Old 06-04-2011, 12:29 AM   #1
Motion Lab Tuning
Member#: 228856
Default Motion Lab Tuning, new 2011 STi - Big results - why a good tune is critical...
Shop: Motion Lab Tuning
Dyno Type: Dyno Dynamics
Boost: 23.5psi ----> 15psi
Fuel: 93 oct
Target AFR: NA
SAE Corrections: Default Corrections
Peak HP at RPM: 295whp @ 5500 RPMs
Peak Torque at RPM: 335wtq @ 3400 RPMs
Transmission: Stock 6-speed
Gear: 4rd
Fuel: 93oct Unleaded
Power Modifications:
- AEM CAI
- 3.0" Downpipe/midpipe (catless)
I'm very impressed with the new STi! So few mods and this power was able to be extracted. Notice we didn't use a 3-port BCS either as the factory BCS proved to be up to the task.
We performed several baselines with with the above mentioned mods on the factory tune. Obviously the non-tuned graph is a bit rough (and a little lean in spots). We mention this because we see so many auto enthusiasts throwing on mods without any real tuning performed. Following those pulls, we then got to work on getting some serious power down.
Enjoy!
FINAL "TUNED "GRAPH
[b]
BASELINE
GRAPH
TUNED VS BASELINE
BOOST: TUNED VS BASELINE
[b]
Added 4th gear pull on the street. Had the car for a little while earlier. Keep in mind, engine load is following WITH boost pressure. This car of course had the AEM intake so the MAFv and load are different from stock.
Here are some pics of the stock catback at the rear. As you can see, very small diameter piping.
Motion Lab Tuning is offline   Reply With Quote
Old 06-04-2011, 10:04 AM   #2
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
wow that looks great. I def agree with a tune after any modifications are done. sure the ecu can learn but it only goes so far.
On a side note what turbo does the new sti come with?
WhiteBgeye02 is offline   Reply With Quote
Old 06-04-2011, 10:52 AM   #3
Motion Lab Tuning
Member#: 228856
I believe they are still using the vf48 on the 2011.
Alex
Old 06-04-2011, 11:04 AM   #4
Motion Lab Tuning
Member#: 228856
Also just an FYI we have some more info on the car getting posted up later when Todd has a sec to sit down at the computer.
Alex
Old 06-04-2011, 05:47 PM   #5
synolimit
Member#: 225225
11 WRX
335HP, 394TQ, 93 VF52!!
Wow that turbo falls hard. Not sure if it's because the taper is so large but ouch. My max HP is at 5900rpm and drops 30hp to 6600rpm redline. Dropping almost 60hp from max to redline has to feel a little sad no? That lil snail needs some injectors for more boost top end
synolimit is offline   Reply With Quote
Old 06-04-2011, 06:26 PM   #6
cdoliver
Member#: 34084
2002 wrx
Thats a lot of boost... This car go boom the first time (maybe 2nd) it see's a run through 6th gear with bad gas
cdoliver is offline   Reply With Quote
Old 06-04-2011, 06:32 PM   #7
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
Adding injectors won't allow more boost. On Any stage2 vf car the turbo is already maxed.
Old 06-04-2011, 11:29 PM   #8
Speed
Member#: 67371
05 BUILT 2.4L STI
23.5 psi... on 93 yeah, that's a great tune!
Speed is offline   Reply With Quote
Old 06-05-2011, 02:49 AM   #9
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
LOL. I dont get the title or disclaimer, but i will be constructive. A good tune would take out 3-4 psi and up the timing. A stg2 car should only fall 8-9% from peak power to 7k on 93.
The added boost pops a punch, but the added heat kills it upstairs.
STi Mikey is offline   Reply With Quote
Old 06-05-2011, 07:56 AM   #10
mapleleaf
Member#: 103399
2009 Stripped STI
Dirty White
@ the disclaimer. It aint black magic and there are not too many secrets.
23.5psi on pump
mapleleaf is offline   Reply With Quote
Old 06-05-2011, 08:08 AM   #11
Spenk
Member#: 7164
2000 Miata LS
Evo Orange Mica (1/644)
I can feel the heat off those cooking heads from here...
Aggressive tune + stock pistons = one bad knock away from a rebuild.
Spenk is offline   Reply With Quote
Old 06-05-2011, 06:08 PM   #12
VladiWrX
Member#: 145658
On my 5th scoob
and lovin it
Magic tuning secrets is what its all about
VladiWrX is offline   Reply With Quote
Old 06-07-2011, 01:50 PM   #13
Clark Turner
Member#: 178047
02 WRX STI Spec C
Power peak at 5200rpm? Timing curve and AVCS maps need serious work
C
Clark Turner is offline   Reply With Quote
Old 06-07-2011, 03:03 PM   #14
Motion Lab Tuning
Member#: 228856
So apparently you guys are upet by th disclaimer. I put that there to stop the whining. I guess it hurt some feelings.
This tune is as it was intended to be. You don't like, keep it to yourself.
Old 06-07-2011, 03:05 PM   #15
Motion Lab Tuning
Member#: 228856
Prove it then. A good tune is one that makes power/torque and is safe. Exactly what this does.
Old 06-07-2011, 03:10 PM   #16
Motion Lab Tuning
Member#: 228856
23.5psi on pump
You're 100% correct. I've always thought black magic tuning was rediculous. However, we are able to keep the boost under control via other methods. No need for your sarcasm.
Old 06-07-2011, 03:44 PM   #17
Motion Lab Tuning
Member#: 228856
You're a smart man! And you're also correct, the "tuned" graph is obviously very smooth compared to the non-tuned graph. Thanks for not being part of the nasioc bandwagon haters.
Old 06-08-2011, 01:23 AM   #18
SVT_WRX
Member#: 164830
G61 III OVE 58e
I will remind you, sir, people will say what they want to say. And if somebody doesn't like what you are trying to portray, they can say whatever the ef they want. And there isn't a damn thing you can do about it. Is there? No. Can you say what you want? Damn right you can. It's a free country, a free forum where anybody can discuss anything or voice any opinions all day, every day. If you don't like what people have to say, well that's just too damn bad. You will never be able to control what people say, or what people think. So get that out of your head now. That being said, I don't like the tune or your disclaimer. Now you can defend yourself all you want. It doesn't matter to me. I said what I had to say....and it is, what it is.
SVT_WRX is offline   Reply With Quote
Old 06-08-2011, 02:58 AM   #19
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
NASIOC is filled with too many stock ecu "guru's".
Keep on trucking motion lab, still wish you had your MD though.
project_skyline is offline   Reply With Quote
Old 06-08-2011, 05:10 AM   #20
Dutch Devotion
Member#: 145985
We do that on 2 litres overhere with (far) less boost in the mid range.
And still we're being warned that VF series are not build for going over 21psi......
So do you warn your customers as well ? That they'll kill their turbo's driving with these boost levels within 15.000 miles ?
And please adjust your attitude Motion Lab Tuning ?
It's not what you say, but how you say it !
Thank you.
Erik - the Netherlands
Dutch Devotion is offline   Reply With Quote
Old 06-08-2011, 08:51 AM   #21
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
Thank you.
well put Erik!
I really think everyone is now poking motion labs to get a reaction because they can. Oh the drama
Old 06-08-2011, 09:15 AM   #22
Black07STiGuy
Member#: 155930
2008 WRX Josh Tuned
VF39+JoshTune=330hp/350tq
23.5PSI on a VF48? dudes car is gonna go up in
Def gonna keep an eye on this thread.
Black07STiGuy is offline   Reply With Quote
Old 06-08-2011, 09:21 AM   #23
jays05
Member#: 78165
05 STI 35r + e85
jays05 is offline   Reply With Quote
Old 06-08-2011, 10:24 AM   #24
Motion Lab Tuning
Member#: 228856
I ran 23psi on my vf turbo for 3 years. Took it off with 0 shaft play. Why is the subaru community so worried about boost? We have to bring the evo guys back down to earth every now and then cause they all want to run 40psi. No we don't warn our customers, we tell them to drive the car how they want and enjoy it the tune is safe.
Thanks,
Alex Goodwin
[email protected]
Old 06-08-2011, 10:43 AM   #25
big18g
Member#: 165872
2005 wrx
black
Who cares about evo owners and how much boost they run? How is that in any way shape or form relevant to this conversation?
Their cars have iron blocks, bigger turbos, and pretty much different everything aside from the general "turbo and awd".
big18g is offline   Reply With Quote
New 2011 STI owner in UT and new to the forum as well! Doberzus Newbies & FAQs 15 03-07-2011 09:22 PM
Ali Afshar's new 2011 STI and his 8 second street STI at IDRC finals this Saturday, S ESX Motorsports Southern California Impreza Club Forum -- SCIC 6 09-08-2010 06:08 PM
2011 STi Sedan in white - 720p Action Video shot on Oregon's awsome roads! SubaruShawnPDX North West Impreza Club Forum -- NWIC 24 08-24-2010 02:39 PM
AutoBlog.com drives the new 2011 STI a real review Sikk General Community 8 07-19-2010 08:46 PM
What you guys think of new 2011 STI ? ProdriveRex North West Impreza Club Forum -- NWIC 7 04-01-2010 02:53 PM
