Old 07-22-2002, 01:57 PM   #1
WRXVII
Member#: 15854
VF34'd...
Default Eibach Prokit spring installation question II
can a car be driven without problems with only front springs installed? I'm planning on doing fronts first and then rear next day.... any suggestion?
WRXVII is offline   Reply With Quote
Old 07-22-2002, 02:00 PM   #2
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
You should have no problems. As long as you aren't blasting though the corners and driving like a fool you should be fine.
Arnie is offline   Reply With Quote
Old 07-22-2002, 02:41 PM   #3
WRXVII
Member#: 15854
VF34'd...
Great.... I will baby my car after spring istall how much does autozone charge for renting a spring compressor?
Old 07-22-2002, 03:26 PM   #4
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
~50 deposit and 45 gets credit back when you return them
definatly worth it...
Old 07-22-2002, 06:15 PM   #5
Sanctum
Member#: 3074
2002 Impreza WRX
Red
Snagged my compressor at Sears for $40. Here's the linkage:
Craftsman Spring Compressor
- Brian
Sanctum is offline   Reply With Quote
Old 07-22-2002, 08:53 PM   #6
ThinkTank
Member#: 6821
2006 Scion TC
Mica
Default Parts stores will loan
spring compressors for free. Do the rear first as they drop less.
ThinkTank is offline   Reply With Quote
Old 07-22-2002, 08:55 PM   #7
D_REX
Member#: 8945
MY02 WRX
- Brian
I bought mine from autozone. Looks the same, I don't think it cost more than $20. I've used them at least 5 times now, well worth the investment.
D_REX is offline   Reply With Quote
Old 07-23-2002, 12:44 AM   #8
WRXVII
Member#: 15854
VF34'd...
can I use a regular wrench and a hex key in order to remove the top strut bolt? Is hex key and Allen Wrench same thing? someone PLEASE answer this question.... what's the easiest way of removing the top strut bolt? can I do it simply with a hex key and a regular wrench?
Old 07-23-2002, 12:47 AM   #9
WRXVII
Member#: 15854
VF34'd...
which way does the spring install? should the letter be upside down? where do I align the bottom spring tip at?
Old 07-23-2002, 12:52 AM   #10
WRXVII
Member#: 15854
VF34'd...
Autozone sells one for like $31. Heard NAPA sells one for around $20.
Old 07-23-2002, 01:32 AM   #11
WRXVII
Member#: 15854
VF34'd...
Someone PLEASE answer this? I need the answer ASAP.... also about the method of removing the top strut bolt.... can I just use a hex key and a regular wrench to remove it?
Old 07-23-2002, 01:36 AM   #12
ThinkTank
Member#: 6821
2006 Scion TC
Mica
Default Lettering on eibach spring..
should be right side up when installed. Threads contain advice on which end of the spring should be properly seated and how to tell the front set from the back. I have seen at least two descriptions of the top bolt removal in this forum. One had pictures of the tools. There is a T shaped hex key tool available from Sears. One guy used a hex key with vice grips I think. Search some more. I don't have the links handy.
Check strut install instructions.
Old 07-23-2002, 01:48 AM   #13
WRXVII
Member#: 15854
VF34'd...
So... letters SHOULD not be UPSIDE DOWN when installed?
On the spring it says 7710.002 (longer springs) and 7710.001 (shorter springs). I think longer springs should go to fronts, right?
Old 07-23-2002, 07:49 AM   #14
WRXVII
Member#: 15854
VF34'd...
Need answer ASAP... as I will be doing spring install today!! please someone answer above questions?
Old 07-23-2002, 11:16 AM   #15
WRXVII
Member#: 15854
VF34'd...
Someone please reply?
"So... letters SHOULD not be UPSIDE DOWN when installed?
On the spring it says 7710.002 (longer springs) and 7710.001 (shorter springs). I think longer springs should go to fronts, right?"
Old 07-23-2002, 11:25 AM   #16
Member#: 17625
02 WRX
CLICK HERE
Would of posted earlier but I didn't see this thread. Good luck!
STR8OUT@WORK is offline   Reply With Quote
Old 07-23-2002, 10:42 PM   #17
ThinkTank
Member#: 6821
2006 Scion TC
Mica
Default 002s in back
letters right side up. Remember to cut bump stops by 1/3
FS/WTT:NY/CT: Eibach prokit Springs for wagon springs singincanary NESIC Private Classifieds 2 05-12-2007 08:57 PM
Difference in Eibach sportline and Eibach prokit springs? 2slofouru Brakes, Steering & Suspension 1 06-26-2006 10:12 AM
Eibach Prokit Springs $390 Installed and OTD Gruppe-S Bay Area Impreza Club Forum -- BAIC 1 10-19-2005 08:00 PM
Eibach prokit spring install question txl146 Brakes, Steering & Suspension 5 10-19-2004 07:42 PM
Questions fo MY00 2.5rs Eibach Prokit springs AzNStiImpreza Brakes, Steering & Suspension 11 10-29-2002 04:56 PM
