Go Back   NASIOC > NASIOC Classifieds > Private Vehicle 'For Sale' Classifieds
Old 06-06-2011, 01:49 PM   #1
mrkt321
Member Sales Rating: (3)
Member#: 210752
Default CO: 2004 Sti Psm, >80k, Unique sleeper, Built Motor, HTA68, E-85, Coilovers
SOLD SOLD SOLD
Hello,
PRICE DROPPED!
I am moving to New York City next year, so I'm forced to get rid of my car. I've had the car for two years now and am the third owner. The first owner had the car as a stock daily driver and put 9500 miles on it and sold it in 2006. The car's motor was built under the car's second owner. Element tuning did the entire motor build in the summer of 2007 when the car had about 35,000 on it. I purchased the car and made some changes to make it a more fun daily driver with a usable powerband and great handling in any conditions on any road. The car will have less than 80,000 on it at the time of sale.
Cosmetically, the car looks great. There are a couple minor door dings that could be removed. The front of the car has some normal rock chips and highway wear (this is Colorado). On the passenger side of the front bumper the corner is a bit cracked around the fog light cover. The only noteworthy ding on the car is right above the exhaust opening. I believe I was backed into. There is some scratching and deformation to the rear bumper where this occurred that can be seen in the pictures.
Recently the car was tuned by Adam at Revolutions Motorsports in Colorado Springs. On E-85, the car made [email protected] and [email protected] psi on 91. Both tunes were on the conservative side so that the car maintains drivability and reliability. The particular dyno used is reported to rate cars on the low end. A 300whp car on this dyno made 350whp on Harvey's dyno. The car also has an Element Tuning Hydramist methanol injection kit. The car hasn't been tuned with this yet, but expect similar numbers to the E-85. Run E-85 all summer long and keep the same power through winter without worrying about cold startup on ethanol with the meth injection and 91.
Interior:
Status Racing Ring seats in black alcantera
Fuel pressure gauge
Infiniti front speakers
Fuel switch
ABS kill switch
2005 Sti Steering Wheel
TurboSmart EBoost2 Gauge
Autometer Dual Dash Gauge Pod
Aquamist Methanol Injection Gauge
Sti Floormats
Braille Lightweight B3121 Battery
Engine Control:
Cobb Accessport V2
Motor:
CP Custom Spec Forged Race Pistons OEM Bore with rings, 9.5:1 compression
Element Turning Rods
Cosworth Camshafts 278/274
Cosworth Valves/Springs/Retainers
ARP Head Studs
Element Competition Catch Can
NGK 1 Step Colder Spark Plugs
Perrin Lightened Crank Pulley
Element Hydramist Methanol Injection System
Drivetrain:
Clutchmaster Stage 4 Clutch
Turbo:
Forced Performance Ported HTA68 Turbo
Element Steel Braided Oil Line
Intake:
K&N Cone Filter
Silicon Inlet
Exhaust:
Perrin Equal Length Headers
Non-catted Up-pipe
Turbosmart Ultragate 38mm Wastegate
Cobb Downpipe
Maddad Whisper Dual Tip Catback (Sounds great, no drone whatsoever)
Fuel Delivery:
Ultimate Racing Rails
Injector Dynamics ID1000 Injectors
Bosch 044 Fuel Pump
JDM TGV Deletes
Cooling:
Turbo XS Front Mount Intercooler (Turbo is clocked to reduce piping)
Synapse Synchronic Blow Off Valve
Zerosports Thermostat
Mishimoto Aluminum Radiator (Upgraded Cap)
Braking:
DBA 5000 Slotted Front Rotors
DBA 4000 Slotted Rear Rotors
EBC Yellow Stuff Brake Pads
Agency Power Steel Brake Lines
Exterior:
30% Tint
Seibon CF RS Hood
Cusco Fiberglass trunk with rally straps
Rally Armor Mud Flaps
Custom Fiberglass-Vented-Reinforced Skidplate/Splashguard
Stiffening/Suspension:
HotBits DT1 Coilovers (Great ride, Can take abuse, Tarmac Rally/Road valving) (Professionally aligned, cornerwieghted, and tuned)
Kartboy Rear Subframe Lockdown Bolts
Whiteline Steering Rack Bushings
Whiteline Anti-Lift Kit
Kartboy Shifter Bushings
Kartboy Transmission Mount Bushings
Whiteline Rear Diff Support Bushings
Group B Transmission Mount
Group B Engine Mounts
Whiteline Roll Center Kit
Perrin Front/Rear Endlinks
Whiteline Rear Swaybar
Front H Brace
Wheels/Tires:
17x8 Enkei RPF-1's with Dulop Star Specs (Lightly used last summer, tons of tread)
17x7.5 Stock Sti BBS with Bridgestone Blizzak WS60 (Used two seasons, lots of tread remaining)
Bottom Line:
This is a car I planned on using for years to come. Everything has been done the right way and no corners were cut. The car was built, but never truly utilized. The car has never seen a track day or drag strip. Everything has been setup in this car to maximize it's fun and usability. The car will outhandle almost all other Sti's, but it maintains a ride-height and robustness needed to handle Colorado's roads and seasons. This car is understated, yet unique with its looks. I've put a lot into this car in form of both time and money and would like to get as much compensation as I can.
I'm looking to get $21,000 for the car. I will consider reasonable offers and would be happy to answer any questions or supply additional pictures. PRICE DROPPED TO $19,000!! -------->$17,000!!!!
I can be reached on here, at [email protected], or at 970-420-6163.
Thank You
I just got back in town, so please re-contact me if I haven't gotten back to you.
I am only around until the 17th of August, so I am very motivated to sell the car before then.
mrkt321 is offline   Reply With Quote
Old 06-06-2011, 01:49 PM   #2
mrkt321
Member#: 210752
Old 06-07-2011, 03:00 PM   #3
mrkt321
Member#: 210752
Any interest? I'm flexible.
Old 06-08-2011, 10:47 PM   #4
mrkt321
Member#: 210752
I'm very open to offers for anyone interested.
Old 06-09-2011, 11:24 AM   #5
mrkt321
Member#: 210752
Let's go!
Old 06-10-2011, 11:58 AM   #6
mrkt321
Member#: 210752
Bump!
Old 06-11-2011, 03:56 PM   #7
mrkt321
Member#: 210752
Bump!
Old 06-12-2011, 08:59 PM   #8
mrkt321
Member#: 210752
Anybody
Old 06-12-2011, 09:36 PM   #9
LatentWagen
Member Sales Rating: (76)
Member#: 50315
0806 LGTspecB & Saab
9-2xAero5MT DGM & MBP
Looks like a purpose-built machine, free bump for a proper suspension setup.
LatentWagen is offline   Reply With Quote
Old 06-13-2011, 09:53 AM   #10
mrkt321
Member#: 210752
Thank you for the support! If only you were a buyer.
Old 06-13-2011, 10:31 AM   #11
LatentWagen
Member#: 50315
Somebody who knows what's up will find this car and snatch it. If not, bring it to NYC next year and sell it to me
Old 06-14-2011, 01:37 PM   #12
mrkt321
Member#: 210752
Let's hope that person comes along soon.
Old 06-15-2011, 11:25 AM   #13
mrkt321
Member#: 210752
To the top.
Old 06-16-2011, 08:57 PM   #14
mrkt321
Member#: 210752
bump please
Old 06-16-2011, 11:24 PM   #15
Srtkr
Member Sales Rating: (5)
Member#: 228025
07 Forester XT
siiiiiiick seats!
Srtkr is offline   Reply With Quote
Old 06-17-2011, 12:43 AM   #16
ZJDizzle
Member Sales Rating: (6)
Member#: 205851
2004 PSM WRX Sedan
STOCK AS F**K
love the FMIC with the scoopless hood, that's whats hopefully happening on my psm wrx soon!
anyways, GLWS!
ZJDizzle is offline   Reply With Quote
Old 06-19-2011, 07:18 PM   #17
drr
Member#: 198036
2005 Hybrid
Do you have the stock seats? I might be able to come up this week.
Thanks,
Adam
drr is offline   Reply With Quote
Old 06-20-2011, 08:23 PM   #18
mrkt321
Member#: 210752
I am being the idiot answering questions for my son until he gets home tomorrow (Tuesday). Let me know your number and he can call you in the am
Old 06-21-2011, 11:45 PM   #19
mrkt321
Member#: 210752
I don't have the stock seats, but I could possibly find someone in the area who I could buy them from/trade + cash for the stockers.
Old 06-22-2011, 11:26 AM   #20
CoeyCoey
Member#: 286358
2005 Forester XT
How come there are all these nice Impreza's near me but I can't find a freakin forester? LOL
CoeyCoey is offline   Reply With Quote
Old 06-22-2011, 11:52 AM   #21
mrkt321
Member#: 210752
you could get an impreza... ...just saying
Old 06-23-2011, 02:21 PM   #22
mrkt321
Member#: 210752
To the top
Old 06-24-2011, 01:58 PM   #23
mrkt321
Member#: 210752
Bhump
Old 06-25-2011, 06:29 PM   #24
mrkt321
Member#: 210752
Open to offers. Please contact me if you're interested.
Old 06-26-2011, 01:30 PM   #25
mrkt321
Member#: 210752
Bump!
FS : CO: 2004 STi Widebody Bugeye PSM LOOK! STepeci Private Vehicle 'For Sale' Classifieds 80 06-17-2013 12:12 PM
FS: CO: 2004 STi Cluster R0DENT Interior/Dressup/Audio & Security 2 02-16-2007 12:59 PM
CO: 2004 STI ECM (ECU) with Ecutek reflash kite_tmr Private 'For Sale' Classifieds 19 06-07-2006 12:44 AM
CO: 2004 STI ECM (ECU) with Ecutek reflash kite_tmr Private Vehicle 'For Sale' Classifieds 2 05-29-2006 12:21 AM
