Old 06-14-2011, 09:41 PM   #1
nighthawk06si
Member#: 267490
2011 WRX Hatch S2+SF
Default Lean AFR Stage 1 OTS map??
I got a Cobb AP(2011 WRX) and had the Stage 1 ACN91 map reflashed and I was doing some data logging and it seems my AFR is in the 11's under load. Was hoping someone from Cobb could take a look and see what's going on...
https://spreadsheets.google.com/spre...thkey=CO_3psAJ
https://spreadsheets.google.com/spre...thkey=CIbyutwG
If you guys need me to log with any of the other tables, let me know cause your feedback would be greatly appreciated.
edit: I know the side bar says I have SF and I'm on a stage 1 ACN91 is because I haven't installed the SF intake yet so just take that into account. I know there is a SF map i need to reflash when the SF intake is installed..
nighthawk06si is offline   Reply With Quote
Old 06-15-2011, 10:49 AM   #2
Cobb Tuning
Member#: 4803
Hello.
Unfortunately, monitoring the factory A/F sensor is not an accurate means of determining AFR under boost. AFR will be limited to no richer than ~11:1 AFR regardless of the actual AFR. A wideband o2 sensor (with our AccessTUNER software) is what would be needed to accurately determine AFR.
That said, for a basic stage 1/2 car, you can monitor A/F Learning #1 A, B, C, D to determine if there are any potential fueling issues. These are your long-term fuel trims and should be generally within around +/- 5%. Although these are determined in closed loop (basically idle and cruise conditions), the "D" range is also applied in open loop (basically acceleration above cruise) and fueling issues in closed loop could potentially be used to assume issues that would impact open loop as well. That is, you don't need a wideband o2 for a basic stage 1/2 set-up to determine potential issues with fueling.
Bill
Old 06-15-2011, 06:26 PM   #3
nighthawk06si
Member#: 267490
Originally Posted by Cobb Tuning View Post
Hello.
Bill
Thanks for clearing that up Bill. I'll take a look at the A/F Learning and keep an eye out for those and get a couple of logs with those on the datalog.
Thanks!
Cobb Stage 2 OTS map vs. Perrin Stage 2 OTS map liljon350 AccessPort 4 08-09-2009 10:01 AM
Stage 1 OTS Map only hitting 11psi, vacuum is good. asrautox AccessPort 7 08-03-2008 08:33 PM
AP Stage 2 OTS map + Invidia catless DP = CEL? JonM in MN Newbies & FAQs 8 09-28-2007 10:04 PM
VF22 stage 4 ots map ? DemiSlayer UTEC 3 03-11-2007 04:27 PM
safe running cobb stage 2 OTS map with catless tbe + megan headers? spooln407 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-19-2006 07:41 PM
