Old 06-10-2011, 12:16 AM   #1
350zriot
Member#: 264676
Thumbs up Best way to mount hydraulic ebrake firmly? (pics)
This is my current set up. THe staging brake is held up with right two mounted flat bars. no mounts on the left side
The flat bars flex really easily with slight pull of handle.
What would be the best way to mount this firmly, no movement? either welded or bolted.
My thought is to make small brackets and weld them under each flat bar (pics attached). The down side is that i won't be able to reposition the staging brake later on.
I told a guy at Vildini about my thought. He said it'll be OK for now, but in the future, the base of staging brake (aluminum) may crack after countless times of pulling the handle. So i have to come up with something better than the current set up.
Post your suggestions please
350zriot is offline   Reply With Quote
Old 06-10-2011, 12:16 PM   #2
thefoos
Member#: 144751
02 WRX BW EFR E85
7064 TS WRB
I hope you have a 3rd mounting point up front otherwise you have far too much of a torque arm on that back bolt. You're going to rip it out...
thefoos is offline   Reply With Quote
Old 06-10-2011, 06:25 PM   #3
350zriot
Member#: 264676
actually i don't
i'm thinking about mounting a flat bar across the front two mounting points on the brake. And cutting the bolted part on the shifter ring and weld them on the tranny tunnel.
Do you think this will be firm and not cracking the aluminum?
Old 06-12-2011, 09:53 PM   #4
350zriot
Member#: 264676
What do you think about this set up? i decided to weld it.
Old 06-16-2011, 02:51 PM   #5
Paidfor
Member#: 267815
Be in awe
dont hate .)
Y r u doing this again? I think i missed that part.
Paidfor is offline   Reply With Quote
Old 08-05-2011, 11:39 PM   #6
bettner12
Member#: 56179
05 LGT 407hp/372tq
Tuned by [email protected]
bettner12 is offline   Reply With Quote
Old 08-07-2011, 08:11 PM   #7
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
using all 4 pointing positions would be a good start.
scby rex is offline   Reply With Quote
Best way to mount subiegal's single gauge pod? criz Interior & Exterior Modification 13 07-06-2005 12:50 AM
Looking for the best way to mount Intercooler sprayer ring to FMIC MooseWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 03-05-2004 04:03 PM
best way to mount a sub box in the trunk berzerkled Car Audio, Video & Security 2 02-25-2004 12:30 AM
What's the best way to mount generic rear mudflaps? Robmat General Forum Archive 2 03-08-2001 08:52 PM
Best way to mount Thule Rack? AllWheelsDriven North West Impreza Club Forum -- NWIC 4 01-09-2001 11:59 PM
