Old 05-30-2011, 03:48 PM   #1
jeffg
Member#: 2958
2001 WRX (GC8)
Default Straightening Pinch welds
I would like to reinstall my side skirts, but the pinch welds are pretty much folded over. They are covering the screw grommets on the bottom of the rocker. Has anyone had any luck with straightening these? I tried bending them up with a pair of vice grips but that seems like it would take a long time and a lot of effort. Is there a better way? Could I cut them off and weld over the seam? I always thought a set of jacking rails would be nice on this car.
Ideas, comments and pictures would be great.
Jeff
jeffg is offline   Reply With Quote
Old 05-30-2011, 04:47 PM   #2
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
im looking for an answer to this question too.. my pinch seams are destroyed from the billions of times i have jacked my car up
olsen726 is offline   Reply With Quote
Old 05-30-2011, 08:04 PM   #3
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
You would pretty much have to remove the skirt, and interior. That way you can heat it and straighten it with flat vise grips and a hammer and dolly.
scby rex is offline   Reply With Quote
Old 05-31-2011, 12:12 AM   #4
jeffg
Member#: 2958
2001 WRX (GC8)
I was able to get the skirts mounted today after several hours with a BFH and a punch. It was painful and the seams dont "look" good, but it worked. Some of the seams were folded completely over and tight up against the rocker. It sucked.
Old 05-31-2011, 03:53 PM   #5
tyrel.boyce
Member#: 270178
2002 Subaru WRB
380HP stock motor HTA68
i had the same problem and i used the same method as you and it turned out okay as long as you don't overheat it you will be fine.
tyrel.boyce is offline   Reply With Quote
Old 05-31-2011, 04:41 PM   #6
Storm
Member#: 5218
96L Most Over-
Developed Beater
Not looking forward to this....but adding jacking rails will help keep it from happening any more....
Jay
Old 06-17-2011, 01:53 PM   #7
jaegmeister
Member#: 236092
2004 wrx full exhaus
vf48 aps big tmic nstuff
mine were knackered the whole length of the car, from a hydraulic lift used improperly. I straightened them with vice grips, no torch. My sideskirts were ruined as well, so I bought a used set. I would like to do rust prevention now, as the metal is exposed from the pliers.
jaegmeister is offline   Reply With Quote
Old 07-04-2011, 04:46 PM   #8
scby rex
Member#: 104878
02 wrxbastardchild
Jay
Yeah, me too, thats why Im removing the interior to do it. One piece of c channel from front to rear.
Old 07-04-2011, 07:00 PM   #9
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
If it's a street car ^^^^^, will that affect crumple zones at all?
BeBop86 is offline   Reply With Quote
Old 07-06-2011, 08:17 PM   #10
scby rex
Member#: 104878
02 wrxbastardchild
Its kinda a street car, pretty sure all the crumple zones are infront of the front wheels and behind the back wheels.
Old 07-18-2011, 08:26 AM   #11
kay95
Member#: 45494
95 impreza L awd
green
Correct.
Jay what are "jack plates"? I just use a block of wood to spread the weight on the pinch weld area and havent had a problem.
kay95 is offline   Reply With Quote
Old 07-22-2011, 03:16 PM   #12
jeffg
Member#: 2958
2001 WRX (GC8)
Basically its a piece of steel tube, welded or bolted along the length of the rockers to prevent damage to the rockers when jacking the car up.
Something like this
Old 07-22-2011, 09:16 PM   #13
Anthonydinatale
Member#: 273143
2004 WRX
That's what I did but connected them to both subframes so it's a brace also
Anthonydinatale is offline   Reply With Quote
Pinch weld jack adaptor with side skirts? veener79 Service & Maintenance 6 03-22-2009 09:12 PM
Pinch weld adaptor Eugene Onegin Brakes, Steering & Suspension 13 04-23-2008 09:31 PM
pinch weld adapter for jacking ShawnRS Vancouver Impreza Club Forum -- VIC 9 06-11-2007 05:51 AM
Bent OEM pinch weld jack point. seattleswimboy Service & Maintenance 10 11-11-2006 10:40 AM
Messed up my pinch welds Roy Lin Service & Maintenance 3 05-10-2005 05:15 PM
