Old 06-10-2011, 04:03 PM   #1
Keaton522
Member#: 279103
2002 WRX Hybrid
Default After engine rebuild car started, but will not now.
Just finished up a engine rebuild (bent valves). Replaced the heads, new head gasket, turbo back exhaust, headers, perrin crankshaft pulley, and perrin intake. The engine started, idled till i turned it off, but ran rough with the alternator and ac belts not on. I put the belts on today and now the engine wont idle like it would before. Its almost like its not strong enough. It cranks, fuel pump comes on, and it starts for a split second, but then dies. I was thinking it was the plugs (i didnt double check the gap when I put them in), but am open to suggestions. The only sensors not plugged in are the two oxygen sensors because I am waiting on them through the mail. Holes are plugged though.
Keaton522 is offline   Reply With Quote
Old 06-10-2011, 04:36 PM   #2
KronosPerformance
Member#: 285188
2009 Subaru STi
I can picture that if your primary O2 sensor isn't plugged in that it will want to crap out because it thinks there is something wrong.
KronosPerformance is offline   Reply With Quote
Car cranks, but does not start! TheSilentMan04 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 01-05-2011 05:07 PM
Car turns over but will not start Luckyduck919 Normally Aspirated Powertrain 11 03-18-2010 11:32 PM
Blue smoke still after engine rebuild DeezNutz1833 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 31 10-20-2005 03:51 PM
Running Link car cranks but will not start subaru mike Engine Management & Tuning 31 02-15-2005 10:57 PM
Do I need to change oil sooner after engine rebuild? cky211 Service & Maintenance 5 05-17-2003 06:03 PM
