Canada Region Club
Go Back   NASIOC > NASIOC Regional Areas > Canada Region Forum
Old 07-24-2002, 09:05 AM   #1
Extraze
Member#: 16980
2009 FXT
Default Ottawa - EGT + Oil Temp gauge Install
Hi, i'll be getting my Gauges this week, probably today or tomorrow, and i was wondering if anyone around ottawa had allready installed an EGT sensor and welded it on their WRX and had the time/equipment to help me install mine ...
FYI,
i got Omori Electronic EGT gauge - since im not experienced in drilling holes in my manifold, im not too sure that i want to do it myself.
as for the oil temp gauge, I read that it had something to do with the drain plug/oil pan ?? correct me if i'm wrong.
- I know i have posted this in the Newsgroup, but had no success in getting a reply, so again, if anyone can help me out. i would be really greatfull,
Thank you
Extraze is offline   Reply With Quote
Old 07-24-2002, 01:08 PM   #2
mturmel
Member#: 2473
World Rally Blue
If you don't feel comfortable drilling a hole in the intake manifold, then don't!
I'd take it to Lachute Subaru (www.lac-ss), they've done that gizillions time. Should not be too expensive either.
Matt
NCSC Ottawa
mturmel is offline   Reply With Quote
Old 07-24-2002, 01:21 PM   #3
Extraze
Member#: 16980
2009 FXT
what about the local dealers here in ottawa ? any of them ever did the EGT sensor / anyone ever had them done by those guys ?
if not, then i sure will go take a trip to lachute and ask the guys there to do it
thanks again
Old 07-24-2002, 01:27 PM   #4
mturmel
Member#: 2473
World Rally Blue
If you only worry about the drilling part, then you could take your manifold out and take it to any machine shop. Obviously, that means you can't use your car when they're doing it...
Lachute could probably do the whole install for you as well... and then you get to see the goodies room and Julien's PGT WRX
As far as local dealer, both Ottawa dealers are not used to modded cars, at least Ogilvie. I take my car to Gatineau, they have the number one tech in Canada. They've done some mods for me, you can always give them a call (819) 643-4341. Eric should be able to tell you if they can/will do that.
Matt
Old 07-24-2002, 01:30 PM   #5
Extraze
Member#: 16980
2009 FXT
thanks,
ill call lachute to see if they arent to busy this week, if they dont have time ill try gatineau
thanks again
Old 07-24-2002, 01:35 PM   #6
Robin2
Member#: 390
2011 WRX sedan
Plasma Blue
It will be next week...... I made an appointment next Tuesday at 9am to install my complete Brullen exhaust system.....
If you call Westboro ask for Aron Gabor.... he's the service manager there...... but I don't know if they've done it before but probably since they do sell the Subaru gage cluster....
I doubt Ogilvie would do it.....
Most of the Ottawa members go to Lachute on a regular basis for most of their mods and installation.....
Robin
Robin2 is offline   Reply With Quote
Old 07-25-2002, 01:07 AM   #7
99TS
Member#: 846
My buddy owns a WRX Wagon and got the OEM gauge set installed by Ogilvie. I don't know if he will chime in.
From what i can see, they replace the factory drain plug with a sensor + plug (1 unit). Because of the sensor wire and extra large nut I cannot fit a socket to undo it. I used a adjustable wrench.
Ogilvie install aftermarket stuff. Ask for Gildo. He is quite knowledgeable. I am told that he's got an STi swap GC8 in his garage.
99TS is offline   Reply With Quote
Old 07-25-2002, 09:42 AM   #8
TStoWRX
Member#: 19354
Yes, ask for Gildo, they should be able to do that.
Robin, where did u get your Brullen exhaust system,? Toronto?
How much it cost u? and how much Lachute gonna charge u 4 installation? Actually I was there yesterday chking out the MRT downpipe and PDE uppipe, I might get those done by Julien too.
TStoWRX is offline   Reply With Quote
Old 07-25-2002, 10:28 AM   #9
Robin2
Member#: 390
2011 WRX sedan
Plasma Blue
Guido knows his stuff (no doubt) but he's the parts manager.... if he was the service manager then I'd know the job would be done right.... I'm not big on the service side at Ogilvie (it's hard to beat Lachute's service) .... but no harm in calling around.... if it's standard gauge, then any dealer can do it cause they all sell the Subaru gauge pack....
Yes, I bought it used of a member from Toronto.... picked it up on Sunday in Brampton.... I talked to Rejean and cost should be under $100.... including parts and labour (pretty easy job when you have a lift....)..... (parts are bolts and header gaskets) and need to relocate the rear 02 sensor (further out)...
The brullen system new is $1200 for the headers and high flow cat and $700 for the cat back system..... plus tax.... I think installation is included....
This is for the RS..... there's more piping for the WRX.....
Robin
Old 07-25-2002, 11:33 AM   #10
Skeandhu
Member#: 1056
For your oil temp sender, there may be an easier way than replacing the drain plug...
When I installed my oil-pressure sender, I used the "main oil gallery" plug, just under the throttle body. Sure, I don't have an intercooler, so it was pretty easy, but it may be your best bet with less chance of damaging things every oil-change.
All I had to order was a specific bolt and washer from Guido. This is the same bolt and washer that is used for the oil-pressure dummy-light (under the alternator). It's a pre-drilled and tapped (1/4 or 1/8? BSPT) 17mm bolt that fits right in. Just re-tap the bolt if you're looking to fit an NPT fitting, and you're pretty much good to go.
I'll look around for the part #s; there's also info on this board if you do a search under oil-pressure sender. I can give you a better idea of what I've done if you show up to the NCSC meet next Thursday.
Not sure if the heat from the engine will mess with the sender readings though???? The bolt on the oil pan has less ambient temperature at least....
Cheers,
Kevin
Skeandhu is offline   Reply With Quote
SoCal FS: Maddad Clarity Amber Ti Boost/EGT/Oil temp Gauge set r12rex SCIC Private Classifieds 10 04-26-2009 09:49 PM
WTB: Maddad Boost, EGT, Oil Temp Gauges silvrex02 Private 'Wanted' Classifieds 1 02-17-2009 11:12 AM
Omori Boost, EGT, Oil Temp, Gauges saggioWRX Interior/Dressup/Audio & Security 0 06-02-2007 12:25 AM
lifter noise after EGT/oil temp/boost install okaythen01 Factory 2.5L Turbo Powertrain 11 05-02-2006 12:39 AM
oil temp gauge install? YaZahX Factory 2.0L Turbo Powertrain 8 03-14-2002 10:23 PM
Message Board Statistics All times are GMT -4. The time now is 12:47 PM.
