Old 06-12-2011, 01:35 PM   #1
lllarrolll
Member#: 271569
2010 Impreza 2.5i 4D
Spark Silver
Default Tire Pressure?
Just wondering what PSI everyone uses in their tires. I have aftermarket tires and wheels. 17x7, Dunlop Direzza Star Spec. Max PSI is 51. Right now I have 36 in all four. Is that good? Can someone explain the benefits of higher or lower tire pressure? I use the car as a daily driver, a little spirited driving sometimes, and I want to start doing autox soon. Thanks!
lllarrolll is offline   Reply With Quote
Old 06-12-2011, 01:52 PM   #2
razrielle
Member#: 205698
depends, I put 40 if Im doing highway driving not in bad weather (if I know), 35ish city
razrielle is offline   Reply With Quote
Old 06-12-2011, 02:00 PM   #3
lllarrolll
Member#: 271569
Spark Silver
I do about 5 minutes city and 5 minutes highway going to work, same back. Other than that I don't drive often.
Old 06-12-2011, 02:00 PM   #4
Euclid
Member#: 41846
both 05 LGT, 08 STI
black and white
Whatever is printed on my door jamb.
Euclid is offline   Reply With Quote
Old 06-12-2011, 02:01 PM   #5
lllarrolll
Member#: 271569
Spark Silver
I looked there and couldnt find it!
Old 06-13-2011, 08:35 AM   #6
buki_JB
Member#: 274345
2011 STI 5dr
It's on there, keep looking.
Higher pressure:
- Reduced grip
- Uneven treadwear (centerline wears faster than shoulders)
- Better rolling resistance
- Better hydroplaning performance (Due to reduced footprint area, ymmv tho)
Lower pressure:
- Uneven treadwear (shoulders wear faster than centerline)
- Worse hydroplaning performance (Increased footprint area, again, ymmv)
- Possibly slightly increased grip (there is a dropoff point here)
- Worse rolling resistance
That's all I can think of off hand...in short, run what is recommended for your vehicle. There are few reasons why you would want to increase or decrease it for daily driving.
buki_JB is offline   Reply With Quote
Old 06-13-2011, 08:53 AM   #7
jonklein611
Member#: 117776
2011 WRX Limited 5dr
WR Blue Pearl
Tire Rack's Technical Section has a TON of info on tire tech.
Air Pressure - Tire Inflation
Air Pressure - Correct, Underinflated and Overinflated
http://www.tirerack.com/tires/tirete...e.jsp?techid=1
Air Pressure vs. Dry Performance
http://www.tirerack.com/tires/tirete...e.jsp?techid=2
Air Pressure vs. Wet Performance
http://www.tirerack.com/tires/tirete...e.jsp?techid=3
Air Pressure, Temperature Fluctuations
http://www.tirerack.com/tires/tirete....jsp?techid=73
Air Pressure, Time Fluctuations
http://www.tirerack.com/tires/tirete....jsp?techid=74
Air Pressure/Load Adjustment for High Speed Driving
http://www.tirerack.com/tires/tirete....jsp?techid=72
Air Pressure: When and How to Set
http://www.tirerack.com/tires/tirete...jsp?techid=147
Checking Tire Inflation Pressure
http://www.tirerack.com/tires/tirete...e.jsp?techid=8
Clearing the Air About Nitrogen Tire Inflation
http://www.tirerack.com/tires/tirete...jsp?techid=191
The Influence of Altitude Changes on Tire Pressure
http://www.tirerack.com/tires/tirete...jsp?techid=167
Tire Valve Types, Components and Uses
http://www.tirerack.com/tires/tirete...jsp?techid=208
We're Checking Who's Checking Spare Tire Pressures
http://www.tirerack.com/tires/tirete...jsp?techid=185
We're Checking Who's Checking Tire Pressures
http://www.tirerack.com/tires/tirete...jsp?techid=165
jonklein611 is offline   Reply With Quote
Old 06-13-2011, 11:54 AM   #8
06blksti89
Member#: 285210
i always have all 4 at 36.
06blksti89 is offline   Reply With Quote
Old 06-13-2011, 10:34 PM   #9
TheTesseract
Member#: 236238
2010 WRX Wag
For me 35 front 33 back. my door sticker says 33 front and 32 back
For autocross I been running about 40 front and 33-35 back. I am still feeling it out.
36 in all four is good, as long as you're some where near what the door says your should be fine. Look for a sticker on the driver side, not on the door but on the sill. That is where it in on the '10 wrx wagons.
Also go for read the tire rack info, more than you would ever want to know and will answer every technical question you could ever want to ask.
TheTesseract is offline   Reply With Quote
Old 06-14-2011, 10:25 PM   #10
575rider
Member#: 112024
03 hybrid 6spd wgn
Santa Cruz Bronson-Carbon
You're not even driving far enough for your tires to heat up. For you, anything above 32 is going to be fine. I believe Subaru recommends 33fr and 32rr, may be slightly diff on your vehicle, but it's on the sticker in the driver side door jamb.
575rider is offline   Reply With Quote
Old 06-14-2011, 11:02 PM   #11
KLZCYA
Member#: 281146
95 6 spd GC8 STi
I run 40 all around. Haters gonna hate.
KLZCYA is offline   Reply With Quote
Old 06-15-2011, 12:53 PM   #12
nwegel11
Member#: 263904
36f 34r
nwegel11 is offline   Reply With Quote
Old 06-15-2011, 01:27 PM   #13
EdHilario
Member#: 137398
2004 Impreza 2.5RS
36F and 35R
EdHilario is offline   Reply With Quote
Old 06-15-2011, 03:03 PM   #14
bpang1
Member#: 67225
2015 Audi S4
Red
40 Front and 34 Rear. This is the best so far for my auto-x needs and is fine on the street. Gives me neutral handling with the ability to coax oversteer with the brake pedal and understeer with the gas pedal.
bpang1 is offline   Reply With Quote
Old 06-15-2011, 03:32 PM   #15
cmiovino
Member#: 134005
2004 WRX Premium
I used to roll with 50F/47R in my Kuhmo ASXs... the outsides would wear out hardcore. Then I made the front max negative camber and it's helped considerably. The sidewalls on these are very flexible. I now run that 43/40 now that they're even again. It works for me.
Old 06-16-2011, 11:28 AM   #16
Vew
Member#: 74229
2004 PSM WRX
When we did our autox runs, we'd put white shoe polish on the edge of the tread to the edge of the sidewall, overlapping a little. After our 1st run, you can see how much contact your tire made. If there was still polish on the tread, it was overinflated. If polish was missing from the sidewall, it was under inflated.
Vew is offline   Reply With Quote
what tire pressure to run stock? and what is a good aftermarket tire? jay25RS Tire & Wheel 6 06-13-2011 01:54 PM
New tires, which tire pressure to go by, tire or car? NewShockerGuy Tire & Wheel 7 12-04-2004 02:33 PM
Tire pressures for snow tires? TimStevens Brakes, Steering & Suspension 10 12-22-2001 05:00 AM
Tire Pressure Loss on Yokahoa Geolander Tires Rusty Russell Forester Forum 1 08-04-2001 03:00 PM
Tire Pressure for snow tires??? 99 RS 2.5 New England Impreza Club Forum -- NESIC 4 10-12-2000 09:17 PM
