Old 05-29-2011, 08:21 PM   #1
cyclura
Member#: 206490
2008 STI
Default P0119 fans wont stop? Please help!
I Just finished my 30R install and my coolant fans will not shut off. code is a P0119. any help would be greatly appreciated as I have been racking my brain trying figure this out.
cyclura is offline   Reply With Quote
Old 05-29-2011, 09:08 PM   #2
Jessekrs123
Member#: 236927
2015 BRZ, 93 Legacy,
1984 BRAT
Your coolant temperature sensor is disconnected. This sends the car into fail-safe mode which trips the fans constantly. Because the ECU sees no resistance within the coolant temperature circuit, it senses there is something wrong and trips the fans constantly to be safe to avoid possible overheating.
I'm guessing that you disconnected it to get it out of the way when you were putting in your new turbo since all of those parts all exist in the same general area.
Or maybe you broke the wire.
Check out the connection, because it is either unplugged or broken.
Jessekrs123 is offline   Reply With Quote
Old 05-29-2011, 09:24 PM   #3
cyclura
Member#: 206490
2008 STI
Thanks, Its plugged in, but I did not pull the connector to check if its broken. Today I followed the main harness to the ECU and found a green male and green female not connected. I plugged it in and turned the key and the fans would turn on and off like a soloniod was going on and off, But the interior lights did not flash or go on or off, And the fans never went off for good they just stopped and started?
Old 05-29-2011, 09:34 PM   #4
van_dutch
Member#: 198633
2004 WRX
Green connectors under the steering column near your knees by the OBD port? Sounds like the test mode connectors. You don't want those connected unless you are flashing a new map.
van_dutch is offline   Reply With Quote
Old 05-29-2011, 09:41 PM   #5
cyclura
Member#: 206490
2008 STI
No they were right above the ecu under the carpet on the passenger side, coming off the main loom. My maps are all done with an AP.
Thanks Guys I really want to gget this solved as I have spent days trying to track this issue down. Its going to AMS for a tune as soon as I get this resolved. (On a limp map of course)
Old 05-29-2011, 10:30 PM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
green test connectors....there are 2 sets of these....the ones on the passengers side are usually connected at the factory and stay connected forever....sometimes whoever PDI's the car will disconnect these and NOT the one on the drivers side when the car is put up for sale after PDI
ONE PAIR OF THE GREEN CONNECTORS MUST BE DISCONNECTED UNLESS THE CAR IS TO BE PUT INTO TEST MODE AND THAT ALMOST NEVER HAPPENS
Old 05-29-2011, 10:39 PM   #7
cyclura
Member#: 206490
2008 STI
So thats not my issue, I will disconnect them immediatly. Thanks, any other things this may be?
Old 05-29-2011, 11:59 PM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
p0119
Engine Coolant Temperature Sensor 1 Circuit Intermittent
means the circuit isnt constant....means ya got a busted wire or connector or some such electrical issue
figure it out
Fan wont stop running. mls1 Electrical & Lighting 4 02-19-2011 12:01 PM
cosworth motor wont rev! please help jerry leahy Built Motor Discussion 8 05-06-2008 12:16 AM
kia sportage wont start please help i will pay for help dukeduster Off-Topic 40 05-06-2007 08:14 PM
Car wont start please help SplatZ400 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 07-22-2006 04:22 PM
my car wont boost please help blackrod punishment Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-12-2006 11:42 PM
