Old 05-15-2012, 06:00 PM   #301
arf80
Member#: 125580
2011 WRX 5dr
I'm also curious how you broke a forged piston instead of losing a rod or bearing, etc.
arf80 is offline   Reply With Quote
Old 05-15-2012, 07:06 PM   #302
leonbmx
Member#: 82864
2005 MPS Wagon HTA35
Domtuned Stage $$$$$
Originally Posted by alcoolaid View Post
Hahaha. Thanks man. I try to do whatever I can... mostly to save $.
I'm sure you can find some sort of wing element out there and make custom mounts out of aluminum to mount onto your hatch/roof.
I'm pretty sure I'm just going to run fog light covers for the track and zip tie the duct hose on when I'm swapping over to the track wheels. Too risky if something starts dangling when I'm driving on the street making tight turns a hose might catch or something.
For sure man! Let me know when you plan to come out. If I can get the car fixed fast enough I want to be able to go to the turn2lapping.com event again on June 1st.
That's where the roo ducts come in handy, less hose to get tangled up... (http://rooducts.randyzimmer.com/) and (http://www.randyzimmer.com/carbon/airducts/). I have the ABS ones and they look pretty cool.
I bought an APR Drag wing from a friend of mine in CA who had it on his time attack focus and that's on there now... looks a bit ricey, but function over looks!
My engine is being dropped in next week, so all I need now is to finish installing my fire suppression, aquamist HFS-4 and killswitch and I'm ready to break 'r in!
Not sure if I'll be able to make June 1st (or if you even are, for that matter ), but the next one I'll try to be there!
Are you going to that Ridge Motorsports Park event the end of June? (http://forums.nasioc.com/forums/show....php?t=2347499)
leonbmx is offline   Reply With Quote
Old 05-15-2012, 08:16 PM   #303
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
Originally Posted by soon2bblackongold View Post
how many miles did this motor last? (obviously at 600whp and track duty)
anything you notice different about that race day and did you hear it detonate? anything you can think of to help future folks not have the same fate? 600whp is a lot for a 4cyl, how about you use a h6
do you know what broke yet? sounds like a ringland too, though they aren't supposed to go on a nice piston and ring set...
your car is nuts man, mad respek!
I think somewhere between 18-19,000 miles on the short block. Heads had maybe like 9,000 miles. I just filled up a full tank of 92 octane at the Arco gas station. After that it was hesitating under boost. Pretty sure when I pull the motor out I'm going to see pre-ignition or a melted piston. I felt it hesitating and I should have pulled off the track at that point but I kept going... oh well! We will find out soon enough.
Oh damn that looks sick. But $400???!?
Nice, can't wait to see the car back on the road.
That event seems quite expensive. Probably going to go with this group: http://ridgeracingschool.com/
Do 4 events in a year and the 5th one is free! $250 bucks too.
alcoolaid is offline   Reply With Quote
Old 05-15-2012, 08:19 PM   #304
alcoolaid
Member#: 134949
'07 SWP STi
This is the second time I damaged a piston. Last time meth failsafe didn't work because of Vi-pec firmware upgrade that wasn't fully tested... so EGT went super high and piston melted a bit. I'm assuming detonation this time.
I've always been super anal about my oil clearances on my bearings as well as my oil pressure so I'm always good in that department.
Old 05-15-2012, 10:56 PM   #305
microsnook
Member#: 313952
2006 STi
SGM DOM 3xt-r
Your car is sweet! wow
microsnook is offline   Reply With Quote
Old 05-15-2012, 11:20 PM   #306
WhatTurboLag?
Member#: 243992
2006 WRX TR
where are you getting air for the brake ducts?
WhatTurboLag? is offline   Reply With Quote
Old 05-16-2012, 12:17 AM   #307
alcoolaid
Member#: 134949
'07 SWP STi
No air right now
Still waiting for fog light covers
Old 05-16-2012, 01:16 AM   #308
sysfailur
Member#: 135993
08 AW STi GTX3071
V-Mount, 18x12, 335 R888
This thread gave me wood.
sysfailur is offline   Reply With Quote
Old 05-16-2012, 02:35 AM   #309
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
i put money on cracked sleeve!
Bariga is offline   Reply With Quote
Old 05-16-2012, 02:58 AM   #310
alcoolaid
Member#: 134949
'07 SWP STi
Not losing coolant
Old 05-16-2012, 04:14 AM   #311
SashaSasha
Member#: 241828
2005 STI
How do yours look? What do you mean mine are from plastic?
http://forums.nasioc.com/forums/show...2194067&page=5
SashaSasha is offline   Reply With Quote
Old 05-16-2012, 10:41 AM   #312
KillerRabbit
Member#: 184772
2004 WRX
World Rally Blue
Thanks man!
Figure out why you keeping having ring land failures then fix it!
I'm still running around with low comp on cylinder 4 till I can get my spare block figured out. Waiting to hear from Dom if he has one available sleeved block right now I can take and swap for mine.
Right now just ordering a new piston, main and rod bearings, piston rings, case bolts, gasket kit, etc to swap things over once I get the new block.
Should be back up and running soon if parts come quickly
Hopefully everything works out for you! My 1st motor was due to an off tune, something wasnt right, i was tuning it my self and it ran good for awhile then one day i got on it hard and started having issues. The second block had a ringland failure due to a lean condition when my turbo inlet collapsed. Sad day but i was really wanting to go rotated anyways.
Im gonna kinda use a similar setup like yours, turbo wise at least. That sx300 spools pretty quick for the size ive been told. True or not true? I figure your hitting full boost at 4k-4500?
KillerRabbit is offline   Reply With Quote
Old 05-16-2012, 12:13 PM   #313
WhatTurboLag?
Member#: 243992
2006 WRX TR
No air right now
im un decided if i am going to run one fog light cover and make an air intake (running speed density) or dual and get brake ducts. im going to run out of space soon in that area as i plan on having my external gate exit out the side of the bumper right there too
Old 05-16-2012, 12:46 PM   #314
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Not losing coolant
I wasn't loosing coolant either!
Old 05-16-2012, 01:05 PM   #315
alcoolaid
Member#: 134949
'07 SWP STi
Originally Posted by SashaSasha View Post
Oh damn that look sick. Can't wait to see how it looks when it's painted. How much wider? 40? 45mm?
Yeah it spools quick. 4th gear pull one time I hit full boost in the 3800-3900 range.
External gate out the side? wow! lol that is going to be loud as hell
Interesting! I'll be in for a surprise when I take the head off that's for sure.
Old 05-16-2012, 03:23 PM   #316
Loubaru
Member#: 155489
07 STi
Wait... you didn't run Arco gas on the track did you?
Loubaru is offline   Reply With Quote
Old 05-16-2012, 03:25 PM   #317
alcoolaid
Member#: 134949
'07 SWP STi
Previous tank was 76... which I've run many times and on the dyno. No problems.
Filled Arco and the rest is history
Old 05-16-2012, 03:59 PM   #318
jfdavis22885
Member#: 145716
08 Lexus IS 350
05 WRB WRX Stg2 (Sold)
well this thread made my slow day at work MUCH better
jfdavis22885 is offline   Reply With Quote
Old 05-16-2012, 04:49 PM   #319
WhatTurboLag?
Member#: 243992
2006 WRX TR
think something like this
Old 05-16-2012, 04:52 PM   #320
alcoolaid
Member#: 134949
'07 SWP STi
definitely don't want to be on your passenger side when you have launch control on hahaha
Old 05-16-2012, 11:29 PM   #321
WhatTurboLag?
Member#: 243992
2006 WRX TR
hahahahaha yep! im still on a stock manifold so i gotta look into it more. next time im at work im going to get on a lift and figure it out. will most likely be something for me to do when i go rotated (pte 5858 waterless dbb billet) next year. the thing is i really want to run a killer b header or full race, but full race is out of my dollar range and killer b dosnt make a rotated up pipe to my knowlege.
Old 05-17-2012, 09:00 PM   #322
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
That really sucks about the motor dude! i hope you have better success with the next one. have you thought about going with one of Doms longrod motors?
waynoSTI is offline   Reply With Quote
Old 05-17-2012, 11:47 PM   #323
omgawg
Member#: 304967
2006 frankenSTi
Came across your videos on youtube along time ago, frigging love your build man!
omgawg is offline   Reply With Quote
Old 05-18-2012, 12:21 AM   #324
alcoolaid
Member#: 134949
'07 SWP STi
Yeah I always wanted a long rod 2.5 from Dom but my rods are still good as well as 3 pistons Setup has provided what I need so far. Maybe down the road when I have more money.
Thanks!
Old 05-18-2012, 12:41 AM   #325
N8F
Member#: 305804
2006 Impreza WRX
Sometimes I read this and just start sobbing uncontrollably out of awe and jealousy. Beautiful car.
N8F is offline   Reply With Quote
04 STi Weekend Warrior Blazin Brakes, Steering & Suspension 2 03-07-2008 02:10 PM
So I just found out I need hand surgery tomorrow...Weekend warriors be careful! Neek Off-Topic 45 12-12-2006 09:30 AM
Attention Car Enthusiast’s, Car clubs, & Weekend Warriors GotTurbo Tri-State Area Forum 15 08-11-2006 02:46 PM
Optimum weekend warrior suspension set up? EarlQHan Brakes, Steering & Suspension 15 11-03-2005 01:18 AM
What pads are folks using for daily driver/weekend warrior? Mephiska Brakes, Steering & Suspension 6 06-28-2002 02:08 PM
