Old 07-23-2002, 06:58 PM   #1
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Default Tire width and rim width numbers? Any resources?
Im trying to find info on tire width and the best width rims to use with them. I think this would be beneficial to everyone. I would think someone created a table that shows tire sizes from 175 to say 245 and what rims sizes are optimal.
Any links?
Old 07-23-2002, 07:20 PM   #2
driggity
Member#: 7453
2014 Scion FR-S
Hot Lava
I haven't seen an all inclusive table anywhere, but most tire manufacturers have this information on their websites. I think that sidewall height is also important. For example I think that 235/45's are supposed to be ok on 7 1/2" wheels while 235/40's are not (although I've seen that setup and it looked ok).
driggity is offline   Reply With Quote
Old 07-23-2002, 08:00 PM   #3
mofugga
Member#: 19540
2000 old skool RS
BRP
mofugga is offline   Reply With Quote
Old 07-23-2002, 08:10 PM   #4
ciper
Member#: 15543
90BJ Legacy LS ABS
mofugga: Thats not exactly what Im looking for.
If you run a tire that is too wide or too narrow for the wheel, not rolling diameters and such.
driggity: I dont think that is right. The tire width and the wheel width should be totally dependant on each other while the sidewall percentage number ONLY effects outer diameter and revolutions per mile
I could be wrong though.
Old 07-23-2002, 08:23 PM   #5
driggity
Member#: 7453
2014 Scion FR-S
Hot Lava
All I know is that some tire manufacturers will recommend different rim widths for tires of the same width but different sidewall heights. For instance 235/45 17 S-03's are recommended for rims 7.5-9 inches wide while 235/40 17 S-03's are recommend for rims 8-9.5 inches wide
Old 07-23-2002, 10:43 PM   #6
Fitz
Member#: 1426
'07 335xi, '07 ZX6R
SV650 Race Bike
Tirerack.com
Look under the details specs for each individual tire. Gives you recommended rim width, sectional width on the tire, how changing rim sizes effects contact patch.
You can also contact Luke @ Tire Rack; him and I had a great discussion the other day since I'm trying to upsize so drastically for next year.
Fitz
Fitz is offline   Reply With Quote
Good/cheap place to get tires mounted and rims put on? tbcboo North West Impreza Club Forum -- NWIC 13 05-02-2008 03:29 PM
Ideal offset and rim width for 2.5 TS? Scott_2.5TS Tire & Wheel 7 11-14-2007 02:40 PM
Max optimal tread width to rim width chart? chimchimm5 Tire & Wheel 2 01-12-2007 11:27 PM
Difference of 225 and 235 width tire on an 8" width rim. petawabit Tire & Wheel 6 05-11-2005 04:01 AM
tire and rim width? rawrFERNY Tire & Wheel 5 03-09-2005 09:01 PM
