Old 06-04-2011, 09:31 AM   #1
NickLegacy22
Member#: 261953
1995 Legacy L
red
Default ej22 common oil leak locations?
So I've replaced both headgaskets and verified that they are not leaking. I can't figure out where my leak is coming from. I know that it is on the underside of the heads, I do know that I'm missing a bolt in the oil filler tube, but I rtv'd it pretty decently. It may be leaking, but I lost so much oil over maybe a month that my valves are now ticking. Is it possible to lose so much from the oiil filler tube?
NickLegacy22 is offline   Reply With Quote
Old 06-04-2011, 01:39 PM   #2
grafton
Member#: 187936
07 WRB STi
valve cover gaskets, cam seals, rear cam seals, the bolts that hold the valve covers on , crank seal, oil pump, rear main seal, oil separator plate
thats just off the top of my head
grafton is offline   Reply With Quote
Old 06-04-2011, 02:10 PM   #3
NickLegacy22
Member#: 261953
1995 Legacy L
red
Those are all common????? I meant to say I replaced both valve cover gaskets, and I verified that they are not leaking.
Old 06-04-2011, 02:18 PM   #4
SD_GR
Member#: 31509
2002 Impreza WRX
If you are seeing it "under" the heads it could be coming from elsewhere and moving along air flow. I know the front cover is a source for leaks; it could be cam seals. Also, since you have replaced things and are seeing a big loss, you could be seeing a combo of leaks and consumption. This won't be linear, the level can drop fast quickly after staying relatively stable for a bit.
SD_GR is offline   Reply With Quote
Old 06-04-2011, 02:24 PM   #5
NickLegacy22
Member#: 261953
1995 Legacy L
red
Yeah, weird thing is it's leaking fast, all underneath is covered in fairly fresh oil, however non of it gets on the ground when I'm parked overnight or for a couple days or whatever. Could the oil filler tube have enough pressure to leak a fair amount, because mine is broken.
Old 06-04-2011, 02:34 PM   #6
grafton
Member#: 187936
07 WRB STi
shouldn't even have oil up there, check under the timing belt cover for oil
Old 06-04-2011, 02:40 PM   #7
NickLegacy22
Member#: 261953
1995 Legacy L
red
There does seem to be oil up there. I bought the car with the timing belt cover half assed put on. If I take it off I might not get it back on, think that will be ok if I keep it off?
Old 06-04-2011, 05:47 PM   #8
Psyklon
Member#: 80155
1998 OBS
the back wont come off unless you remove cam gears, or break it off.
Psyklon is offline   Reply With Quote
Old 06-04-2011, 07:25 PM   #9
NickLegacy22
Member#: 261953
1995 Legacy L
red
Old 06-04-2011, 07:37 PM   #10
amoore131
Member#: 222708
From the locations you are describing I would say to look into the oil filler tube gasket and valve cover gaskets. I would also consider checking into the cam seals, rear main seal, and spark plug gaskets.
amoore131 is offline   Reply With Quote
Old 06-04-2011, 07:44 PM   #11
NickLegacy22
Member#: 261953
1995 Legacy L
red
I have a sohc, so no plug gaskets, VC gaskets are brand new and positively aren't leaking. I'll replace the filler tube because it's cracked where it bolts in, it IS leaking for sure but idk if it's THE problem. Rear cam seals look like they are new.
Old 06-05-2011, 09:17 AM   #12
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
There are spark plug tube seals but they are usually replaced with the valve cover gaskets
Old 06-05-2011, 09:24 AM   #13
NickLegacy22
Member#: 261953
1995 Legacy L
red
Thats on dohc motors, Like I said I have a sohc motor. The spark plugs bolt directly into the cylinder head.
Old 06-05-2011, 11:24 AM   #14
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
The phase 2 sohc have plugs that go through the valve covers, is not a dohc/sohc thing. But I see what your saying, now.
Old 06-05-2011, 11:32 AM   #15
NickLegacy22
Member#: 261953
1995 Legacy L
red
Are you able to find me a picture of a phase 2 engine? I've been looking for a picture for one and haven't seen them anywhere.
Old 06-05-2011, 11:39 AM   #16
NickLegacy22
Member#: 261953
1995 Legacy L
red
BTW I'm really thinking it's from the filler tube as it is leaking.. I had to use rtv and it has oil coming out of it, and possibly the oil pan? I'm praying it's not the rear main or the oil separator because I really don't feel like pulling a tranny for a oil leak.
Old 06-05-2011, 12:41 PM   #17
grafton
Member#: 187936
07 WRB STi
can you get pictures of the leaky areas?
Old 06-05-2011, 01:32 PM   #18
NickLegacy22
Member#: 261953
1995 Legacy L
red
Yeah It'll have to wait until tomorrow. But mainly you will see pictures of the leaky area on the oil filler tube. other than that the whole entire undercarriage is covered in it. I'll see what I can get for pictures.
Old 06-05-2011, 01:38 PM   #19
NickLegacy22
Member#: 261953
1995 Legacy L
red
This is another picture I found, very similar except I have red silicone squeezed out of the sides of my fill tube.
Old 06-06-2011, 03:49 PM   #20
NickLegacy22
Member#: 261953
1995 Legacy L
red
When I opened the oil cap the whole tube like bent on me, since that bolt is snapped off... And since I'm obviously only leaking oil when I'm building pressure enough for oil to go upwards, I'm sure this is the problem.
Most common oil leak? Brian204 'Old School' Subaru Forum 25 06-05-2011 11:12 PM
Oil Leak Location Pictures Ramon_12345 Service & Maintenance 3 05-20-2008 07:34 PM
EJ22 Mysterious Oil Leak whitet777 Service & Maintenance 76 05-29-2007 10:54 PM
Oil leak location? hawksoob Service & Maintenance 6 02-05-2004 09:50 PM
Common oil leak problem?? Puyo Newbies & FAQs 1 03-14-2003 10:19 PM
