Old 07-24-2002, 09:26 AM   #1
gtx1990
Member#: 20041
1995 Legacy LSi
Maroon
Default weird intermittant no-start
Have this weird intermittant no-start condition.
Chased it down to the wire for the starter solenoid is not getting any voltage. Car has completely redone engine and chassis grounds... that's not it. If I take a jumper wire and jump from solenoid to battery it starts right up.
Get a click from a relay in the cabin somewhere, but that's it.. battery load doesn't increase either. It *seems* to be heat related but sometimes the car won't start when it's been sitting in the sun for a few hours.
I'm thinking some sort of relay inline, maybe alarm... I don't have a wiring diagram so I really can't chase further. Help!
Car is a 95 BD (legacy) 2.2 SOHC AWD
Mike Harrington
gtx1990@hotmail.com
gtx1990 is offline   Reply With Quote
Old 07-24-2002, 04:15 PM   #2
Tim Smith
Member#: 19147
2002 Impreza RS
Alpine White
Is the clutch all the way in?
Tim Smith is offline   Reply With Quote
Old 07-25-2002, 02:16 AM   #3
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
it sounds like a bad relay to me...check the starter relay....
jeremy
Old 07-25-2002, 02:21 AM   #4
danci1973
Member#: 19018
1995 Legacy Wagon
What has the clutch got to do with starting??
Do USDM models have some sort of 'cluthc switch' that would disable starting without engaging it (I'm sure my european version doesn't)?
D.
danci1973 is offline   Reply With Quote
Old 07-25-2002, 10:45 AM   #5
gtx1990
Member#: 20041
1995 Legacy LSi
Maroon
FYI - it's an auto, no clutch switch
Where's the starter relay?
Mike Harrington
Old 07-25-2002, 12:19 PM   #6
Tim Smith
Member#: 19147
2002 Impreza RS
Alpine White
D.
Yes. You have to push the clutch to the floor board to start it. just like the auto has to be in park. It makes it impossible for someone to drive into a building when trying to just sart there car. (Yes, that has unfortunately has happened.)
ON an auto. do you have it in Park. couldn't resist.
I would take the relay too. It should be in the under-the-hood fuse box.
Old 07-25-2002, 12:30 PM   #7
gtx1990
Member#: 20041
1995 Legacy LSi
Maroon
any specific one? They're all marked AFI0 - AFI6 or something like that. IE, all all marked the same with different numbered suffixes.
Geez, I wish I had a factory service manual for this thing... but they're not $50 lik ethey were for my Mazda
Mike Harrington
Before low power, now, no start.. POSSIBLY SOLVED cronus1987 Normally Aspirated Powertrain 15 06-01-2010 07:29 PM
Intermittent no start condition, 2002 WRX, 95k miles austinramage Factory 2.0L Turbo Powertrain 18 07-03-2009 06:13 PM
Intermittent no-start on a 95 L bigboss Normally Aspirated Powertrain 0 09-23-2006 07:09 PM
weird no start bugman1964 Service & Maintenance 3 04-13-2005 12:28 PM
Very intermittent no start problem NotAnRS Normally Aspirated Powertrain 6 05-15-2002 08:39 AM
Message Board Statistics All times are GMT -4. The time now is 03:10 AM.
