Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 07-30-2012, 06:27 PM   #451
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
Ok I entered because of you guys haha
alcoolaid is offline   Reply With Quote
Old 07-30-2012, 09:27 PM   #452
SuaveCougarBait
Member#: 255092
2007 WRX Limited
Garnet Red Peal (33j) e85
good deal, you have my vote!
SuaveCougarBait is offline   Reply With Quote
Old 07-30-2012, 11:54 PM   #453
Heedlessone
Member#: 254130
1993 LS1 RX7
Glad to see this car up and running again. I Youtube stalk you, by the way.
Heedlessone is offline   Reply With Quote
Old 07-31-2012, 01:51 AM   #454
zcarter0792
Member#: 309445
2006 STi
CGM
Originally Posted by subie bro View Post
What kind of bov you got? Sounds sick
been wondering this for a while too. sounds amazing.
zcarter0792 is offline   Reply With Quote
Old 07-31-2012, 02:10 AM   #455
Dinng
Member#: 327437
good job man
really like this gen in white and ur aggressive wing
Dinng is offline   Reply With Quote
Old 08-08-2012, 03:03 AM   #456
alcoolaid
Member#: 134949
'07 SWP STi
Pacific raceway tomorrow with new motor!
Dialed in an extra 0.5 camber in the front. -2.75 to -3.25.
Also raised rear ride height 0.125" and went from 8 degrees aoa on the wing to 7.
I'll see if this helps with the understeer I'm having mid corner
Old 08-08-2012, 09:57 AM   #457
sjs0433
Member#: 86061
You get the front overfenders on yet?
sjs0433 is offline   Reply With Quote
Old 08-08-2012, 10:16 AM   #458
todeswalzer
Member#: 191495
'05 WRB GTX3071R
JDM V8 EJ207 USDM 6MT
Originally Posted by alcoolaid
My ears were ringing after this pull through the wall
Video Link: http://www.youtube.com/watch?v=M-aA9JtM2uo
So that's what a black hole sounds like
todeswalzer is offline   Reply With Quote
Old 08-09-2012, 02:54 AM   #459
alcoolaid
Member#: 134949
'07 SWP STi
Not yet, been too busy.
Old 08-09-2012, 03:03 AM   #460
alcoolaid
Member#: 134949
'07 SWP STi
So track day today didn't go so well. I'm pretty sure I have a blown head gasket(s).
A few laps into the day, car suddenly snap oversteered on me. Thought I blew a tire or something then when I got into the pits, tires were fine. Walked to the front, saw coolant coming off my splitter. Pop the hood and coolant everywhere.
Upper rad hose connecting to the radiator slid off about 1/2" and some coolant was coming out of it. Don't 100% remember if coolant was coming out of the overflow or not. But I did see bubbles.
Did a coolant pressure test and found that the stock spring clamp on the rad hose wasn't tight enough anymore and was leaking coolant. Changed clamp out and all is good. Holds 17psi for more than 5 mins.
Drove around, boosts fine on the hwy, streets, etc. Thought to myself it wasn't the head gasket that blew and over pressurized the system so much to make the radiator hose slide out. Was relieved until I came home, popped the hood with the engine running and saw bubbles slowly coming out in the overflow.
New sleeved block by dan benson (say sleeves will never drop).
Freshly decked heads but they were repaired. Pretty much a polished finish on the heads.
Not sure of the finish on the block. Cometic .040 inch head gaskets. ARP 625+ head studs @ 110/105 ft.lbs
Cometic's to blame? Finish on the block wrong? Head repair wasn't good enough and bad sealing? Was fine at 25psi on the dyno for a few pulls but once I hit the track, 25psi for long periods of time made it go? No clue....
Only 1200 miles on the motor. Very frustrated!
Old 08-09-2012, 10:33 AM   #461
sjs0433
Member#: 86061
I've always heard such mixed things about cometic gaskets.
Old 08-09-2012, 11:40 AM   #462
M4c0770
Member#: 225851
07 Spec Wannabe
Limited in San Remo Red
^Me too, Some say the get burned so easily.. But I have cometic since 2010 (knocking wood) but the car only sees drag, 1/2 mile run events and weekend drivings with occasionally road race.
A very respected Suby builder I very well know only uses OEM gaskets.
M4c0770 is offline   Reply With Quote
Old 08-09-2012, 12:04 PM   #463
alcoolaid
Member#: 134949
'07 SWP STi
There was some intermittent mis-firing at high load. I think it was my IAT sensor going as I've gone through like 3 of them in 4 years.
The mis-firing may have caused the hg to get damaged but I can't believe it was that easy.
This is the first time I used cometics because oem doesn't make anything thicker and now I have this issue
My previous motors had gone through much worse and never had a hg fail on me.
Old 08-09-2012, 12:39 PM   #464
berdugo
Member#: 163108
07 EuroDM STi 2.5L
What IAT are you using? Is it the oem together with the MAF sensor?
berdugo is offline   Reply With Quote
Old 08-09-2012, 12:55 PM   #465
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Arthur do some more trouble shooting before you come to final conclusion, maybe do compression check? You just scared the **** out of me now because i have same engine setup!
Bariga is offline   Reply With Quote
Old 08-09-2012, 01:02 PM   #466
alcoolaid
Member#: 134949
'07 SWP STi
Gm/ac delco open element
Old 08-09-2012, 01:29 PM   #467
alcoolaid
Member#: 134949
'07 SWP STi
Pretty sure it's hg. Bubbles coming out of overflow ain't good. Unless one of my rad caps are bad.
I parked car for dinner on my way home from the track last night and it started a little different from what i remember. Possibly small amount of coolant in cylinder...
I'll check upper coolant tank today after work to see if I lost any coolant with car sitting overnight.
Old 08-09-2012, 01:38 PM   #468
juanmedina
Member#: 133146
07 FPgreen 7.37@95
WRX VF39+E85 12.0, 121mph
That sucks man, it seems that is either the cometic gaskets or the sleeves..... I would say the sleeves since you were running custom age head studs.
GL
Old 08-09-2012, 01:47 PM   #469
WhatTurboLag?
Member#: 243992
2006 WRX TR
That sucks to hear man, road racing is hard on engines! Kinda scares me to road race mine even though It's just a Peewee old vf39
Question for ya though, the other day I finally broke my 5 speed and I'm putting in a 09 6mt so it had the longer gears like your 07. How do you like them for road racing? Moreso back when you had the old 2.5? I'm a tad worried I will bog in 2nd out of corners with the longer gears?
WhatTurboLag? is offline   Reply With Quote
Old 08-09-2012, 02:21 PM   #470
berdugo
Member#: 163108
07 EuroDM STi 2.5L
At least that is much cheaper than oem MAF sensor
I have 2 spares for that sensor.
Old 08-09-2012, 02:46 PM   #471
alcoolaid
Member#: 134949
'07 SWP STi
GL
Dan benson says they wont drop but we will see when I open it up next week when im done my exams.
Old 08-09-2012, 02:48 PM   #472
alcoolaid
Member#: 134949
'07 SWP STi
You won't bog that's for sure. Depends what track you're at too. With a small turbo you're going to have a lot of torque down low so I wouldn't worry about it. The 2nd gear on pre 07 sti's was super short. You literally stay in it for like 1 second when you're driving on the street lol.
Old 08-09-2012, 02:49 PM   #473
alcoolaid
Member#: 134949
'07 SWP STi
Yeah much cheaper. I don't know why they keep breaking. People say its from the vibration the element is subjected too with high air flow. Some people fill the base of the sensor inside with a sensor safe epoxy to prevent vibration of the element inside. Hopefully that will fix it so I don't have to keep changing this thing!
And sorry guys for all the posts. On my cell at work and can't multi quote lol
Old 08-09-2012, 03:01 PM   #474
vica153
Member#: 76586
1994 GF6
Head gaskets crapping out for no reason would be pretty low on my list of possibilities.
25psi doesn't seem like nearly enough to stretch headstuds, especially extra beefy headstuds.
If the engine didn't get overheated, then I think warped heads aren't likely and you're left with the sleeves.
What does "repaired" mean on the heads?
vica153 is offline   Reply With Quote
Old 08-09-2012, 03:19 PM   #475
alcoolaid
Member#: 134949
'07 SWP STi
Yes, never overheated.
Previous pistons had a crown piece break off damaging the heads a bit. Pitting on the quench area on the head. The holes were welded and head decked to make it as smooth as possible. It turned up pretty nice actually.
I think there is a post of the pics a few pages back showing the damage.
04 STi Weekend Warrior Blazin Brakes, Steering & Suspension 2 03-07-2008 03:10 PM
So I just found out I need hand surgery tomorrow...Weekend warriors be careful! Neek Off-Topic 45 12-12-2006 10:30 AM
Attention Car Enthusiast’s, Car clubs, & Weekend Warriors GotTurbo Tri-State Area Forum 15 08-11-2006 03:46 PM
Optimum weekend warrior suspension set up? EarlQHan Brakes, Steering & Suspension 15 11-03-2005 02:18 AM
What pads are folks using for daily driver/weekend warrior? Mephiska Brakes, Steering & Suspension 6 06-28-2002 03:08 PM
