Welcome to the North American Subaru Impreza Owners Club Tuesday March 31, 2015
Old 06-06-2011, 08:15 PM   #1
kenlee
Member#: 49341
Default Clutch cylinder rod mating to pitch fork
What is the easiest or proper way to mate the Clutch cylinder rod to the pitch fork? Right now the rod is sitting below the hole in the pitch fork. Here are pics to show what I'm talking about
kenlee is offline   Reply With Quote
Old 06-06-2011, 08:28 PM   #2
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
That looks like it is sitting right where it is supposed to. It does NOT sit in that top hole there. It sits in a dimple below that hole on the back of the fork. Take a look for it. The top hole is for a spring that goes from there to that tab on the left side of the top picture. The spring prevents rattling, but doesn't do much else. Many people don't even run one, myself included.
Old 06-06-2011, 08:30 PM   #3
kpluiten
Member#: 120273
06 WRBWRXWGN
See what I'm talking about?
Old 06-06-2011, 08:36 PM   #4
kenlee
Member#: 49341
Aw snap, I was thinking it went inside the upper hole. Thanks much kpluiten!
Old 06-08-2011, 06:33 PM   #5
freakfly23
Member#: 171302
2006 wrx tr
crystal grey metalic
Damn it. I knew this one. It's like watching jeopardy and knowing the answer to one of the questions but the guy next to you says it first.
freakfly23 is offline   Reply With Quote
WRX clutch Cylinder vs STI clutch Cylinder kakarotoni Newbies & FAQs 8 12-02-2010 03:24 PM
Release Bearing Popping off when mating to Clutch Hayaboosted Transmission (AT/MT) & Driveline 9 07-27-2010 08:18 AM
Clutch questions 06 wrx push type in 05 RS trans mated to 05 sti motor? arch4life Subaru Conversions 0 10-22-2008 12:13 PM
new synchros,flywheel,clutch or STI RA gears,shift forks,clutch? cvcsmkr Transmission (AT/MT) & Driveline 0 11-12-2002 11:16 AM
Will RS Clutch mate to WRX Flywheel? EddyRS Transmission (AT/MT) & Driveline 25 12-18-2001 11:52 PM
