Welcome to the North American Subaru Impreza Owners Club Friday January 30, 2015
Old 07-23-2002, 12:16 PM   #1
FLaBrit
Member#: 19135
2002 RS
Default Outback + WRX turbo? Will it work?
I have done some searching and don't seen to come up with an answer. I have an 2002 2.5 Legacy Outback and am trying to find out what stock parts off the WRX turbo system will bolt on to my car. I understand that I'm going to need a boost controller and run much less boost than a WRX but how much of the WRX's turbo system can I use on the Legacy?
Am I better spending more and getting a kit?
Thanks,
Jon
FLaBrit is offline   Reply With Quote
Old 07-23-2002, 02:01 PM   #2
AKSubie
Member#: 6214
92 Corrado SLC
www.motorsportsalaska.com
I would think you could probably take the intercooler, turbo, BOV, and ??? Definitely woul dneed new piping, boost controller, other electronics.
I have no idea what else could be transfered. You may want to also pose this question in the Aftermarket Forced Induction section.
edit: Just found this thread in the other forum. Look HERE
AKSubie is offline   Reply With Quote
Old 07-23-2002, 02:14 PM   #3
GTBGUY
Member#: 2003
'99 BGP Legacy GT
'98 QS Legacy L (auto)
FLaBrit - The only parts you'll really only be able to use from the WRX on your outback is the TD04 turbo, and that's a little small. To use the exhaust manifold etc, an x-member swap has to be done, however no one has confirmed fitment on the BE/BH Legacy.
You're much better off waiting for a Legacy specific kit. iON Performance will be out with two kits for the Legacy shortly, each catered to different needs.
GTBGUY is offline   Reply With Quote
Old 07-23-2002, 04:12 PM   #4
JoeT
Member#: 3956
2000 Turbo Legacy GT
Titanium
I'll let you know in September.
2000 Legacy GT (for now)
JDM Hood w/ hood scoop
WRX TD04 or VF23 or ????
WRX Intercooler
Maxim Works WRX Headers
ECU Tuning for engine management
This kit is being put together by Japanese Auto.
http://www.japanese-auto.com
No prices yet, my car is the guinea pig. I'll post pictures of the components shortly.
JoeT is offline   Reply With Quote
Old 07-23-2002, 10:59 PM   #5
Paul H
Member#: 21842
2004 WRX Wagon
Black with Dents
I'll let you know in Oct.
2001 Outback VDC
H6 (stock 212 hp N/A)
WRX intercooler
custom exhaust
hood scoop (if I cannot get the intercooler infront of the rad)
STI vs5 turbo
ECU tuning for engine management
This is also being put together by Japanese Auto.
Paul H is offline   Reply With Quote
Old 07-23-2002, 11:35 PM   #6
etam
Member#: 439
www
Joe and Paul, you guys all go turbo and leave me behind where is my lotto ticket? or my 100 shares of nortel (a years ago)....
etam is offline   Reply With Quote
Old 07-24-2002, 12:52 AM   #7
Scoobyriffic
Member#: 14499
2000 Kona Caldera
1998 Specialized Allez
All those are worth about $200. Oh god that is so sad
Scoobyriffic is offline   Reply With Quote
Old 07-25-2002, 02:15 PM   #8
FLaBrit
Member#: 19135
2002 RS
Thanks for the input and the stock advice guys! I was hoping to get away with as much WRX 2nd hand stuff as possible as it seems like you can pick up all the WRX stuff for less than $1000 + some electronics I was hoping <$2000 when I'm done....but it appears not to be that simple
Old 07-25-2002, 02:31 PM   #9
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
I remember another post similar to this. Someone posted the effeciency charts for the stock wrx turbo and it was a really bad match for the 2.5 liter engine. Ill try to find it.
2005 WRX Wagon springs on 2006 WRX Sedan..Will it work? Silver on Blacks Brakes, Steering & Suspension 4 01-09-2009 08:32 PM
EJ25 swap for EJ20 twin turbo..Will it work? bushey83 Built Motor Discussion 6 01-31-2008 06:28 PM
05 Legacy turbo will it work SlverEJ20 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-26-2008 08:23 PM
i have a mits 20G turbo will it work on my car?? 01G_WRX_02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 07-26-2005 11:49 AM
16x8 45 offset on a WRX sedan. Will it work? boxerT Brakes, Steering & Suspension 4 07-09-2002 02:15 PM
