Old 06-02-2011, 10:40 AM   #1
faSTI666
Member#: 180204
2005 FXT Stg II 1/2
SSM
Default DP help
I was wondering if anyone could give me the dimensions and measurements and/or pics of the transmission bracket on a Titek DP for 02-07 WRX/STI MT. I need to fab one and dont know anywhere else to get this info. thanks
faSTI666 is offline   Reply With Quote
Old 06-02-2011, 10:03 PM   #2
paulpat
Member#: 237145
02 WRX
12 FXT
Same here. I bought a used dp with the bracket sheared off.
paulpat is offline   Reply With Quote
Old 06-02-2011, 11:32 PM   #3
AREA1320
Member#: 112508
Dont bother. Its not needed.
As proven by the bracket shearing off
AREA1320 is offline   Reply With Quote
Old 06-06-2011, 12:45 PM   #4
alx8283
Member#: 225024
2002 wrx
correct me if im wrong, but i feel that the trans bracket is necessary.
my line of thinking is in regards to exhausts with no flex section. with no flex section, the exhaust turns into a long arm, putting stress on the dp to turbo connection every time the exhaust moves side to side. this can be alleviated with stiffer exhaust hangers, but will not prevent all movement. a second mechanical fastening point (trans mount) seems like it would keep things a bit stiffer, and lessen the swing of the exhaust, thus lessening the stress on flange welds, or at least put stress on less expensive/necessary bits. not to mention that there's a good chance theres a really smart engineer somewhere at subaru that put that bracket there for a reason.
im not claiming to be %100 correct by any means, this is just my uneducated opinion. if im wrong, please tell me why i am.
to the op, if possible mount the dp and make a cardboard template.
alx8283 is offline   Reply With Quote
Old 06-06-2011, 05:03 PM   #5
paulpat
Member#: 237145
02 WRX
12 FXT
If the weld shears then there are some extreme forces on the exhaust. I don't think letting it swing around is a good idea. It could be done I guess and be fine.
Autospeed or Cobb dp, help me decide please... maestro Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 12-01-2004 08:29 PM
CEL on Turbo XS DP...help!!! imprezach Engine Management & Tuning 8 11-06-2003 10:08 AM
Any secrets on removing DP? Help johsti Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 10-29-2003 02:43 PM
Bellmouth DP help needed... westy66 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 08-01-2003 04:32 AM
dp help scrappydoo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 06-05-2003 07:09 PM
