Old 07-23-2002, 07:46 PM   #1
Red98GT
Member#: 21829
2005 Legacy GT Wagon
RBP
Default Bridgestone Protenza RE950 on 98GT
Has anyone installed these tires on the Legacy GT? I am looking specifically at 225/50/16... Please let me know what you think, or if they are even too wide..
Thanks!
-- Bill
Red98GT is offline   Reply With Quote
Old 07-23-2002, 10:36 PM   #2
Benjamin Tang
Member#: 4496
2009 Forester
red
i have them on our wrx. 215/45/17. not as sticky as the sp5000s on our legacy, but still good. braking distances a little long. haven't seen snow yet.
Benjamin Tang is offline   Reply With Quote
Old 07-23-2002, 11:05 PM   #3
HIHO
Member#: 7624
BD5; family sedan
that just wooped your ass
I would think 225 would be to wide. I have them as daily drives and I can easily break the rear loose. But they are good in the rain and comfortable. I good daily driver.
HIHO is offline   Reply With Quote
Old 07-24-2002, 09:16 AM   #4
Red98GT
Member#: 21829
RBP
Do the Legacy's have the same wheel clearance as the Impreza's, or is it just a bit smaller?
Thanks!
-- Bill
Old 07-24-2002, 09:29 AM   #5
Red98GT
Member#: 21829
RBP
Thanks!
-- Bill
Old 07-24-2002, 10:24 AM   #6
subarugt
Member#: 11053
99 Legacy GT LTD
Rio Red
Red98GT
I think it is a close call the wheel clearance btw the Legacy's and the Impreza. It seems that both New Age platforms can run 225/45/17 with no rubbing, but the old schools cannot. I believe it is the same with 225/50/16. So I would stay constant with advise for a GC will probably be the same on a BD/BG and GD = BH/BE.
subarugt is offline   Reply With Quote
Old 07-24-2002, 10:53 AM   #7
GTBGUY
Member#: 2003
'99 BGP Legacy GT
'98 QS Legacy L (auto)
Red98GT - Yes the 225/50/16's are do-able, however you may experience rub under full compression/load. if you want to run 225, then get the 45 series and this will give you extra clearance. However, one thing is that the OE GT wheel is only 6.5" wide, so it's not really recommended to run a 225 on there.
If you had the OE RS wheels that are 7" wide you could get away with doing that fairly safely.
I've run a set of Yoko AVS Intermediates in 225/45/16 on the L and it didn't rub (using RS wheels) at an auto-x. This was w/ the H&R's w/ V6 STi struts.
GTBGUY is offline   Reply With Quote
Old 07-26-2002, 11:13 AM   #8
cfwdfw
Member#: 5046
'97 Legacy gt 5 spd
Deep Saphire Blue Sedan
Default 225.50.16's ...
Bill,
Yes .... as long as your gt is not lowered ... very doable ... and you will notice quite a difference ...
as gtbguy noted ... 7" rims more appropriate ... although most tires spec's show you can run a 225.50.16 on a 6.5 inch rim ...
I ran 225.50.16 Firestone SZ 50 EP's on 16.7 team dynamics before installing the DMS golds ... which dropped the gt about one inch .... back to stock now ...
however ... you will get rubbing if you ... ... "autocross" with 4 people in the car ... proven by Glen at last year's evolution school ..
last comment ... If you havent already upgraded your rear sway bar ... you should ... the 18 mm Outback fits and works gr8 ... and you will be pleasently pleased with the combination!
Charlie
cfwdfw is offline   Reply With Quote
Old 07-27-2002, 01:28 AM   #9
Red98GT
Member#: 21829
RBP
Thanks for all the great suggestions.. From what I have read here, I think I will most likely go with the 215's and i will end up going with a set of 17's from Wheels Direct in Toronto, and keep the GT 16's for a winter/beater set with the stock size.. Right now, I am just cooking the Blizzaks that came with the car..
Thanks!!
-- Bill
Old 07-27-2002, 10:29 AM   #10
Benjamin Tang
Member#: 4496
2009 Forester
red
fyi i bought my re950's from http://www.tiretrends.com... they are a canadian mail order tire shop. see if their prices are competive with your shop of choice?
FS: Bridgestone Potenza RE950 Tires 215/45-17 Computergeek24 SCIC Private Classifieds 13 06-17-2008 02:08 PM
FS: Bridgestone Protenza RE070 tires - No Wear, only 1000 miles ProdriveRex NWIC Private Classifieds 20 11-01-2007 06:48 PM
4 Bridgestone Potenza RE950 205/55/16 dubluv17 RMIC Private Classifieds 8 09-21-2007 04:49 PM
FS: Set of Bridgestone Protenza ++ RE070 ++ 225/45/17 with 1500 miles Quadratic NWIC Private Classifieds 1 05-23-2007 09:13 PM
FS: Stock Bridgestone Protenza Tire teamzzyzx Private 'For Sale' Classifieds 3 02-26-2004 03:35 PM
