Welcome to the North American Subaru Impreza Owners Club Tuesday August 23, 2016
Old 07-13-2016, 04:15 PM   #1
Brodin
Member#: 449524
1997 GF8
RED
Subaru Stars Junkyard MY97 GF8
Friday July 8th 2016 I bought a 1997 Impreza WRX Wagon from the junkyard. It was junked because of a bad harmonic balancer and a few other little things.
Here is my thread to show my progress!
The bay is a little rough, I have the balancer on order along with the other little things I need!
Thanks for lookin'
Brodin is offline   Reply With Quote
Old 07-14-2016, 03:26 PM   #2
Brodin
Member#: 449524
1997 GF8
RED
Subaru Stars
Since I am still waiting on the parts to come in a cleaned up the grimey ass center console [IMG][/IMG]
Also finding out that the GF8 has a Kenwood KVT512 DVD Player w/ Navi is pretty crazy... I updated the old firmware and cleaned it up.
[IMG][/IMG]
Til' next time.
Old 07-20-2016, 02:34 AM   #3
Brodin
Member#: 449524
1997 GF8
RED
UPDATE:
So removed plastics found this bad boy.
Then also went to see if it's in time..
Still waiting for parts. Going to compression test it on Friday and see what's up. Timing is a little off which is okay.
Took off this ratty ass top mount to clean it up a little.
Plan if compression is good. Order new belt, water pump, woodruff key & thermostat and wait for parts lol and align the hashes when the belt is off.
Old 07-24-2016, 03:47 AM   #4
Brodin
Member#: 449524
1997 GF8
RED
Compression Test:
Piston 1: 135
Piston 3: 140
Piston 2: 140
Piston 4: 140
[IMG][/IMG]
Still waiting on timing belt kit..
Old 07-24-2016, 04:36 AM   #5
Brodin
Member#: 449524
1997 GF8
RED
Compression Test:
Piston 1: 135
Piston 3: 140
Piston 2: 140
Piston 4: 140
[IMG][/IMG]
Old 07-24-2016, 08:52 AM   #6
lktaylor72
Member#: 203159
2008 WRX - Stage 2
Looks like a fun project!!
lktaylor72 is offline   Reply With Quote
Old 07-24-2016, 09:45 AM   #7
Brodin
Member#: 449524
1997 GF8
RED
It's honestly been fun learning how to do all this stuff for the first time. It's pretty nerve-racking but it all seems pretty simple man
Old 07-24-2016, 11:47 AM   #8
shakur45
Member#: 165106
2017 WRX
Gray
Glad it's working out for you! Might want to think about replacing that tmic, it's looking a little rough.
shakur45 is offline   Reply With Quote
Old 07-24-2016, 12:13 PM   #9
Brodin
Member#: 449524
1997 GF8
RED
Trying to pick up a ver5 sti tmic!
Old 07-25-2016, 08:14 AM   #10
Brodin
Member#: 449524
1997 GF8
RED
New balancer and key came in!
Now just waiting for timing belt kit!
Old 07-25-2016, 09:11 AM   #11
robschilke
Member#: 397553
2017 STI
Dark Gray Metallic
Sweet thread. What are your end goals with this puppy?
robschilke is offline   Reply With Quote
Old 07-25-2016, 12:24 PM   #12
Brodin
Member#: 449524
1997 GF8
RED
I am leaving Germany next June so nothing crazy I just want to make it reliable until then and I don't know the previous maintenence that's been done besides the dealership service that ended at 100k kms and it's at 175k now. So I'm just replacing what needs to be replaced. Next is the timing belt and the componets along with the kit. The woodruff key is trash so I might do an oil pump and oil seal as well. My end game is to flip it because it was only 300$ but thanks man for checking out the thread. I'm new to forums and new to car maintenence tho i work on f16 engines as my job lol gotta start somewhere!
Old 07-28-2016, 12:32 PM   #13
Brodin
Member#: 449524
1997 GF8
RED
Impreza GC8
New Discovers with the GF8....
The turbo inlet is trash...
**** removing this ****. I removed the P/S pump because I wanted to..
Turbo Inlet..
All together.
recirculating valve is toast... YAAAAYYYY
water temp sensor is toast **** yeah
a dirty dick td04
How the bay looks.. oh yeah removed radiator. its full of ****.
So yeah today was eventful.. to replace more parts and getting rid of boost leaks...
That's all for today bros.
Old 07-29-2016, 07:08 PM   #14
Brodin
Member#: 449524
1997 GF8
RED
JDM GOODIES...
a buddy of mine is leaving and his 95 WRX Sedan JDM Spec is broken and
I got a chance to be first at getting dibs on parts.
Picked up brand new timing belt kit with pullies and idlers.
- Water Pump
- Thermostat
- New radiator
- Coolant Reservoir tank
- center console cubby hole.
- Blitz Boost Gauge
- Nardi Wheel.
today was a good day.
Still looking for turbo inlet and stock bypass valve (which will be hard to get)
so I might invest in a turbosmart bypass valve.
peace out bros.
Old 07-29-2016, 08:38 PM   #15
shakur45
Member#: 165106
2017 WRX
Gray
Originally Posted by Brodin View Post
+1 for being a boss and doing engine work barefooted.
Old 08-14-2016, 08:35 PM   #16
Brodin
Member#: 449524
1997 GF8
RED
So finally got around taking this timing belt off and replace the pullies and idlers and water pump!
And finding out that someone installed the water pump without the thermostat...
New Waterpump
Cleaned up thermostat housing
Had some time to try and fix these bent ass fins on the top mount. Finding a decent newish top mount that's not breaking my bank is difficult.
Still wanting to get into the smaller pieces
Looks a little better..
Next update should be belt, pullies, idlers, cam gears back in timing, woodruff key and v2 nardi wheel installed and replaced!
Later Bros
