Old 07-23-2002, 05:25 PM   #1
dasubaruguy
Member#: 6523
Default Which Ems To Use.
ONE QUESTION FOR PEOPLE LOOKING FOR A EMS. HOW MUCH TUNNING DO YOU REALLY NEED? UNLESS YOU ARE RUNNING A FULL RACE ENGINE, I REALLY DONT THINK YOU NEED A MOTEC. I'M RUNNING A HKS F-CON V PRO. ITS NOT PRE PROGRAMMED SO UNLESS YOU REALLY KNOW WHAT YOU ARE DOING DONT USE IT. I USE IT BECAUSE I PUT 589 HP TO THE WHEELS. IF YOU ARE LOOKING FOR A GOOD SYSTEM THAT IS EASY TO TUNE ( YES, YOU DO NEED A DYNO ) AND IS PRE WRITTEN, IT WOULD BE A GREDDY E-MANAGE. IF PEOPLE ARE INTERESTED, I CAN TUNE IT SINCE I HAVE THE PROGRAM FOR IT. THE GREDDY EMS READS OFF OF YOUR STOCK ECU BUT CAN DO EVERY THING A POWER FC,AEM,TEC, OR MOTEC CAN DO EXCEPT RUNNING ON A MAP SENSOR. A GOOD EMS SHOULD RUN CLOSED LOOPE SO THAT IT CAN LEARN. SO KEEP IT IN MINED AND ASK ME FOR ANY MORE QUESTIONS ON COMPUTOR TUNNING YOUR IMPREZA.
dasubaruguy is offline   Reply With Quote
Old 07-23-2002, 05:38 PM   #2
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
OMG I needed my sunglasses for this one....
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 07-23-2002, 05:41 PM   #3
wRx14pSi
Member#: 6203
i see Waldo ... somewhere hidden in the caps.
wRx14pSi is offline   Reply With Quote
Old 07-23-2002, 06:47 PM   #4
mlambert
Member#: 13831
maybe greddy e-manage is tuned in all caps so hes practicing
mlambert is offline   Reply With Quote
Old 07-23-2002, 07:00 PM   #5
WizardBlackWRX
Member#: 14979
If you think the Greddy E-Manage can do everything a TEC, AEM or PowerFC can, you're poorly mis-informed.
WizardBlackWRX is offline   Reply With Quote
Old 07-23-2002, 07:26 PM   #6
dasubaruguy
Member#: 6523
have you ever used the greddy e-manage?. oh sorry guys for the caps. Also I never said it will do EVERY THING. like I said the only thing you cant do is convert a MAF to a more responsive MAP sensor. For street use the e-manage would be a better system to run on than a race system like a MOTEC. I'm not sure how long some of you been working on Subaru's, but working on the EJ20 turbo for the last 11years I would go for a e-manage for street use. It also costs considerably less than the other EMS. I dont think any of the users will be logging in on how much fuel they should richen at turn one down the street.
Old 07-23-2002, 07:59 PM   #7
dasubaruguy
Member#: 6523
The e-manage can adjust timing. It has a separate harness for it. As for the guy talking about the power fc. where do you get your info?????? The power fc can read both MAP and MAF. OMG you need some serious teaching on what each one can do. As for the F-CON. There are only three people in California that has the Key for the F-CON. And yes I am not the one with it. The people are Mr. Fujita,a tech at HKS usa(no names), and Mike. I'll keep the names discreet for privacy reasons. Oh also the whole BS thing. Have you gone there lately?
Old 07-23-2002, 10:34 PM   #8
Coati
Member#: 9106
2015 FXT - DGM
2008 STI - Aspen White
I think you scared him away.
He seems to have deleted all of his posts on this thread.
Coati is offline   Reply With Quote
Old 07-24-2002, 12:35 AM   #9
sakurax
Member#: 8863
02 WRX
I got the e-manage but having problem installing it for the WRX. I need to find out the 3 rotary switch for WRX and the instruction menu only have it for GC8, not GDA. Anyone install it for their WRX?
sakurax is offline   Reply With Quote
Old 07-24-2002, 10:57 AM   #10
worry
Member#: 13461
How does this "piggyback" signal interceptor unit differ from the DasTek UNIChip that people are already using in WRXs? Does it offer any real gains over the Dastek offering? Other than the GReddy badge?
worry is offline   Reply With Quote
Old 08-01-2002, 10:57 PM   #11
WRX300
Member#: 17974
well it seams that it is basically a $300 (unit) + 45(timing control) + 35 (Injector control 16x16map) = $380 unichip that is user programmable
~WRX300
WRX300 is offline   Reply With Quote
Turbo motor into Porsche 914. Which motor to use and where to get it? pktzygt Subaru Conversions 18 11-08-2008 04:52 PM
Which gauge to use to monitor my O2 bottle jikhead Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 01-06-2004 05:23 PM
Which tool to use to cut a urethane greddy lip? bigbird Interior & Exterior Modification 4 04-29-2003 07:51 AM
Which Wagon to use Stubaru New England Impreza Club Forum -- NESIC 2 07-15-2001 06:24 AM
