Old 06-10-2011, 10:33 PM   #1
bill hincher
Member#: 280288
Default building my own flex plate
I needed to build a flex plate for a 6G72 V 6 Mitsubishi engine so I got some HSLA commercial grade 1/8 in plate and marked the center with a small starter hole, you can see the original flex plate was built from 1/16th but its shape was fairly close
this machine is called a nibbler or pullmax style machine, it was built for making circles, but I also build my own dies for what ever purpose I want to use
a flex plate is just that, it flex's and its also like a spring, it gets pushed forward under load, the flex plate has to move about .060 so a bit of a bend not only keeps a little of pressure against the load but when you bend steel, you double its strength without adding weight
I opened the center hole so I could mount my adapter and then drilled it to accept the Ford C-4 torque converter and this was one of the reasons the C 4 was chosen, it has a 10.5 in bolt circle pattern, which was just small enough to fit inside the ring gear that was selected, the GM converter was 10.75 and would not fit
I mounted the flex plate to the coupler just for the center, then I trimmed the outer diameter to size for the ring gear
this is the finish look, I need to pay some attention to detail but I was pretty happy with it, with the smaller ( 10 in or smaller ) converter I will be mounting the starter as a reverse set up but I kept the ring gear on the flex plate so anyone could select and buy what ever stall speed converter they may want
bill hincher is offline   Reply With Quote
Old 06-15-2011, 07:49 PM   #2
69subaru360
Member#: 159682
1995 WRX
2015 F150
That is neat. How had would it be to make an EJ engine to GM automatic flexplate? Someday way in the future I might want to have one made.
Old 06-15-2011, 11:34 PM   #3
bill hincher
Member#: 280288
I did the GM adaptor a long time ago, this system adapts the wide block 464 or the narrow block 463 or the g54b to any GM auto trans
I could do a Gm adapter but I think the C 4 Ford would be a better build
Old 06-16-2011, 12:21 AM   #4
69subaru360
Member#: 159682
1995 WRX
2015 F150
Nice work! I was asking about GM because I have experience building GM transmissions. I'd be lost on the ford stuff. Someday I'd like to mate a powerglide to an EJ engine.
Old 06-16-2011, 07:11 AM   #5
bill hincher
Member#: 280288
the starter is the problem, it will have to be a reverse starter to clear most sub frames in most cars, so the Ford with the detachable bellhousing is the best chioce
Build your own slip plates for alignment? Type2 Brakes, Steering & Suspension 18 10-07-2009 12:59 PM
First time building my own PC - please take a look sasquatch95 Off-Topic 45 03-18-2006 08:34 PM
Im building my own pro street chopper, some pics STEALTH-WRX Off-Topic 48 04-01-2005 11:39 PM
So I'm building my own turbo kit jasona Normally Aspirated with bolt-on Forced Induction Powertrain 9 07-15-2003 06:52 AM
what parts would i need to build my own turbo kit? suberstar 2.5 Normally Aspirated Powertrain 1 02-17-2001 07:25 AM
