Old 07-23-2002, 11:26 AM   #1
Tim Smith
Member#: 19147
2002 Impreza RS
Alpine White
Default Adjusting tach signal wire.....
Couldn't find the answer.
If I added a small resister to the tach wire on my '02 2.5 would that allow the motor to pull past the stock red line? I want to get some cams that will move the power to the stock redline and would like to be able to go past the by about 400 RPM. So I would like my redline to be in the 6600-6750 range. How would this affect the cruising charactistics of the eninge? Would it just think that my engine is always underload becasue the ECU is a smidge behind?
Tim
Tim Smith is offline   Reply With Quote
Old 07-23-2002, 02:06 PM   #2
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
I dont think it works that way. Isnt the signal just a pulse so say 6000rpm equals 100 pulses a second? If you just stuck a resistor in it might not get a reading at all depending on value.
Perhaps Im mistaken?
Old 07-23-2002, 02:09 PM   #3
Tim Smith
Member#: 19147
2002 Impreza RS
Alpine White
You are absolutely right and I knew that, just having a bad day. Thanks.
Old 07-23-2002, 02:23 PM   #4
Reciprocity
Member#: 1165
2012 dcrawford died
for your sins
Nah, you aren't having a bad day...ya thought of doing a clever tricky thing. That's all good.
It just didn't work!
NC
Reciprocity is offline   Reply With Quote
Tach output signal wire nwindyz Electrical & Lighting 1 05-01-2007 08:30 PM
Tach signal for shift light? jeff22 Electrical & Lighting 1 04-05-2004 10:15 PM
Tsport rev light install tach signal ? The Donnn Electrical & Lighting 0 05-09-2003 06:15 PM
Tach signal 2Rexhouse Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-04-2002 08:33 PM
Another question: Frequency of Tach signal? #522 Normally Aspirated Powertrain 0 09-26-2002 12:39 AM
