Old 07-24-2002, 04:04 AM   #1
flent
Member#: 4706
2001 2.5rs
silverthorn metalliac
Default Clunk in front end
I am having a clunking noise comeing from the front end of my car.. It sounds like it is comeing from the front left wheel.
The sounds only occurs now and then.
if I am going slow and hit the brakes it does it (sometimes)
if I am backing up and stop it does it (sometimes)
does not sound like a bad cv joint though
any ideas????
flent is offline   Reply With Quote
Old 07-24-2002, 01:12 PM   #2
thavy
Member#: 2505
95 Impreza L
yea i've had the same problem in my car for about 2 weeks now...just haven't had the time to look at it. Free bump...hopefully someone will know what's up.
Thavy
thavy is offline   Reply With Quote
Old 07-24-2002, 01:48 PM   #3
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Same thing here. It only happens when I am backing up or start going forward and have the wheels turned to almost full lock. Can't figure out what it is but I doubt it is to serious. anyone know?
Eric
Eric SS is offline   Reply With Quote
Old 07-24-2002, 02:05 PM   #4
Slack
Member#: 17548
If its what I think it is...I've asked the tech guys from my dealership and they say its just the brakes and its normal. They are just moving very slightly when you brake going in a different direction. Like if you are going forward and then back up and apply the brakes it will happen and so forth. It happens on my car, but I'd describe it more as a click than a clunk. *shrug* maybe its not the same thing.
Slack is offline   Reply With Quote
Old 07-24-2002, 02:08 PM   #5
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
I don;t think he is talking about the same thing if it is what is happening to my car. It happens to my car while not using the brakes.
Eric
Old 07-24-2002, 02:19 PM   #6
Slack
Member#: 17548
Well, at least I tried. A clunk without using the brakes...doesn't sound good. I would get it checked out asap personally.
-Slack
Old 07-24-2002, 05:03 PM   #7
Scubaru
Member#: 1530
Mine will clunk only when turning right-weird-Scu
Scubaru is offline   Reply With Quote
Old 07-24-2002, 06:14 PM   #8
Reflex-Arc
Lord of the Gilf
Member#: 1703
2012 Fiat 500 Sport
Copper
I was told the same thing by my dealer's service department. A quick way to see if this is the problem you are having is to back up slowly, apply the brakes, pull forward and apply the brakes again. Chances are you will hear a clunk.
It may be "normal" but it sure annoys the fudge out of me!
Reflex-Arc is online now   Reply With Quote
Old 07-25-2002, 01:08 PM   #9
flent
Member#: 4706
2001 2.5rs
I am just glad that other people have this same problem and like i did not fudge up my car.
Old 07-25-2002, 08:37 PM   #10
ted109
Member#: 18043
98 Outback Sport
Green
dont know all that much about how the stuff is put together in the front of the car, but iv heard that clunking noises in the front can be from worn/damaged/loose endlinks.
gl
ted109 is offline   Reply With Quote
Old 08-11-2002, 08:33 AM   #11
Deslock
Member#: 7959
2013 BRZ limited
1999 Nova RTS
I first noticed the clunking noise coming from my front wheels last week. Did any of you end up finding out that it's not normal?
It definitely sounds vaguely unwholesome...
Deslock is offline   Reply With Quote
Old 08-11-2002, 10:08 PM   #12
cyborg7_
Member#: 16571
2000 Impreza 2.5 RS
'90 Honda Civic si hatch
Originally posted by brucelee
I get a really loud clunk when I step on the gas while enguaged in a gear. No idea what it is!
That is your rear differential... at least that is what it should be... and it is loud.
cyborg7_ is offline   Reply With Quote
Old 08-12-2002, 05:09 PM   #13
tonytiger
Member#: 3844
1993 Legacy 1.8
The dictionary didn't know the word endlink. However, if it's the joint below the strut, it was the case in my Subie last year. I was in the army back then so I paid to do it, but the part wasn't expensive. It was in USD something like 25 or so.
That was my problem at least.
Here is a related pdf http://www.endwrench.com/pdf/steerin...seInfoSp99.pdf. It's about legacys front end clunk and the fix for it is fairly simple.
tony
tonytiger is offline   Reply With Quote
Old 08-13-2002, 12:20 AM   #14
RebelINS
Member#: 2953
2000 Impreza 2.5RS
2005 Impreza WRX STi
The endlink is the part that goes on the end of the sway bar. They are platic stock. These do seem to come loose, but if it was a loose endlink, you would hear the noise when you went over bumps, and when you took corners.
-Wes
RebelINS is offline   Reply With Quote
Clunking in front end, high milage 2.5RS TheIglu Newbies & FAQs 8 11-24-2009 10:25 PM
clunk in rear end???? subeman90 Baja Forum 4 09-27-2006 06:26 AM
Clunk in front suspension carpetsloth Brakes, Steering & Suspension 13 02-03-2006 01:16 PM
Clunk in front end since Prodrive & KYB Install sajohnson Brakes, Steering & Suspension 10 10-10-2005 10:50 AM
Clunking from front end SubieFL Brakes, Steering & Suspension 25 10-29-2000 03:01 PM
