Old 06-13-2011, 08:36 AM   #1
plunk10
Member#: 32342
2004 :derp:
Default TTAC: 2012 Hyundai Accent... looks like an Elantra
http://www.thetruthaboutcars.com/201...ent-gls-sedan/
By Michael Karesh on June 8, 2011
The Hyundai Accent has never been a “gotta have it” sort of car. Instead, it’s been a “what’s the cheapest thing you got?” sort of car. The 2011 started at just $9,985 (plus shipping and handling). That’s “started,” as in past tense, because the 2011 is history. The 2012, now arriving at dealers, starts at $12,445 plus $760 for destination. Add an automatic transmission, A/C, the $1,300 Premium Package (fog lights, cruise, remote keyless, Bluetooth, upgraded interior trim, 16” alloy wheels in place of 14” steelies), and floor mats, and you’re looking at a $17,350 sticker. Clearly Hyundai thinks they’ve developed a much more desirable car. Have they?
Hyundai couldn’t get a new Accent to me before an upcoming vacation, and reviews based on press cars are embargoed until June 22nd regardless, so in the interest of reporting on the car early I dropped by the dealer. At first they didn’t appear to have a 2012 Accent. Then I noticed that the fog lights on one of the Elantras wasn’t quite like the others—because it wasn’t an Elantra. From the front the cars aren’t easy to tell apart. From the side, the Accent sedan has the same highly styled shape as the Elantra, with swept back headlights, a strong character line rising through the door handles, and an arching roofline that terminates over yet another, even larger black plastic triangle. But this shape is compressed into a 172-inch length, a half-foot less than the Elantra. So, like the previous-generation Elantra, the new Accent sedan appears thick through the midsection. As with the Ford Fiesta, the new hatchback (which isn’t yet at dealers) is considerably more attractive.
Inside the new Accent, Hyundai’s designers weren’t permitted to indulge themselves as much as they were with the Elantra. So there are no wavy curves, just a clean, straightforward design with easy-to-use controls—including three separate knobs for the HVAC. The surfaces are primarily hard plastic, but they are attractively textured and feel solid. The Premium Package’s piano black trim adds an upscale touch; the silver trim that remains on the doors, not so much. Some piano black would be welcome there as well. This being a GLS sedan with the Premium Package, the tan cloth aspires to look and feel luxurious. I’d personally prefer a heftier, sportier fabric, but perhaps such is fitted to the SE hatchback. In terms of materials, you might be able to do a little better in this segment; you can certainly do much worse.
There are benefits to the Accent’s stubbier length: the windshield couldn’t be laid back so far, so the instrument panel isn’t as deep and the driving position is much better than that in the Elantra. The forward view is very open, inspiring confidence. Unfortunately, the manual tilt front seat adjustment standard in past Accents is gone, as it is from most cars these days. The steering wheel tilts, but does not telescope.
The Accent’s front seats are comfortably shaped, moderately firm, and provide a decent amount of lateral support. Those of you who always ask if a tall person can fit (you know who you are) might actually be able to fit—the driver’s seat has quite a bit of travel. When the front seat is positioned for the average adult male, there’s easily enough room in the back seat for another such male—and so far more than in the Mazda2 or the Fiesta. The Elantra offers a couple inches more legroom than the new Accent, but its rear seat is positioned lower (and even then doesn’t have allow quite as much headroom), so I actually find the Accent’s rear seat more comfortable. Trunk volume of 13.7 cubic feet is just a single cube shy of the Elantra, and quite good for such a small car.
The Accent GLS automatic weighs in at 2,463 pounds, so about 100 pounds heavier than a Mazda2 or Toyota Yaris but nearly 200 lighter than a Chevrolet Sonic or Ford Fiesta and nearly 300 lighter than the larger Elantra. Despite this relatively low weight, the car feels more solid than most in the class and even the Elantra. Factor in a direct-injected 1.6-liter engine that, with 138 peak horsepower, checks in only ten short of the conventionally injected 1.8 in the Elantra (and well above any others in the segment—the Fiesta’s 120 is next best), and even with the six-speed automatic the Accent never feels slow. With the manual transmission it might even feel quick. Even a strong 1.6 in a relatively light car must work fairly hard, so it’s a good thing that this engine likes to rev and sounds good (if not quiet) while doing so. The transmission can be manually shifted, but generally selects the appropriate gear when left to itself and lets the engine do what it needs to do, with shifts in the low 3000s in casual driving. In normal mode (there’s also an “Eco” mode) the transmission doesn’t lug the engine the ways it sometimes does in the Elantra, Sonata, and Tuscon.
Perhaps because the transmission isn’t tuned to be a killjoy, the EPA ratings are nearly identical to those of the heavier, port-injected Elantra, 30/40 instead of 29/40. Not quite the cause for celebration such numbers would have been just a year ago, but who’s doing to complain about “just” 30/40? Especially when the car is much roomier than competitors who fare no better (and who often fare worse) on the EPA’s rollers.
So here’s the part where I tell you that the car functions well, but isn’t any fun to drive. Except it actually is. The aforementioned driving position certainly contributes. The electric motor-assisted steering does feel artificial, even a bit gummy on center, but does have a satisfying firmness and loads up progressively when turned. Understeer and body lean are minimal, and the chassis remains composed and thoroughly predictable up to the limits of the front tires. The suspension is tuned much better than that in the Elantra (whose ride continually irritated me). Thanks to firmer damping, body motions are better controlled over uneven road surfaces. Some people might find the ride a little too firm, but for anyone who cares about driving it’s about as good as it gets with a 101-inch wheelbase. A Ford Fiesta does feel cushier, but also feels soggier when exercised. A Mazda2 feels lighter and more agile, and so is more fun to drive on a twisty road, but also looks and feels much cheaper. As in the Ford, wind and road noise are surprisingly low even at highway speeds—unlike the subcompacts of years past, the Accent is a car that could comfortably be driven for long distances.
I haven’t yet input pricing for the 2012 Accent into TrueDelta’s car price comparison tool–but should before the end of the month. For now, a less precise comparison will have to do. You cannot load up an Accent the way you can a Ford Fiesta. Features like leather upholstery, seat heaters, sunroof, and keyless ignition simply aren’t available. A leather-wrapped steering wheel can only be found in the Accent SE hatchback (MSRP with automatic: $17,555). So the midlevel Fiesta SE sedan seems to match up most closely with the $17,350 car I drove. Similarly equipped, one lists for $17,060, so a few hundred dollars less. Similarly outfit a Nissan Versa and a Toyota Yaris, and they list for $18,180 and $18,630, respectively, well above the Ford and Hyundai. So while the Accent certainly isn’t in the bargain basement, it continues to check in at the low end of the segment’s price range. A similarly-equipped Hyundai Elantra: $18,445, just over $1,000 more than the Accent.
The 2012 Hyundai Accent has a surprising number of strengths, including the best combination of power, fuel economy, handling, ride, room, driving position, interior materials, and overall refinement you’ll find in the segment. Some competitors are ahead in one or two of these areas, but not by much, and then lag severely in others. In hatchback form the new Accent is even attractive (and the sedan isn’t bad looking). This combination of attributes is so compelling that it’s not only easy to see why many people will desire the Accent more than other B-segment cars. Many will also find that it’s a better car than the Hyundai Elantra. The only significant advantage of the larger, more expensive car: you can get it with heated leather seats, sunroof, and nav. Don’t want these? Then the better-driving Accent is the way to go—even if you can’t get one for anywhere near ten grand anymore.
I sat in one of these yesterday. Methinks Honda/Toyota/Nissan should be worried if this thing drives as awesome as it looks and feels.
plunk10 is offline   Reply With Quote
Old 06-13-2011, 08:38 AM   #2
MattJP
Member#: 1280
I saw one on the road the other day and it looks good!
MattJP is offline   Reply With Quote
Old 06-13-2011, 08:50 AM   #3
BacDoc
Tone Patrol
Member#: 75141
Foreign car makers, making great cheap fuel efficient cars, ... this is new.
BacDoc really likes some of the Hyundai's.
BacDoc is offline   Reply With Quote
Old 06-13-2011, 08:58 AM   #4
WRX Shenanigans
Member#: 101378
I love my 2011 Sonata. My 2010 Elantra, on the other hand, is only ok (very boring). I should have waited another year...(though I got it for dirt cheap).
C/N: Hyundai is becoming a serious threat. And yes, I own 2 Hyundais.
WRX Shenanigans is offline   Reply With Quote
Old 06-13-2011, 09:23 AM   #5
Davemeister
Member#: 86577
2016 Supercoolmobile
Awesome Pearl Metallic
It drives like a truck, and the interior is sub-standard compared to the V6 Mustang.
Davemeister is offline   Reply With Quote
Old 06-13-2011, 09:27 AM   #6
jbone
Member#: 97060
SPB- Proud owner of
the flip-cup trophy.
jbone is online now   Reply With Quote
Old 06-13-2011, 09:37 AM   #7
nepawrx
Member#: 8702
I'd 've done better
if it weren't for Kai
A relative of mine just had a 2011 Elantra or Accent as a rental. He hated it. He said it was super loud inside on the highway. There's my little bit of anecdotal evidence.
nepawrx is online now   Reply With Quote
Old 06-13-2011, 09:45 AM   #8
plunk10
Member#: 32342
2004 :derp:
some folks in the TTAC comment thread are saying the Kia Rio is more attractive. I think Hyundai should have named this car something else, because they have a hard enough time selling Hyundais. Everyone knows the Accent is the cheapest of the cheap.
Still, they are becoming a threat. If I were buying a NEW car, they would be high on my list. For now though, I'm only ever considering used.
Old 06-13-2011, 10:15 AM   #9
BacDoc
Tone Patrol
Member#: 75141
Douchemeister strikes again!
Old 06-13-2011, 10:19 AM   #10
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
And the interior is terrible!
XanRules is offline   Reply With Quote
Old 06-13-2011, 10:22 AM   #11
BGPunk2001
Member#: 46134
You forgot: "AMERICA... **** YEAH!!!"
BGPunk2001 is offline   Reply With Quote
Old 06-13-2011, 10:27 AM   #12
nate.the.great
Member#: 72031
does that have more to do with tires though? just asking since my impreza's highway noise volume depends heavily on tires.
nate.the.great is offline   Reply With Quote
Old 06-13-2011, 10:32 AM   #13
nepawrx
Member#: 8702
I'd 've done better
It may. Like I said... anecdotal evidence. Take it at face value. All that I know is he said it was a piece of junk.
Old 06-13-2011, 10:37 AM   #14
FiveDoorSVT
Member#: 79933
'03 Mazda Protege5
I love the way that little green hatchback looks in their new commercial. In fact, all the new Hyundai's look really good.
Edit: Website says it comes standard with a 6speed manual?! Sweet!
FiveDoorSVT is offline   Reply With Quote
Old 06-13-2011, 10:50 AM   #15
shikataganai
Member#: 92634
'07 Land Cruiser
'12 RAV4 EV
Here's a good reason to not buy a small, Korean car: they're unsafe.
Note #3, 6, 8, 11, and 12 are all Korean small cars.
Source is the 2011 IIHS driver death rate report. For comparison, the safest "small car" had a rate of 55 (driver deaths per million registered vehicle miles). "mv" is multi-vehicle accident, "sv" single-vehicle, "roll" rollovers.
shikataganai is offline   Reply With Quote
Old 06-13-2011, 10:56 AM   #16
WRX Shenanigans
Member#: 101378
Maybe it has something to do with the driver demographics?
ibyou'reracist9pointsforyou
But seriously, you can't negate an entire market based on 4 cars. Especially since Hyundai has rolled out all new models for 2011/2012...
Old 06-13-2011, 10:58 AM   #17
boxered
Member#: 61884
I'm seeing Sonatas all over the place. They the new Accord.
boxered is offline   Reply With Quote
Old 06-13-2011, 11:02 AM   #18
shikataganai
Member#: 92634
'07 Land Cruiser
'12 RAV4 EV
I see no reason why demographics of Hyundai or Kia drivers should be any different than those of Civic or Corolla drivers, yet the death rates are quite different.
I'll only be convinced when/if the new models show themselves to be different than the old. Until then, I remain a skeptic.
Old 06-13-2011, 11:06 AM   #19
Davemeister
Member#: 86577
The problem is that the Hyundai drivers use their leftover cash to buy stuff like cell phones and iPods and then they drive off cliffs trying to drive while texting or navigate using a click wheel.
Old 06-13-2011, 11:17 AM   #20
Vostok 7
Member#: 30209
Do you need to
read this in Braille?
So does that mean all the other cars on that list are completely unsafe? Why do they sell 350Zs and Titans then, since they're so unsafe?
There's a lot of factors lists like that don't take in to account. Going off of that list alone, Chevrolet and Nissan are far more unsafe than Kia or Hyundai (which only had one car on the list, which also happens to be one of the oldest models as well).
You're smarter than that, dude.
Vostok 7 is offline   Reply With Quote
Old 06-13-2011, 11:17 AM   #21
markman
Member#: 93623
This thread has been done already.
markman is online now   Reply With Quote
Old 06-13-2011, 12:24 PM   #22
Swizz_dub
Member#: 144089
Looks cute, dawww. I'd get one, or any other new Korean automobile (srs).
Swizz_dub is offline   Reply With Quote
Old 06-13-2011, 12:28 PM   #23
Full_Clip
Member#: 22218
You been cuddlying with skywaffles?
chris619
dr_wheel
Full_Clip bets the Corolla is in trouble.
Full_Clip is offline   Reply With Quote
Old 06-13-2011, 12:52 PM   #24
Davemeister
Member#: 86577
That outdated piece of garbage? I was surprised to see that the "55" on the speedo wasn't red.
Old 06-13-2011, 01:21 PM   #25
shikataganai
Member#: 92634
'07 Land Cruiser
'12 RAV4 EV
I think there really might be something wrong with the Titan's design. It has death rates totally out of line for its class, especially rollovers. 350Z probably is due to crees driving too fast. Aveo is a cheap Korean car so no surprise, and the other Chevys are merely cheap? I'm not sure why they're so bad.
Engorged claim: 2012 Hyundai Accent will be the ultimate affordable commuter car GodWhomIsMike Off-Topic 193 03-01-2012 02:15 AM
redesigned 2012 Hyundai Accent plunk10 Non-Subaru News & Rumors 15 11-19-2010 04:00 PM
Looks like an STi for me! WannaWRX Texas Impreza Club Forum -- TXIC 21 03-06-2003 02:12 PM
how do i make my L look like an RS spiralsmurf Interior & Exterior Modification 5 08-10-2002 10:06 PM
Look like an ad almost?? SubaDan Member's Car Gallery 5 09-01-2001 06:29 PM
