Old 07-23-2002, 10:26 PM   #1
Fred Zaplitny
Gone... But not forgotten
Member#: 92
1999 2.5RS Coupe
Blueish Kind of
Default My MY99 CAI
Well the stock plastic crap came out of my car finally yesterday! It only took 3 years. here it is, basically the same as what Larry Ganz has on his websight I think. Just a PRM, a Kartboy MAF adapter, a 45 degree bend and some silicone tubing. So far I love it, and I have not seen any lean conditions on the A/F guage.
Fred Zaplitny is offline   Reply With Quote
Old 07-23-2002, 11:25 PM   #2
imprezey
Member#: 17178
2001 2.5RS Coupe
Silverthorn Metallic
did you get that from larry or did you make that yourself? looks really nice..
imprezey is offline   Reply With Quote
Old 07-23-2002, 11:40 PM   #3
Fred Zaplitny
Member#: 92
1999 2.5RS Coupe
Blueish Kind of
My initial Idea was to use a modified Minnam intake tube and a PRM to make a MY99 Cobb-like intake. I got the PRM and the 45 deg. tube from Larry along with one piece of 3" blue silicone hose and the silicone hose to line the fender hole with. I later decided to go with the stock air box, so I sold the Minnam. I needed a 2.5"-3" neck down silicone hose which I got from my friendly niegborhood Honda tuner and some hose clamps amd 6mm (1.0 pitch thread) nuts from the hardware store. The MAF adapter was from Kartboy.com. I still need a short 3" tube to put in the inlet of the PRM so it will stay put in the hole. One thing, because the MAF is so far back, I had to snip a wire in the harness and splice and solder in an extension to get the harness to reach. You can see the darker black electrical tape I added today. So far, so good.
Fred
Old 07-24-2002, 12:16 AM   #4
obyone
Member#: 16523
Fred
Uhhh... I remember 8dude, I mean 8complex saying that If your planning on moving the MAF, the MAF had to be the same distance, from the TB, that it was originally to work correctly.
obyone is offline   Reply With Quote
Old 07-25-2002, 12:33 AM   #5
Fred Zaplitny
Member#: 92
1999 2.5RS Coupe
Blueish Kind of
Give me an excellent technical explanation as to why and I might agree with you. The truth is you can put it where you want. All the MAF does is tell the ECU what the air flow coming in to the intake manifold is. When I first started the car after the ECU reset, it ran weird for about 2 minutes. When it learned the new setup it ran fine and has so ever since. No problems. Just added horsepower. The only problem I can see with moving the MAF back, is possible increases in exposer from pulses from the throttle body. I think the stock airbox will absorbe most of that, so I am not worried.
God, I hope you don't think 8Complex knows everything! Nobody does! Not even me.
No really, I don't!
Fred
Old 07-25-2002, 01:08 AM   #6
Donnie
Member#: 1205
2002 IS 300
gunmetal
i will say having a 99 once a long long time ago that thing is like glass more so than the trannies if it hasnt gone yet you probly have a good one mine went twice with the stock intake
Donnie is offline   Reply With Quote
Old 07-25-2002, 01:17 AM   #7
Fred Zaplitny
Member#: 92
1999 2.5RS Coupe
Blueish Kind of
Yes, but I have the new, improved recall MAF! Just got it about two weeks ago.
Why do you think I had a stock intake system including the snorkus for three years?!
Fred
(BTW Recall MAF's are covered for LIFE!!!!)
Old 07-25-2002, 02:35 AM   #8
yamarocket630
Member#: 9436
05 Saab 9-5 Aero
O.K. to settle this once and for all... you can put the MAF anywhere you want, as long as there are no air leaks between it and the engine, ie you can put it in the trunk if you so desire, and run the tube through the middle of the passenger seat back, and as long as there are no air leaks, it will work just fine.
The MAF doesn't care one bit about air pulses or location.
Air flow is determined by the ECU based on the frequency of the MAF output,(which is the frequency that the transistor inside the MAF operates at to keep the hot film at a constant temerature, so more airflow, the transistor switches faster to provide more current) Intake air temp (measured inside the MAF sensor) and Baro pressure (that sensor to the left of the MAF in the picture).
Yamarocket (the mechanic formerly known as Yamarocket630)
Michigan licensed Master Auto Mechanic, ASE Master Certified, L1 Advanced Engine Performance Certified, General Motors Technical Assistance.
yamarocket630 is offline   Reply With Quote
Old 07-26-2002, 12:22 AM   #9
MrHorspwer
Member#: 4063
Yama... you always gotta bring out the credentials. GM needs all the technical assistance it can get... espically with you on the phones! HA!
Anyhow, nice intake setup Fred... I'll have to check it out if I EVER get back to Shores. School sucks.
MrHorspwer is offline   Reply With Quote
Old 07-26-2002, 08:38 PM   #10
yamarocket630
Member#: 9436
05 Saab 9-5 Aero
Don't worry, you'll have some credentials one day...
Didn't you mean they need all the help they can get especially with you in the dealer?
MY99 + CAI + Cold air = ping? Captain Ding Normally Aspirated Powertrain 2 02-16-2002 01:12 PM
Trade: my MY99 16" wheels for TS 15" wheels Keiho Vancouver Impreza Club Forum -- VIC 14 01-30-2002 06:15 PM
Trade: my MY99 16" wheels for TS 15" wheels Keiho Canada Region Forum 2 01-30-2002 12:12 AM
I Believe that my MY99 is running Rich!!! Xscreamer Normally Aspirated Powertrain 5 02-14-2001 11:23 PM
What aftermarket driving light will replace my MY99 fog lights? ARG Technical Forum Archive 21 09-19-2000 07:06 AM
