#1 |
Member#: 250084
Vehicle:2010 WRX Sedan DGM Cobb Stg. 1 |
I want to pick up an air compressor. I want to actually get the smallet one i can get that will run and air gun. I will be using it alot with a nail gun so i want it to be as portable as possible but still be able to use my air gun with it. I have always borrowed my dads in the past.
Any recommendations?
#2 |
Member#: 242205
Vehicle:2009 wrx blue |
I like the 15 gal horizontal standing with wheels. Pancake or doughnut size is too small.
#3 |
Member#: 278497
Lowes has a 20 gal one for like 199 comes with everything u need plus wheels
#4 |
Member#: 141040
NESIC
Vehicle:07 2.5i wagon UGM |
Get the biggest one you feel comfortable carting around, IMO.
#5 | |
Member#: 197537
Vehicle:06 WRX matte black |
#6 |
Member#: 250084
well what is the minimum tank size and psi i can us that will still run the air gun? The nail gun doesnt need much.
#7 |
Member#: 242205
120-150 psi, most tanks can get to that pressure but the smaller the tank the more it runs to keep the set psi. On small tanks it sucks to use up all the air and have to wait for it to fill up again.
#8 |
Member#: 250084
#9 |
Member#: 33868
Vehicle:2003 wrx srp |
What is an air gun? If it is a paint gun it will have specific air requirements.
#10 |
Member#: 250084
#11 |
Member#: 141040
NESIC
You'll get about 5 seconds from one of those using an impact.
Why the insistence on tiny? It's just not worth it, imo, for practical use. Air is a very inefficient way to do something, so you need a lot of it for most applications. FWIW, any compressor will run any air tool if the pressure is high enough. The problem is sustained use - a nail gun is very annoying to use when you need to wait for the compressor every ten nails. That's why I say buy the biggest one you're comfortable lugging around. Go to home depot and pick a few up, then get the biggest one you could lift into your truck. ![]() Incidentally, you could purchase a few auxiliary tanks and a pancake compressor, then daisy-chain the tanks into the output line. That lets you move each tank individually rather than moving the whole unit at once. Just put a QD and a check valve or ball valve on the inlet, and a combination QD/check on the outlet so the pressure stays in the tank between uses. You'll still be limited by the compressor's flow capability but at least you'll have more air. ![]() Last edited by sniper1rfa; 06-11-2011 at 08:12 AM. |
#12 |
Member#: 177880
South East
here is what you need from harbor freight. and its on sale. Its what we use at my buddys garage. Its loud as balls and takes a while to fill up but it works great. I mean I can't just lug around my 60gal from home
![]() http://www.harborfreight.com/25-hp-2...sor-67847.html |
#13 |
Member#: 239233
Vehicle:1998 LGT White |
^ I have that one in my garage and it gets tons of use and works fine for impact, air ratchet, cut off wheel and paint sprayer.
#14 |
Member#: 37359
Vehicle:2003 WRX |
I've had this one for a while: http://www.harborfreight.com/2-hp-8-...sor-67501.html
I used it with a framing nailer at first, and now I use it with my impact wrench. It seems great and although it has a small tank, it fills up quickly. I never feel like I'm waiting for the compressor. The only reason I wish it was bigger is because I'd like to get into media blasting small parts. |
#15 | |
Member#: 250084
This is the nailer I bought I know people say to get the biggest one possible, however space i a big issue storing it. I like to keep my car in the garage and I only have a 1 car garage, so I would need to store it on the far size of the garage next to my car. In all honesty I would prob. use the nailer more that the impact wrench. If I need some heavy work done on the car I can take it to my friends shop and usually if i fix his computers he takes care of my car for me ![]() |
#16 |
Member#: 275031
NWIC
Vehicle:2009 Forester Blue |
I will admit, I was skeptical on this HF compressor as well when my buddy purchased it. I didn't think it would last... 3 years later, he's definitely got his moneys worth out of it. He only uses it for the occasional nail gun and impact wrench as well.
-Mike |
| Thread Tools | |
| Display Modes | |
| Air compressor tank size? | athakur999 | Service & Maintenance | 5 | 07-19-2007 02:42 PM |
| Air compressor size and PSI help Please? | rexspeedmaster | Newbies & FAQs | 4 | 06-26-2007 03:51 PM |
| Trackday Air Compressor (What size to get?) | 409Industries | Motorsports | 7 | 05-11-2007 04:02 PM |
| Air Stream Air compressor + Tools!! | barkall4 | Non-Subaru Stuff | 0 | 03-31-2007 02:45 PM |
| Good price for air gun and air compressor "rental"..for strut bolts | GregBolby | General Forum Archive | 0 | 08-07-2000 12:06 AM |
