Old 06-13-2011, 01:12 PM   #1
jacky599r
Member#: 137631
2006 WRX
Red
Default Back to Stock (with a couple of problems)
Hi Guys:
I have since returned to stock hardware less exhaust and a cold air intake. Further, I've also gotten my ECU flashed with a stock ROM. However, the car still behaves weird. On boost, part throttle or WOT, there seems to be a fluttering sound coming from the right side of the engine compartment. Also, the transition between boost and off boost isn't a smooth one.
May i know what could be the probable causes?
Jacky
jacky599r is offline   Reply With Quote
Old 06-13-2011, 01:15 PM   #2
sc00ter
Member#: 117767
2015 WRX
CWP
Assuming you mean that you left the CAI and exhaust on the car, my guess would be that the CAI with the stock tune is causing this issue.
Also, is your downpipe stock?
sc00ter is offline   Reply With Quote
Old 06-13-2011, 01:39 PM   #3
Spenk
Member#: 7164
2000 Miata LS
Evo Orange Mica (1/644)
You need stock parts to run a stock map.
Spenk is offline   Reply With Quote
Old 06-13-2011, 02:28 PM   #4
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
Originally Posted by jacky599r
Hi Guys:
Jacky
The fluttering is probably your wastegate trying to regulate boost this is normal.
The transition you are speaking of is probably the Closed Loop/ Open Loop fueling transition which as far as I know has never been smooth in the turbo Subaru's in their stock form.
2Fast4U1DAY is offline   Reply With Quote
Old 06-13-2011, 03:08 PM   #5
Midevil
Member#: 175065
2011 SWP WRX
INTERNET TOUGH GUYS? LOL
You need to take the CAI off and replace with a stock intake system. CBE should be fine regardless.
Midevil is offline   Reply With Quote
Old 06-13-2011, 03:13 PM   #6
dsmtweaker
Member#: 265405
2013 Audi
Agreed
dsmtweaker is offline   Reply With Quote
Old 06-13-2011, 06:58 PM   #7
IA Performance
Member#: 25194
2008 Forester XT 5mt
Dark Gray
if the fluttering changes pitch from when the exhaust is cold to hot then you may have a leak at one of the pre turbo gaskets, most likely one of the 2 on the up-pipe. As others have also mentioned, there will be some wastegate door chatter sounds with an aftermarket downpipe. The bell mouth downpipes have some of the loudest chatter.
Stephen
IA Performance is offline   Reply With Quote
Old 06-13-2011, 07:40 PM   #8
wrx surfwagon
Member#: 262719
02 WRX
PSM with rust accents
you should prob get tuned for all those bolt ons. by exhaust do you mean tbe or cbe?
wrx surfwagon is offline   Reply With Quote
Old 06-13-2011, 10:28 PM   #9
jacky599r
Member#: 137631
2006 WRX
Red
Thanks for the prompt replies.
Well, my downpipe is stock and exhaust would be CBE (Fujitsubo). As for the transition, its really bad, I'm talking about "stages" of lag and punch between 2.5krpm to about 4.5krpm; it gets pretty jittery.
Is the wastegate supposed to sound like that? I remember i have the same intake,20g and a forge bpv and it did not make that kinda sound.
Old 06-13-2011, 11:38 PM   #10
IA Performance
Member#: 25194
Dark Gray
I'm leaning towards a mechanical issue versus wastegate door flutter given the stock DP. Stock DPs tend to make zero noise. Air leaks on the pressure side of the turbo will make noise, as will leaks between the turbo outlet and intake valves (throughout IC and intake manifold). Time to start with a boost leak test. A vacuum leak will create A/F issues that could result in the jittery sensation you feel.
Old 06-14-2011, 06:15 AM   #11
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
I disagree with your first statement. My 06 flutters ALOT. Stock turbo, stock DP, stock tune, all new gaskets, and no leaks.
Vacuum leaks will also cause the engine to Idle rough.
Old 06-14-2011, 05:40 PM   #12
IA Performance
Member#: 25194
Dark Gray
You are entitled to disagree, I too own a 2006, it is actually my 3rd one, and did not have a note worthy flutter noise from the wastegate. This was on a WRX, STi, and again with a WRX. All with Stock downpipes. I later changed to a bellmouth which brought in some flutter/chatter from the wastegate.
Old 06-14-2011, 05:46 PM   #13
IA Performance
Member#: 25194
Dark Gray
Check to make sure there are no leaks between the MAF and the turbo inlet. Sometimes the o-ring around the MAF fails, especially if an intake has been put on the car. If this leaks you may end up with similar symptoms.
Old 06-14-2011, 08:03 PM   #14
gathermewool
Member#: 143624
14 FXT Touring
VRP
Did you have a CAI on any of these? My '08 went from dead quiet to flutter city after installing an AEM CAI. The flutter should sound consistent if you're accelerating at a relatively constant rate, and should not be present at lower boost levels. Is this the case?
Finally, by flashing back to the stock ROM do you mean that you have a stock-like map or that you unmarried an AP? If some one sent you a "stock" map, is there a chance that it actually wasn't?
gathermewool is offline   Reply With Quote
Old 03-09-2014, 11:55 AM   #15
Raven999
Member#: 381768
Does the fluttering sound sound like a chattering either? Like rapidly tapping a coin on a hardwood table?
Raven999 is offline   Reply With Quote
Old 03-09-2014, 12:00 PM   #16
Raven999
Member#: 381768
I ask because I have this issue with mine, and I know turbo systems well enough to understand leaks and or cracks in turbocharged exhaust systems may or will cause chattering sounds. I own an 07 STi sedan, stock. (New project car and daily driver) and due to the rough winter that thankfully recently ended here in Spokane Washington, I feel my cars insides have taken much of a beating as well.
Moving back home to PA in a couple of weeks. Robson Mid Atlantic Impreza Club -- MAIC 2 10-31-2009 11:35 PM
going back to stock so a couple parts for sale shoodoggy Engine/Power/Exhaust 24 02-11-2008 02:16 PM
Selling A Couple Things...Going Back To Stock... coleman_a SCIC Private Classifieds 0 03-30-2007 02:35 AM
Going back to stock and have a couple of questions... Ldogdotcom Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-21-2005 11:33 AM
Back to Stock EM with An Intake for A Couple Days...Problem? Red Rexx Engine Management & Tuning 2 03-10-2005 10:57 PM
