Old 02-06-2013, 04:30 AM   #726
WhatTurboLag?
Member#: 243992
2006 WRX TR
Originally Posted by alcoolaid View Post
I got a quieter exhaust and the car felt slower lol. I think when you're nearing 30 pounds of boost on a 68 lb/min turbo you have to forget about noise. I do wish I could get something quieter for around town though.
I thought about a cut out but don't want to add anymore gizmo's to the car. I heard they fail and leak over time too.
Sound performance boost activated cutout. Best out there, simple, and will not leak. Ask me how I know?
WhatTurboLag? is offline   Reply With Quote
Old 02-06-2013, 04:40 AM   #727
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
I remember when that came out. Not cheap @ 400 bones
alcoolaid is offline   Reply With Quote
Old 02-06-2013, 06:18 AM   #728
alcoolaid
Member#: 134949
'07 SWP STi
I know it's along shot but does anyone know where to buy Goodridge 910 hose other than from Pegasus Racing?
https://www.pegasusautoracing.com/pr...p?Product=3490
Anyone who can source it cheaper or know anyone that can get it cheaper?
Old 02-06-2013, 08:00 AM   #729
berdugo
Member#: 163108
07 EuroDM STi 2.5L
Try MSI if he can sell you cheaper than pegasus racing.
berdugo is offline   Reply With Quote
Old 02-06-2013, 08:01 AM   #730
WhatTurboLag?
Member#: 243992
2006 WRX TR
Not cheap yes. But it can take your abuse and then some. Can easily stand up to als!!!
Old 02-06-2013, 07:34 PM   #731
alcoolaid
Member#: 134949
'07 SWP STi
I will ask them too.
Sent an email to http://www.dragracehose.com
I read they have sales 15-20% so I'm sure he can beat pegasus.
Old 02-09-2013, 08:35 PM   #732
M4c0770
Member#: 225851
07 Spec Wannabe
Limited in San Remo Red
Arthur I found your brake set up LoL. Double 4 piston pompers crazyness.
Btw. U know I am kidding right?
M4c0770 is offline   Reply With Quote
Old 02-11-2013, 02:14 AM   #733
alcoolaid
Member#: 134949
'07 SWP STi
Originally Posted by M4c0770 View Post
[https://www.google.com/search?hl=en&...8xq7kjNxA#i=98]
I don't see anything?
Old 02-11-2013, 06:18 AM   #734
M4c0770
Member#: 225851
07 Spec Wannabe
What about now?
Old 02-11-2013, 06:18 AM   #735
M4c0770
Member#: 225851
07 Spec Wannabe
Old 02-11-2013, 11:50 PM   #736
alcoolaid
Member#: 134949
'07 SWP STi
LOL. don't know what to think of that hahaha
Old 02-11-2013, 11:51 PM   #737
alcoolaid
Member#: 134949
'07 SWP STi
Finally got to do some tig welding today. 10 mins of welding time so far.
16g 304ss. This is with like 40-42 amps. I think it's still too much? My friend with an old miller transformer machine is using 50 amps on the same metal. Maybe inverter machines have more output? No clue...
Old 02-13-2013, 03:50 AM   #738
alcoolaid
Member#: 134949
'07 SWP STi
Did some more practice today.
Room where the magic happens
First time tigging on AC. Any welding experts here who can give me feedback?
This is 1/16" angle on 1/8" aluminum bar. 110 amps
Old 02-13-2013, 09:09 AM   #739
J3SST3R
Member#: 298926
2007 USDM STI
Satin White Pearl
Looking good!
I'm no welding expert, do it in my garage like you, but how much penetration you have there? Pictures makes it look like the bead is sitting on top or higher on the surface.
Maybe some more heat/amps will help?
Again just based off the picture, but well done nice and clean.
J3SST3R is offline   Reply With Quote
Old 02-13-2013, 05:31 PM   #740
j r3s0
Member#: 321412
2006 Sti
CGM
just went through every page on this build thread and wow!!
its all I can seriously say.
don't know if i missed a part but did you end up going with the cosworth hgs?
Love the car man gl with everything you do with it in the future
j r3s0 is offline   Reply With Quote
Old 02-14-2013, 02:09 AM   #741
alcoolaid
Member#: 134949
'07 SWP STi
Not yet, MPS has been very busy. I'll be bringing the motor down soon.
Old 02-14-2013, 02:24 AM   #742
alcoolaid
Member#: 134949
'07 SWP STi
Got a chance to do some PC logging and load it into virtual dyno. Only did two pulls. Took me a while to get the speed sensor reading exactly as it should. Verified via GPS to make sure it was 100% spot on.
Red line was done first to 7400rpm.
Blue line was done second to 8100rpm.
I don't know why boost was down for the second run. Was sitting on the side of the road for a while and was only rolling for like 30s before I did the pull. IAT was already down though. First run was leaner too... wonder if I have a clogged injector. Car does idle weird sometimes. Will have to check. Anyways, here are the runs.
Edit: Got a chance to analyze the data. Red line was running lean between 4k and 6k. Even hit 12.1 AF (target is 11.2) at one point and cylinder 3 and 4 wasn't happy. Engine noise jumped from 30 -> 470. Blue line is down 2-3 psi. Still trying to figure out why. Ignition angle was pretty much the same and boost target was the same as well. No ECT or IAT boost trims. Maybe the header/turbo was hotter on the first pull? Need to tweak the fueling for sure. Fuel filter could be dirty.. it is 3 years old.
Old 02-19-2013, 02:53 AM   #743
alcoolaid
Member#: 134949
'07 SWP STi
Was in Portland with the girlfriend for valentines and did some tax free shopping while I was down there. Great food in downtown Portland! Didn't get to hit the sand dunes because of the weather.
Drove to Columbia River Mandrel and picked up pipes at their location on the way down to Portland. Cool little facility. I actually thought it was going to be much bigger.
Then stopped by to see Troy @ Swag Off Road. Swag Off Road
Got myself a vertical portaband table.
Even has a cool built in LED!
Stay tuned for cool stuff I hope to make
Old 02-19-2013, 08:25 AM   #744
blakkboxer
Member#: 167244
2k3 WRX MBP
Clean & Simple
that's awesome!
blakkboxer is offline   Reply With Quote
Old 02-20-2013, 03:12 PM   #745
alcoolaid
Member#: 134949
'07 SWP STi
Got some 2.5" aluminum mandrel bends. Ready to make some new intercooler pipes!
Also picked up some washer fluid at home depot. Water meth!!!
Old 02-20-2013, 04:10 PM   #746
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
lol tough u got 600 whp ?
Bariga is offline   Reply With Quote
Old 02-20-2013, 04:19 PM   #747
alcoolaid
Member#: 134949
'07 SWP STi
Doms dyno lied 2 me. Lol
Crank up boost back to 28-29 after I change hg.
Old 02-20-2013, 04:27 PM   #748
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
virtual dyno seems to be the best tool to compare numbers...
Old 02-20-2013, 04:39 PM   #749
alcoolaid
Member#: 134949
'07 SWP STi
True. Took me a while to calibrate speed.
Vipec has it at 260. You told me yours was 250. I ended up using 255 to get it spot on.
A difference there might skew numbers
Old 02-20-2013, 06:39 PM   #750
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
hmmm, thats why the orficer said i was going 65 and i wasnt
So what ever you set in there also reflects the gauge cluster reading?
Base map from my Plug in board for 2007 sti had it at 240
04 STi Weekend Warrior Blazin Brakes, Steering & Suspension 2 03-07-2008 02:10 PM
So I just found out I need hand surgery tomorrow...Weekend warriors be careful! Neek Off-Topic 45 12-12-2006 09:30 AM
Attention Car Enthusiast’s, Car clubs, & Weekend Warriors GotTurbo Tri-State Area Forum 15 08-11-2006 02:46 PM
Optimum weekend warrior suspension set up? EarlQHan Brakes, Steering & Suspension 15 11-03-2005 01:18 AM
What pads are folks using for daily driver/weekend warrior? Mephiska Brakes, Steering & Suspension 6 06-28-2002 02:08 PM
