Old 04-28-2012, 03:39 PM   #1
klarowe
Member#: 284753
2004 WRX STI
World Rally Blue
Default Custom multi-reservoir
In the near future I am going to be relocating the battery in my 04 STi, possibly rotating the main fusebox 90* to mount where the factory windshield washer reservoir is now, and then making a custom 3 "chamber" reservoir to house my coolant overflow, windshield washer fluid, and methanol. My question is, what metal should I use. I was thinking either aluminum (6061???) or stainless steel. I don't know what the reactivity is like between any of the fluids (especially the glycol in the coolant and the methanol).
What are your opinions? Anyone know if either metal will react with any of the fluids? Also, what thickness should I go with?? I was thinking 1/8" should be plenty, but I'm not sure if it might be too thin...
Thanks in advance.
klarowe is offline   Reply With Quote
Old 04-28-2012, 05:45 PM   #2
spec.B - autox
Member#: 209699
2009 STI
One of the drawbacks of methanol as a fuel is its corrosivity to some metals, including aluminum. Methanol, although a weak acid, attacks the oxide coating that normally protects the aluminium from corrosion:
6 CH3OH + Al2O3 → 2 Al(OCH3)3 + 3 H2O
The resulting methoxide salts are soluble in methanol, resulting in clean aluminum surface, which is readily oxidized by some dissolved oxygen. Also the methanol can act as an oxidizer:
6 CH3OH + 2 Al → 2 Al(OCH3)3 + 3 H2
This reciprocal process effectively fuels corrosion until either the metal is eaten away or the concentration of CH3OH is negligible. Concerns with methanol's corrosivity have been addressed by using methanol compatible materials, and fuel additives that serve as corrosion inhibitors.
spec.B - autox is offline   Reply With Quote
Old 04-28-2012, 07:04 PM   #3
klarowe
Member#: 284753
2004 WRX STI
World Rally Blue
Its for a water/methanol mixture but I still had a feeling the aluminum could be an issue.... I'm just no chemist so I didn't know the specifics.. lol. So by the sounds of it I'm better off going with stainless?
Old 04-29-2012, 04:34 AM   #4
WReXd
Member#: 114101
93 Impreza L Swap
Stainless would work. Surprisingly, plastic is also an option. I believe polypropylene would work.
WReXd is offline   Reply With Quote
Old 04-29-2012, 05:08 AM   #5
Awd180
Member#: 282763
2002 Impreza
Gray
Stainless could be an issue if charged (mounting to frame equals negative charge) and contact with opposite charge = spark. You could insult the mounting connections but polypropylene (plastic) is best.
Awd180 is offline   Reply With Quote
Old 04-29-2012, 05:16 AM   #6
Awd180
Member#: 282763
2002 Impreza
Gray
Thanks for the detail,
Old 04-29-2012, 11:47 AM   #7
klarowe
Member#: 284753
2004 WRX STI
World Rally Blue
The problem with polypropylene is that I don't have any way to mold it. I would prefer to stick to metal so it can be welded and make it 100x easier to actually fabricate... lol. That is a valid point regarding insulating the mounts to prevent any sparking. I'll def. have to take that into account and throw some quick rubber / plastic washers on all mounting points.
Old 04-29-2012, 03:06 PM   #8
Awd180
Member#: 282763
2002 Impreza
Gray
Yeah I was lazy and wrote insult over insulate. But it's on you if you wanna drive around with a pressure vessel. Using washers doesn't insulate the bolt, your still have xx# of charged bolt heads.
Most fuel cells are plastic as well as methanol kits come with a plastic reservoir for a reason.
Old 04-29-2012, 08:10 PM   #9
klarowe
Member#: 284753
2004 WRX STI
World Rally Blue
I know taht using the rubber washers won't insulate the bolts, but using rubber washers (not the 1/2 rubber, 1/2 metal) along with a grommet should solve that problem. And as far as the bolt heads being charged, I guess I don't see the issue there. Even with a plastic reservoir, you still have metal bolt heads being charged. But you now also introduce the issue of static spark. All 3 reservoirs would also have vents since one of the systems are pressurized. But the cost and pain of trying to mold a triple chamber plastic reservoir wouldn't be worth the hassle. But I completely understand where you are coming from.
Old 04-29-2012, 09:15 PM   #10
Awd180
Member#: 282763
2002 Impreza
Gray
A 1L reservoir cost around 20$ x 3 60$. Cost of materials for ss idk but close in price.
You won't find a 3 chamber vessel.
I like the look your going for but its something that could build a higher charge than the static charge from a plastic.
Have it plastic coated or a ceramic coating might work as well.
Old 04-29-2012, 09:44 PM   #11
klarowe
Member#: 284753
2004 WRX STI
World Rally Blue
Wow... I actually never though of doing universal reservoirs.. duh. That would actually save quite a bit of $$ since I would only need 2 at that point (reuse factory washer fluid reservoir). And if I really wanted to clean it up I could just build a small cover. Once I do the battery relocation I may just have to take some measurements and see what I can make fit... but that might be the route I take. Thanks for the help!
FS : 04-05 custom grill Subey03 Exterior/Styling 25 01-31-2013 02:18 PM
FS : WA-08+ Sedan STI Struts modded for wrx, Custom TMIC theotherguy NWIC Private Classifieds 52 06-24-2012 08:10 PM
FS : 2006 Chevrolet Trailblazer SS Custom, 420hp, lots of goodies! TKDKracker007 MWSOC Private Classifieds 0 04-28-2012 01:28 PM
one off custom knob for a customer [email protected] Off-Topic 18 12-14-2004 10:27 AM
WRX Turbo kit. TO4R Turbo, Custom upipe and custom downpipe STEALTH-WRX Private 'For Sale' Classifieds 13 03-07-2004 02:03 PM
