Old 08-10-2002, 05:50 PM   #1
N/A01RS
Member#: 22478
2002 WRX Sedan
Platinum Silver
Question Nitrous Compression Ratio?
Im starting my N/A buildup and am looking at purchasing the Cobb Stage 2 short block, but when I get to where I want to be with the engine (210-220whp) I want to add a 75-100hp shot of nitrous. I was told by a guy at work that If I plan on running nitrous I should stick with the stock compression ratio instead of the 11:1 pistons that come with cobbs kit. Is this true? What is the highest compression that you can run on 93 octane gas with stand alone engine management? Safely of course. Also, as far as increasing the bore and/or stroke on the EJ25 I read somewhere that the bore is already so wide that it can cause problems with fuel burn. What are the positives and negatives to altering the stroke. I know this is alot of questions, but id apreciate any help/advice.
N/A01RS is offline   Reply With Quote
Old 08-11-2002, 12:25 PM   #2
N/A01RS
Member#: 22478
2002 WRX Sedan
Platinum Silver
Oh come on, I know theres some really smart people on here!
Old 08-13-2002, 02:08 AM   #3
Section 8
Member#: 821
Ummmm.... ask the person building your engine???
If you spending that kind of money and they can't answer that question.
Hang up the freaking phone.
I could tell you to run 13:1 and go to the paint store and buy chemical Toluine and add large ammounts to your gas. Guess what, your engine builder will say.
"Step away from the crack pipe."
And you will do what they say anyway......
cheeRS,
Greg
Section 8 is offline   Reply With Quote
Compression ratio? Naturally Aspirated Normally Aspirated Powertrain 31 11-30-2003 10:37 PM
('93-'01) what is the compression ratio on a... wop Impreza Forum 9 06-15-2001 05:34 AM
Boost and compression ratios 98mpreziveRS Normally Aspirated Powertrain 4 03-29-2001 06:58 PM
Compression Ratio for 98-01 RS Delhi Normally Aspirated Powertrain 4 03-14-2001 03:00 PM
Compression ratio question fellfrosch7 Normally Aspirated Powertrain 12 03-14-2001 12:43 AM
Message Board Statistics All times are GMT -4. The time now is 02:22 PM.
