05 is offline   Reply With Quote
Old 07-21-2012, 10:36 PM   #15
bluemax189
Member#: 137405
2011 WRX 6spd
GTX3076r
definately worked and as i said it was a precautionary. i have since moved onto a perrin tmic just for the cooling in baltimore traffic.
Old 07-26-2012, 07:06 AM   #16
SeeeeeYa
Member#: 129681
2016 WRX w/EyeSight
Lapis Blue Pearl
Having had both of those I can say with certainty that the OEM TMIC is superior to the Perrin in traffic. Certainty.
The OEM LGT, 08+ WRX TMIC is THE best Daily Driver TMIC available, bar none. The reason is simple, it has less metal in it which means there is less reservoir for heat to accumulate, or soak. Its smaller, but highly efficient core also has less mass, by far, than the bar-and-plate of the Perrin, which also has heavy aluminum end-tanks. Even when the OEM TMIC does get inevitably hot in traffic, it quickly cools down. The Perrin is exactly the opposite.
The ONLY advantage the bulky Perrin, and others built similarly, have over the OEM TMIC is less internal resistance... an advantage traded at the cost of cooling efficiency. The OEM TMIC is the better intercooler, in multiple ways.
Once reinforced with the BulletProof-TMIC Mod the OEM TMIC is not only capable of holding any boost you want to thrown at it, it is also a capable intercooler for track duty as well...
http://legacygt.com/forums/showpost....4&postcount=25
I've been running this kit for well over a year. I have done >10 trackdays at 18 and 20 psi on it. It has and still is holding strong. Highly recommended if you want to run >18psi on the stock TMIC without issues.
Old 07-26-2012, 10:01 AM   #17
J_Maher_WRX
Member#: 290307
Hmm, i'm running the bulletproof mod on mine as of now as well and I can vouch that it works like a charm
My next plans either included getting a larger TMIC, or an EWG setup, but I guess with the info posted above, bring on the EWG!!
J_Maher_WRX is offline   Reply With Quote
Old 07-26-2012, 12:31 PM   #18
Seventh
Member#: 263223
2011 WRX 5dr
SWP, 332ti
Just stopped by to support the cause. Still rocking mine and loving it. Hope all is well Jeff, long time no talk!
Old 07-27-2012, 07:55 PM   #19
SeeeeeYa
Member#: 129681
2016 WRX w/EyeSight
Lapis Blue Pearl
Ditto, Jeff, especially the long time. How it flies.
Thanks for your feedback. And continued thanks for your OL/CL tip.
Old 07-28-2012, 11:30 AM   #20
DeadGeneration
Member#: 313753
2012 WRX
Dark Gray Metallic
I am considering this. I haven't seen pictures of a zip tied one yet.
DeadGeneration is offline   Reply With Quote
Old 07-30-2012, 09:19 AM   #21
xlaterdaysx
Member#: 285807
2011 WRX 5-door
Couldn't you do it without taking it off?
xlaterdaysx is offline   Reply With Quote
Old 07-30-2012, 09:21 AM   #22
BarmanBean
Member#: 297778
2005 OBXT 6mt
http://legacygt.com/forums/showpost....&postcount=316
Some good pics of the zip tie version in that post.
BarmanBean is offline   Reply With Quote
Old 07-30-2012, 09:23 AM   #23
BarmanBean
Member#: 297778
2005 OBXT 6mt
It's possible, but likely would only cause increased frustration. Removing the intercooler is not difficult, and doing so allows you to inspect everything and make sure the rails are all seated completely.
Old 07-30-2012, 10:32 AM   #24
SeeeeeYa
Member#: 129681
2016 WRX w/EyeSight
Lapis Blue Pearl
I posted my experience with that. It is possible, but stupid. To seat the rails properly they must be lightly hammered/tapped into position. That can't be done with hand pressure alone. In my attempt I got beneath the car and used a piece of dowel to tap the rail into place from underneath. In the process I messed up the intercooler fins badly. Later, when I took it off and did it right, it took a long time to straighten them out and it still looked nasty. Don't try it.
I did that because ideally that's the way I wanted the Mod to work. Fail. Take the TMIC off, it's utterly simple and easy. Not only that, you NEED to address the BPV sense hose underneath which can only be done with the IC off.
Old 07-30-2012, 11:19 AM   #25
J_Maher_WRX
Member#: 290307
What is this BPV sense hose issue you speak of? Please explain
TurboXS TMIC install question roybfr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 11-01-2004 02:11 PM
APS TMIC install rjrutzky Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 12-05-2003 12:48 PM
TMIC installation = major PITA redrexx STi Forum Archive 4 06-25-2003 12:41 AM
new tmic installed krex Texas Impreza Club Forum -- TXIC 26 05-08-2002 01:53 PM
help with mrt's tmic install axis Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-21-2002 09:38 AM
