Old 05-30-2001, 03:12 PM   #1
shifterkartracer
Member#: 6847
2005 LGT Limited
Post SCCA G Stock Rule Clarification
Alright, help a guy out here. My rule book is AWOL and I have a couple quick questions regarding GS in SOLO 2. Is it legal to remove the silencer? Is cat-back exhaust legal (or further)? Are computer mods legal?
Please only reply if you KNOW the answers. I'm trying to whoop some Type R a$$, so don't get me DQ'd. Thanks all.
shifterkartracer is offline   Reply With Quote
Old 05-30-2001, 03:37 PM   #2
KC
Member#: 442
16 SS
00 S2000
Post
GS..
Silencer removal... not legal (13.10 A - The engine air filter element may be removed or replaced. A replacement element which is taller than standard may not be used to hold the air cleaner cover open. No other components of the air induction system may be removed, replaced or modified.)
Catback... Legal (13.10 E - Any part of the exhaust system beyond (downstream from) the header/manifold or catalytic converter, if so equipped, may be substituted provided the system meets the requirements of 3.5. Stainless steel heat exchangers are permitted only if the physical dimensions and configuration remain unchanged. Modifications of any type, including additions to or removal of, the catalytic converters, thermal reactors, or any other pollution control devices in the exhaust system are not allowed and the system must be operable. Replacement catalytic converters must be OEM if the vehicle has not exceeded the 5-year/50,000 mile warranty period as mandated by the EPA. Converters must be of the same type and size and used in the same location as the original equipment converter(s). This does not allow for a high performance unit. If the vehicle has exceeded the 5 year/50,000 mile warranty period, replacement catalytic converters must be OEM-type as per Section 13.
Computer... not legal. (13.9 D - No changes are permitted to electronic engine management systems or their programming)
-kC
[This message has been edited by KC (edited May 30, 2001).]
KC is online now   Reply With Quote
Old 05-30-2001, 03:46 PM   #3
shifterkartracer
Member#: 6847
2005 LGT Limited
Post
Thanks KC. Got beat by a Type R on Monday and just wanted to make sure I was getting every edge I legally could. Dude was definitely fast - I'm no rookie and he beat me by over a second. Of course, I had only owned the car for a couple days. With a better alignment and a bit more practice with AWD, I'll get him next time.
Thanks again.
Old 05-31-2001, 04:45 AM   #4
LUME
Banned
Member#: 2641
2000 Impreza 2.5 RS
Dirt and Bird Poop
Post
get some AGX struts, change your air filter and plug wires, and get some some race rubber. These are also legal changes.
--Roy
LUME is offline   Reply With Quote
Old 05-31-2001, 06:34 AM   #5
Big C
Member#: 3586
2000 RSTI Rally Car
2012 STI SWP Hatch
Post
Going to be a bit tough to change the wires on a WRX
Big C is offline   Reply With Quote
Old 05-31-2001, 09:46 AM   #6
tomrichardson
Member#: 2672
1973 Porsche 914
Porsche Red
Post
LUME - Any filter other than stock is not legal.
tomrichardson is offline   Reply With Quote
Old 05-31-2001, 11:05 AM   #7
KC
Member#: 442
16 SS
00 S2000
Post
Tom .. read the 1st line again.
The filter ELEMENT *may* be replaced. (Ie K&N, ITG, etc... panel replacement filters that fit in the stock location and are of the same size). Or it may even be completely REMOVED... not a good idea to remove it tho....
But you can't swap out the air-box and put in a cone filter, nor can you remove any of the plastic before the box.
--kC
[This message has been edited by KC (edited May 31, 2001).]
Old 05-31-2001, 11:57 PM   #8
Gary (gg)
Member#: 179
98 2.5RS
Rally Blue
Post
Have you got R tires yet? Get a set of the 16 x 6.5 Legacy GT rims with some Hoosier 225/50R16's on it. That would be the first thing I do. Second is an alignment, do not just take it in and find that its within factory spec. Get as much negative camber as possible. Third, get a harness. Not the Schroth but a 3 inch 4-5 point camlock one to hold you in. Finally, seat time. Go to as many solos as you can.
Gary (gg) is offline   Reply With Quote
Old 06-01-2001, 04:45 AM   #9
shifterkartracer
Member#: 6847
2005 LGT Limited
Post
Thanks all. R-spec tires aren't an option though, I'm running TGS (street tire). Can anyone share their alignment specs. I assume as much negative camber up front as possible with factory adjustments. What about toe-in, out and what about the rear?
Old 06-02-2001, 07:49 AM   #10
Fitz
Member#: 1426
'07 335xi, '07 ZX6R
SV650 Race Bike
Post
Do a search in the suspension forum. I remember a post awhile back where a lot of the more prominent tuners posted their settings (Rallispec, Cobb, etc...) That might help you out.
Fitz
Fitz is offline   Reply With Quote
Old 06-03-2001, 02:25 PM   #11
Tangmere
Member#: 572
Post
SKR,
I use equal max neg camber up front, zero camber in the rear and 1/8" toe out front and rear. This way I can rotate the car with the throttle or the brakes.
Good luck, Mark
Tangmere is offline   Reply With Quote
Old 06-04-2001, 08:28 PM   #12
Fmdeadrick
Member#: 200
1999 Impreza 2.5RS
Post
SKR,
Was it Evan Moen in a yeller Type R. If so, he's been rally racing for a few years, and is quite fast in autox as well.
[email protected]
www.kartboy.com
Fmdeadrick is offline   Reply With Quote
Old 06-05-2001, 04:12 AM   #13
shifterkartracer
Member#: 6847
2005 LGT Limited
Post
Mark - nope it was Jeff Gunning in the Type R. I've been autocrossing for 7 years and this guy was SMOOTH. Oh well, I only had like 2.5 days of driving the WRX before the race. We'll see what happens next time.
STILL LOOKING FOR ALIGNMENT SPECS! Any others?
Old 06-05-2001, 05:43 AM   #14
TimStevens
Member#: 4817
2012 STI, '02 WRX
'91 MR2, '05 Speed Triple
Post
Check with COBB tuning... a friend used their specs and had some good results last weekend... not that he needed any help!
I believe it was 0 degrees caster and camber in the rear, and 1 degree caster and camber in the front, but don't quote me on that...
-tim
TimStevens is offline   Reply With Quote
Quick ST rule clarification sachilles Autocross 2 09-01-2009 10:41 AM
Rule clarification needed. "Questionable outfits" Davenow Off-Topic 1 02-28-2006 11:57 PM
SM Rule Clarification Uber Wagon Motorsports 7 11-19-2003 11:49 AM
who has a link to SCCA autocrossing class rules? jmott Texas Impreza Club Forum -- TXIC 5 08-18-2001 01:19 AM
SCCA Auto-X rules interpretation Section 8 Motorsports 0 05-30-2001 08:49 PM
