Old 01-31-2013, 11:41 AM   #26
CJ68
Member#: 187419
2001 2.5RS
Sedona Red
Originally Posted by seanathanq83 View Post
i found a spicer slip yoke that will fit, and then also a rear flange that i can make work, when i have an r180 they have a spicer flange for that, just really need to go get it make, or i may just wait and get the correct spicer flange for the r180 and hurry and do the swap
Ha! I finally found this thread again! I subscribed this time...
No one would have the part number for the Spicer r180 flange yoke would they?
CJ68 is offline   Reply With Quote
Old 01-31-2013, 01:29 PM   #27
Yulri
Member#: 162299
2007 Impreza WRX OBP
93 Impreza L, 91 Legacy L
Originally Posted by Samurai Jack View Post
make you one what?
Driveshaft Shop has been having balancing issues with their driveshafts
PST can make you a driveshaft in steel, aluminum or carbon fiber.
You can check their website for the forms and information needed, but they don't work with individuals. You can figure out what you want and go through RallySport Direct.
If you swap an R160 with an R180, and you are using a 5MT, the pinion flanges on the front of the diffs are the same. Same bolt spread pattern.
You can use your 5MT driveshaft with the R180 rear diff. You do not need an Auto driveshaft even though many people say you do.
In other words, the driveshaft is a direct swap
Ask me how I know
But can you use a 06 sti ds with a 06 sti tranny to a 02 wrx rear diff on an 07 wrx tr is the question
Yulri is offline   Reply With Quote
Old 01-04-2014, 11:10 AM   #28
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
Sorry to be so late getting back to this, I actual found my slip yoke and rest flange the slip yoke is Spicer, and I will get a part number later today, as for the pinion flange in not sure the brand at the moment and also not sure if I bought it to fit the r160 or180 I will check all that out today and get some pics, hoping to have a steel driveshaft made soon guy said it would only weigh like 14lbs or something and would be I believe 2.5" so no tunnel mods should be needed
seanathanq83 is offline   Reply With Quote
Old 01-05-2014, 12:27 PM   #29
Samurai Jack
Member#: 21145
2002 Enemy of Aku
I just saw this.
Even though the answer is almost a year old, it may help someone else.
The answer is "YES".
The differences between the STi driveshaft and the WRX driveshaft is the length. The STi transmission is longer than the WRX transmission, hence the STi version is shorter.
They bolt up at the rear diff the same, using the same bolt flange and pattern
Samurai Jack is offline   Reply With Quote
Old 04-18-2014, 02:15 PM   #30
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
Bringing this back from the dead. Did anyone have a steel one piece drive shaft made?
Or ever find out part numbers for parts needed?
Thanks
rexworx is offline   Reply With Quote
Old 06-26-2015, 04:58 PM   #31
UT_WRX
Member#: 400034
@Seanathanq83 - Did you ever get the part number for that companion flange? I have the part number for the Spicer Slip Yoke. but I have an R160 rear diff and dont want to have to pull the diff apart to re-drill the diff flange. A PN for a companion flange that fits the r160 diff would be great. OR the bolt circle measurement for the r160 flange.
Thanks in advance.
UT_WRX is offline   Reply With Quote
FS : Perrin Equal Length Headers [email protected] Engine/Power/Exhaust 8 06-06-2011 11:25 PM
driveshaft size/length confirmation kurion Transmission (AT/MT) & Driveline 0 05-13-2005 02:59 PM
Driveshaft lengths needed (actual numbers) fragment Transmission (AT/MT) & Driveline 0 03-14-2004 12:02 PM
WRX rear diff ratio automatic? Also Driveshaft length? ciper Transmission (AT/MT) & Driveline 9 12-12-2002 05:09 PM
driveshaft length?? steve_d Transmission (AT/MT) & Driveline 1 12-04-2002 10:13 PM
